green.damion
green.damion
Visits: 79
its seems that due to the base pose of the Gen8 Daz puppet base, that when importing the character (along with the Genesis8_female_iCloneFaceKey patch) that the character is twisted up, while you can move and manipulate the puppet fine, the character doesn't start in the normal mode but twisted and this base twist effects all actions you assign the puppet...What to do? ive tried to change the puppet positioning in Daz...nope, tried to figure out a way todo similar in 3d exchange...nope...(I didn't even see an option to articulate the bones/arms and feet in 3d Exchange)...
Last Active: 5 hours ago
Visits: 60.6K
You're on the right track! See if this helps.
You may find that the characters arms are thrusting into their body, rather than at their sides when standing still. Sometimes you need to raise the arms into a Y pose for it to look correct.
6 Years Ago by
Last Active: 8 hours ago
Are you applying the Daz Genesis 8 T-Pose to your character in 3DXchange? If not click "Convert To Non-Standard" on the Modify panel and then apply the correct T-Pose.
6 Years Ago by
slavoisard
slavoisard
Visits: 699
Hi Peter !
We all have problems since latest update... All Genesis (1, 2, 3 and 8) are no more mapping eyes correctly, everything needs to be done manually.... May be this problem is linked to the global thing no more working as before ?
Visits: 60.6K
Peter (RL) (1/9/2018) Are you applying the Daz Genesis 8 T-Pose to your character in 3DXchange? If not click "Convert To Non-Standard" on the Modify panel and then apply the correct T-Pose.
We have a specific G8 T-pose? I'm not finding it. Are we supposed to have one? I am rather blind at times.
6 Years Ago by
Snarp Farkle
Snarp Farkle
Last Active: 3 Weeks Ago
Visits: 3.6K
You'll find it when downloading the iClone_Daz_Genesis_Extension version 3 from your Members area Registration area.
Visits: 60.6K
That's the facekey DUF file. There is the autoconvert 3DXProfile in the 3DX folder, but it doesn't change the arms into a Tpose. It may have gotten left out. It's certainly easy enough to fix. In any case, here is a proper G8 Tpose for both male and female you can download. Uncheck the active box if it's checked, and then click on the "Load" button up top to load a profile.
6 Years Ago by
Last Active: 31 minutes ago
Rampa, I have a Daz Genesis 8 3DX T-Pose when I open up XChange 7, so it's definitely provided somehow (the only thing I know for sure is *I* didn't create it or even want it -- it showed up there one day when my XChange updated).
Visits: 60.6K
I thought I was up-to-date. It shows 7.2.12 something. Little redundancy doesn't hurt. I guess.
Snarp Farkle
Snarp Farkle
Visits: 3.6K
Thanks Rampa, I didn't have the Profile's saved yet. After using them though I noticed that you didn't have the eyes and jaw set up in them so I did that and re-saved them so I won't have to do it manually anymore. I have been using the G8 T-pose that came with the 3Dx upgrade but so far I'm not so impressed with the G8 characters, then again I haven't done much with them yet either, time will tell!
