thedirector1974
thedirector1974
Visits: 5.2K
I already tried that - same result ... :(
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
Man, that sucks. I know...It's like I feel like my hands are tied with these
Matt GH
Matt GH
Visits: 1.2K
jarmoh (1/17/2018)
 Hi After update to 7.2 version, screen is not scaled right in 4k screen ( first picture). Character creator (second picture) and 3DXchange looks sharp. Screen looks like scaled up from 1k screen. I can't find way to fix it. Is there way to fix it?  Jarmo Same here! CC and 3DXC are fine at 4K res, while IC7.2 seems zoomed from a 1080p, resulting in very large blurred buttons and very unconfortable environment to work with.
Posts: 5.3K,
Visits: 16.8K
This one is real ugly. Soft shadow is making a "parquet floor" out of plain flat surface. I just took a screenshot, but it is rendered the same way with any combination of settings (super-sampling, high quality shadow) Soft shadow is ON  Soft shadow is OFF
Visits: 62.6K
4u2ges (1/26/2018)
This one is real ugly. Soft shadow is making a "parquet floor" out of plain flat surface. I just took a screenshot, but it is rendered the same way with any combination of settings (super-sampling, high quality shadow) Soft shadow is ON  Soft shadow is OFF  See if adjusting the shadow bias takes care of that.
Posts: 5.3K,
Visits: 16.8K
Not within the reasonable values. I mean Bias value of -150 took care of it.. but then shadow is way off as you can imagine.
Posts: 5.3K,
Visits: 16.8K
I did work it around by setting "to cast shadow" only for that corner cabinet. Luckily, this cabinet does not need to receive shadow from other objects... this time. Well, until next time, when I have something that needs to cast and receive :ermm:
thedirector1974
thedirector1974
Visits: 5.2K
Reducing the angle helps with this problem ...
Posts: 5.3K,
Visits: 16.8K
thedirector1974 (1/26/2018) Reducing the angle helps with this problem ...
Not exactly. What it does (and this goes to rotating caster itself or changing beam falloff or angle) is changing stripes pattern (angle, direction, width). But it never takes it completely off. Moreover the shadow is getting offset in relation the light source and obviously fall into the wrong direction. It's like, hey pal, you can't have me here, or else, I'll cause you that much trouble. It should be fixed.
mr_vidius
mr_vidius
Visits: 6.1K
been wondering if anyone else is having issues with the time line? I seem to can't copy, or paste anything on the time line. llike motions for example. and when adding a audio file.. either in the sound track, or character voice track. the auto play does not work.
vidius
