Anyone having issues up
loading content? I seem to be able to upload smaller content without any issues but I have been trying to upload an Avatar for the last couple of days with no success. Originally the Avatar was around 95MB. After that failed to upload a number of times, I did a poly reduction on some of the accessories, used JPGs texture instead of BMPs, and limited the number of accessories that I put on the Avatar. This reduced the Avatar file size to about 61MB.
When up
loading with Content Uploader, the 95MB file would get to somewhere past 75% and then return an error message saying that some of the content files could not be uploaded. When I reduced the size down to the 61MB, it makes it to something like 99% and then generates the same error. In both cases the content is not uploaded (i.e. does not appear in my Marketplace store site).
I have also noticed that sometimes when I upload multiple items at once, it gives me the same error after each item is successfully upload. For example, I am up
loading 3 items. After the first item is successfully uploaded, it gives me the error that some files did not upload. However unlike the above scenario, in this case the item does successfully upload before tripping the error message. At this point I can hit the Upload Draft button and basically continue with the next item...but having to press the Upload Draft button after each item. This seems to happen consistently with some content but not with all content.
Lastly, I see people talking about files larger than 100MB? How are people up
loading these? The Draft area seems to be limited to 100MB and Content Uploader does not seem to allow you to exceed that. Is this limit overcome by using the Upload button instead of the Upload Draft so that the content never goes into the Draft area? Or is there a way to get a larger draft space?
My Internet bandwidth is not the best but I don't believe that it is an Internet bandwidth problem. When I was watching the upload (including just before it generated the error), I see that the content is up
loading at around 50KB/sec. I would assume that if the error was related to some sort of a Internet connection timeout then I would see the transfer drop to 0KB/sec and then (after some timeout interval) generate the error. Since this does not happen, I assume that the problem is likely something else. I assume there aren't any timeout settings for the Content Uploader that could be set somewhere to compensate for a poor Internet connection?
I don't suppose there is any other method of up
loading content besides the Content Uploader? Such as an FTP site or something...something that would allow resuming upload if it fails?
