thanosxanderian
thanosxanderian
Last Active: 7 Years Ago
Visits: 57
I created a simple character animation in iClone that looks like this: However, when I export this character using 3dxchange to Unity an preview animation, the fingers of the character are distorted. Here is how it looks in Unity: As you can see in the above picture, the fingers of the character, especially the thumb, index and middle finger, are not the same to those in the iClone. How can I solve this issue? What are the possible causes? Thanks in advance.
7 Years Ago by
thanosxanderian
Snarp Farkle
Snarp Farkle
Visits: 3.6K
I'd be interested in the answer for this as well, I'm still a ways off from my iClone to Unity workflow but gathering all the info I can to help elevate problems in advance.
vidi
Posts: 10.8K,
Visits: 40.2K
look in the unity quality setting if blend weights is set to 4 bones
thanosxanderian
thanosxanderian
Visits: 57
vidi (5/12/2017) look in the unity quality setting if blend weights is set to 4 bonesYes, it is set to 4. Should it be changed ?
vidi
Posts: 10.8K,
Visits: 40.2K
Yes, it is set to 4. Should it be changed ? No 4 is right I created a simple character animation if it is an animation , In the Unity screen it shows frame 0 maybe your right pose i on another frame ?
thanosxanderian
thanosxanderian
Visits: 57
I found that the problem was when I imported the character to Unity the rig setup I set was Humanoid. However, after changing it to Generic everything works fine. I initially made the rig setup Humanoid by following iClone tutorials online. Apparently, that doesn't seem to work, at least in my case. '
uchey.mioneshy
uchey.mioneshy
Last Active: 6 Years Ago
Visits: 10
Hi! It works for me! I can't say any word for this. After a week try to change anything ( including animations>mask and transform, reimport 3d models, etc) I changed to generic back. Thanks! thanosxanderian (5/16/2017) I found that the problem was when I imported the character to Unity the rig setup I set was Humanoid. However, after changing it to Generic everything works fine. I initially made the rig setup Humanoid by following iClone tutorials online. Apparently, that doesn't seem to work, at least in my case. '
