iClone project won't render with Popvideo Plane...
Posted By Labape 8 Years Ago
Labape
Labape
Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)
Last Active: 7 Years Ago
Posts: 23, Visits: 85
Hey, I have kind of a weird issue I'm wondering if anyone has any advice.  I have a project I have created in iClone 6, that features a Plane with a transparent image (1 frame video) I rendered in PopVideo and imported.  The scene is pretty simple, 1000 frames, a 2d Background, 3 props, 3 Motion Paths, and the Plane with the Popvideo on it.  No lighting, no particle effetcs, etc.
When I attempt to render the final video, the software just hangs on frame 0 and will not render.  If I click on the software durring this process it crashes.
If I go back into my project and remove that Plane with the Pop Video, it renders quick and easy.  If I put that plane back in, same result every time.
Anyone have any thoughts or advice o n why that Pop Video plane would keep my project from rendering?
I'm running Win7 64 on a i7 processor with 16gb of Ram and a GTX 1050 2GB video card. Rendering the Video to a non-system 7200rpm HDD If any of that info helps.
Threaded View
Threaded View
Forum Post iClone project won't render with Popvideo Plane... By Labape ( 8 Years Ago )
Forum Post Don't know but I do know how I'd troubleshoot. First I would load up... By Kelleytoons ( 8 Years Ago )
Forum Post So, this is actually my first pop video... I've only had my software... By Labape ( 8 Years Ago )
Forum Post Let me know -- I just bought PopVideo today after experimenting with... By Kelleytoons ( 8 Years Ago )
Forum Post Ok, I tried to create a surface with the Popvideo in a new project...... By Labape ( 8 Years Ago )
Forum Post Certainly seems that way. What are you using to create your PopVideo... By Kelleytoons ( 8 Years Ago )
Forum Post Oh, and be sure you have the latest iClone version (I think for 6 is... By Kelleytoons ( 8 Years Ago )
Forum Post Well, the Original file was a still image that I wanted to make the... By Labape ( 8 Years Ago )
Forum Post Yeah, sounds like it *should* work (but if you want to post that PNG... By Kelleytoons ( 8 Years Ago )
Forum Post Oh, sorry, cross-posted. So you're not using these as a billboard?... By Kelleytoons ( 8 Years Ago )
Forum Post [quote][b]Kelleytoons (5/3/2017)[/b][hr]Oh, sorry, cross-posted. So... By Labape ( 8 Years Ago )
Forum Post Given the testing I have done, I'm wondering now if I am doing... By Labape ( 8 Years Ago )
Forum Post Nope. Deleted the Plane and replaced it with a Billboard. Same issue... By Labape ( 8 Years Ago )
Forum Post Well, that worked for me so I'm kinda stumped. You might want to open... By Kelleytoons ( 8 Years Ago )
Forum Post Thanks for all your suggestions! By Labape ( 8 Years Ago )
Forum Post Well, I opened a case with Support... the response I got was basically... By Labape ( 8 Years Ago )
Forum Post "Why are you trying to do this?" Do what? Are they puzzled because... By Kelleytoons ( 8 Years Ago )
Forum Post Yes they are puzzled why I would create a 1 frame video. My answer... By Labape ( 8 Years Ago )
Forum Post Have you tried r-click dragging the video file into iClone? That will... By Rampa ( 8 Years Ago )
Forum Post This this PopVideo file:... By Kelleytoons ( 8 Years Ago )
Forum Post [quote][b]Rampa (5/4/2017)[/b][hr]Have you tried r-click dragging the... By Labape ( 8 Years Ago )
Forum Post [quote][b]Labape (5/2/2017)[/b][hr]Hey, I have kind of a weird issue... By Pete_RL ( 8 Years Ago )
Forum Post Ive tried MP4 and AVI. I considered it could be a codec issue with... By Labape ( 8 Years Ago )
Forum Post a avi or wmv file will work if you need opacity use the color black... By Am7add9 ( 8 Years Ago )
Forum Post I'm a little confused (my normal state of mind): you DID get one to... By Kelleytoons ( 8 Years Ago )
Forum Post [quote][b]Kelleytoons (5/5/2017)[/b][hr]I'm a little confused (my... By Labape ( 8 Years Ago )
Forum Post The file I sent you was already a PopVideo so you shouldn't have had... By Kelleytoons ( 8 Years Ago )
Forum Post I updated my klite codec pack yesterday. Same results. By Labape ( 8 Years Ago )
Forum Post So just for the heck of it, I took my image, Imported it into Sony... By Labape ( 8 Years Ago )
