CrazyTalk Animator 3.1 Known Issues
Posted By Ola(RL) 9 Years Ago
vepop
vepop
Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)Distinguished Member (6.0K reputation)
Posts: 1.0K, Visits: 9.9K
Watch this to get a better understanding of how it works:-
https://forum.reallusion.com/uploads/images/9331d0a4-6a4b-4e86-9f88-963f.jpg
YouTube Tutorials Here
Posts: 23.1K, Visits: 36.6K
samaay.nasto (1/27/2020)
I have done my rigging but when i tried to make an animation in crazy talk it seems broken legs and unusual .can you please help me out
Hi...
Do make sure that each body part is overlapping so that bone nub goes through both parts as if you were pinning them together. The best way to do this is to round off the ends of each part. For example in the image below you will see the top of the arm is rounded off. This then overlaps the shoulder with the bone nub (the red circle) pinning the two parts together. This will stop them from coming apart.
https://forum.reallusion.com/uploads/images/1702e545-5659-4ba6-a73c-4e3d.png
https://forum.reallusion.com/uploads/images/80100bbf-d983-4bee-af55-0ea4.png
samaay.nasto
samaay.nasto
Last Active: 6 Years Ago
Posts: 1, Visits: 10
parisgranville
parisgranville
Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)Veteran Member (676 reputation)
Posts: 35, Visits: 283
Thanks, I got it to work. Character looks great now.
parisgranville
parisgranville
I think this is what is going on. But I'm too much of a newbie to understand it. Will you say more?
AriToons
AriToons
New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)New Member (58 reputation)
Posts: 9, Visits: 364
Thanks
kylelee
kylelee
Posts: 462, Visits: 4.2K
Hi,
I guess that your character could not double bind the left-hand and the left forearm.
Please check bone the left-hand and the left forearm.
I think that this issue has two situations.
1.) The sprite position incorrect in compose mode.
https://forum.reallusion.com/uploads/images/effdb244-0046-4677-af59-db68.png
2.) The bone does not have rigged double bind two sprites.
https://forum.reallusion.com/uploads/images/cf2e3373-cecd-4d7c-bdb1-1807.png
https://forum.reallusion.com/uploads/images/224c485b-859e-46fb-b325-c5eb.png
parisgranville
parisgranville
Hello, Kyle.
It looks like the problem is that the original character doesn't have straight arms. Do you know a way that I can rig it with bent arms.
https://forum.reallusion.com/uploads/images/406a0b33-04c7-43f8-8791-7328.png
kylelee
kylelee
parisgranville (4/15/2017)
I set up a G3 character in photoshop, but the left hand floats widely during animation. The bones are at the base of the hand and the hand nub is at the longest point of the hand. The other hand does not do this. Any ideas
Hi, Could you try to adjust sprite via Transform Sprite mode in Composer Mode?
This issue could be incorrect location of the element, you can check your element via Spirit Editor in Composer Mode.
If it still happened, please attached the screenshot, I will try to solve your issue.
kylelee
kylelee
ElAriel (4/14/2017)
Hi. I see two issues. When I import a G3 character to the scene, the eyes disappear. Also collapsed the software and closed.
Bye.
Hello, I want to reply your issues.
1.) I also have happened the eyes disappear issue, but this issue has workaround when I replace the character via the same one.
=> You can refer this issue: https://www.reallusion.com/FeedBackTracker/Issue/Eyes-move-1-report-2-separate-cases
2.) About the crashed issue, you can report your situation to technical support.
https://reallusion.com/CustomerSupport/user/FAQList.aspx
