Miranda (RL) (1/17/2017)
Hi nadiak, this is Miranda from Reallusion. Sorry to hear that you have a bad feeling, and I can sort of understand. I believe that you did spend time in figuring out why, and the result is not what you expected. We are serious about every message we convey, so we did add some remarks under the related feature intro on the
Feature page. For example,
Thank you. I still think there needs to be more clarity...
After all of this circus the answer is this:
1) The CC Essentials situation still makes no sense, but it doesn't apply at all to what I am doing.
2) Everything I need to do can be done with Substance. I don't need the Character Creator RGB Maps. I can bake all of that into a Substance sbsar.
It's amazing that there was early foresight to jump on the Substance train and have deep integration, but not to clearly state how things work. It wasn't until I took the time to look at Substance today that I finally got it.
I am not an idiot. I am the .1% in a lot of different skills closely relating to the Reallusion product line. If I don't understand something, it is because it is not documented. I RTFM and search forums whenever possible. I can't know everything, and often with infrequently used skills of things I'm quite skilled at, like ZBrush, I have to spend a day refreshing my muscle memory on the keyboard. If the documentation is outright wrong, and the user base is small, it is not pretty. This is the case here.
The reason I am participating on the forums is not only for the good of others, but myself so I can find the answer down the road. It's amazing how often years later I will find my own answer somewhere to remind myself how to do something. There is almost not outside discussion of RA product outside of this forum. There is no stack exchange base, no ZBrush base, no blender base, no cg forums base except for general questions about what the products are. It's amazing that my opinion on matters is so universal on the outside comments I do see. I'm not going crazy, but these things do make me put my MAGA hat on when I go outside. (3 more days, praise be upon our lord, Pepe LeKek)
I don't have a lot of 3D animation experience. It's was too time consuming previously to do side projects on my own, and it's a nightmare in blender unless you need to do things never done before, which will always be hard. The software is great. It's very sad though I couldn't make use of CTA3, and that's why I'm grinding iClone. CTA3 is crippled by design with the sour idea that animators don't want to create their own characters and want to buy add on packs. Good luck making a custom 360 G3 character there on your own, and good luck as a newcomer even understanding what G3 means. There are a few comparisons, but you have to go deep digging. You won't find it with a cursory search.
Invest in better documentation and then raise the prices. People here have $120,000 art degrees and rake in $15 an hour at Starbucks. Make them pay by all means, but not like you are currently doing.
