Where did RGB Masking go in Character Creator 2.0?
Posted By GreedyPeopleSuck 8 Years Ago
3
GreedyPeopleSuck
GreedyPeopleSuck
Last Active: 6 Years Ago
Posts: 94, Visits: 357
Is it only possible to do an RGB mask via Substance Painter?
Or did I miss something that the stock clothes are different?
http://manual.reallusion.com/Character_Creator/ENU/1/15_Substance/Divisions_by_RGB.htm
This doesn't exist in CC 2.0 it seems.
eternityblue
eternityblue
Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)Distinguished Member (10.5K reputation)
Last Active: 8 Months Ago
Posts: 769, Visits: 2.7K
I dunno, it appears to work the same in 1.5 as 2.0 over here. To be clear though, you always have created your RGB mask elsewhere, whether it be Photoshop, Substance Painter, or whatever. Unless I'm missing something :) You just load an RBG mask in the Input Maps RGB slot, and to view it in diagnostic mode, you click Enable in the Diagnostic panel.
My system: i7 3770 Gtx1060 6GB
Delerna
Delerna
Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)Distinguished Member (8.5K reputation)
Posts: 1.5K, Visits: 14.8K
My understanding of the workflow for this is
Select the cloth you want to work on
In materials tab set the shader to Classic
Goto Appearance tab and enable the appearance editor
Now you have the RGB mask etc etc to texture you cloth
Once you have the cloth textured how you want disable the Appearance editor
Now you can go back to the material tab and select PBR as the shader type.
Now you can setup the PBR textures as desired
Edit
Hope I understood your question correctly
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
Delerna
Delerna
Hmmmmm.....Actually I just tried it out again. No the RGB mask is there with shader type set to PBR so forget what I just said.
I don't remember where I got that idea of doing the texturing first and then doing the PBR from.
I thought I also couldn't find the RGB mask etc and that's why I thought that way.
GreedyPeopleSuck
GreedyPeopleSuck
eternityblue (1/15/2017)
[quote]
I dunno, it appears to work the same in 1.5 as 2.0 over here. To be clear though, you always have created your RGB mask elsewhere, whether it be Photoshop, Substance Painter, or whatever. Unless I'm missing something Smile You just load an RBG mask in the Input Maps RGB slot, and to view it in diagnostic mode, you click Enable in the Diagnostic panel.
It's not in CC 2.0 for the default assets at least, are you sure? There is no RGB slot as far as I can find. :-/ I followed the CC video turorial to it, and it just doesn't exist as a slot. Please reference my CC screen, and the documentation screenshot with the RGB slot.
https://forum.reallusion.com/uploads/images/60f67a3f-3756-4f3b-822d-f4d2.png
https://forum.reallusion.com/uploads/images/73c84b2d-4939-4cc4-8fed-0240.png
https://forum.reallusion.com/uploads/images/d18dc75e-2d09-443b-b3a4-519b.jpg
eternityblue
eternityblue
Yeah, I see what you are doing, don't dig so deep into that hierarchy, go to the top level of the Jeans, you'll (hopefully) see all the controls, including the input maps and diagnostics.  That said, I still see the input maps for all the clothes, including the jeans, at that level, so that may still be an issue, I dunno. Maybe it is your install?
GreedyPeopleSuck
GreedyPeopleSuck
I can't find it for the life of me. I am learning substance now, it's a nice format, but I'm losing my mind trying to figure out if I'm losing my mind. All of the fabrics show up, but not where to import the RGB map itself.
If you can confirm it's in 2.0  for sure, that would be great.
https://forum.reallusion.com/uploads/images/4e7f9c27-e765-452e-89ff-9119.png
https://forum.reallusion.com/uploads/images/bc2fd397-52dd-42a4-ab05-3ba2.png
eternityblue
eternityblue
Yep, same beta version.
Last Active: 4 days ago
Posts: 8.2K, Visits: 62.6K
Nadiak, I think you need to move your installed content over from CC1.5. You only get the input maps when the "Essential" packs are installed.
The paths to copy should be in the original CC2 post from RL.
Delerna
Delerna
rampa (1/15/2017)
aha, now I see why I get them now. I was checking the RGB mask when I got CC 2 but just before I installed the essential pack into CC2.
Gee wiz. All this time I was thinking along the workflow I mentioned when in actual fact it was  installing the essentials pack. I had forgotten that requirement.
3
