hj
Posts: 3.5K,
Visits: 18.7K
Es hallo Tesira
wo hast du die Piratin her, bei mir waren nur 4 Grundfiguren bei der Beta. Ansosten bist du ja eine fleißige Testerin. Ich habe mich bisher mit Tutoriasl zu CAT 3 beschäftigt und bin jetzt auch zum Beta-Test übergeschwenkt und muss erstmal mich duch die ganzen Posts wühlen. beste Grüße hj
Fehler gehören zum Leben. Was zählt, ist, wie man auf Fehler reagiert Niki Giovanni
Tesira
Tesira
Posts: 1.3K,
Visits: 2.4K
hi hj, well I have buyed iClone7 already and with this is come also the Pirate Lady. Finally I have learned, how I can make a substance with textures, which I can dynamically load in CC. And now I really would like to see them in iClone 7. It really is great fun. :) Have a nice day Tesira
Tesira
Tesira
Posts: 1.3K,
Visits: 2.4K
I have installed the Essentials export version in CC Beta 2.0. But if I try, to export a character as fbx, I get the message, that I need an export licence.
Tesira
Tesira
Posts: 1.3K,
Visits: 2.4K
Meantime I have seen, that I have the same problems with the export of the Essential Character also in CC1.5 The good message is, if I use the substances, which I have made in the Substance Designer, I have no problems inside of CC2.0. And here 2 more examples: Have a nice day Tesira
hj
Posts: 3.5K,
Visits: 18.7K
hi t did tested a liitle bit too If it works the Substance material in iClone, then also in the CC. Sometimes I have some problems with unwanted shine.
best hj
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Hi Tesira, can you check if you have logged into CC2.0? If yes, please provide me the file via Email. We will simulate the environment, and figure out why it happened. Thank you! Tesira (1/17/2017) I have installed the Essentials export version in CC Beta 2.0. But if I try, to export a character as fbx, I get the message, that I need an export licence.
Tesira
Tesira
Posts: 1.3K,
Visits: 2.4K
hi Miranda, where should I find the log file. Until now I haven't found one. But it seems, that other have also problems with the export licence. https://forum.reallusion.com/267226/Purchased-the-CC-Essential-Complete-Bundle-Export-license-and-Cant-export?PageIndex=1Thanks for your answer Tesira
luke (RL)
luke (RL)
Group: Power Developer
Visits: 5.6K
Hi, Tesira This problem should be solved, would you mind try it again ? thanks
Tesira
Tesira
Posts: 1.3K,
Visits: 2.4K
thanks waveact, yes it has worked now. Here we go: Have a nice day Tesira
Tesira
Tesira
Posts: 1.3K,
Visits: 2.4K
I have tested a bit more. The problem with the png Texture in the Roughness and Metall Channel seems to be solved. But in the Base and Bump Channel the png Textures until now don't work right. I get a clear picture after inverting and also the sliders don't work right, if I invert the texture. Here the Base Channel: after Inverting: Here the Bump Channel after Inverting the texture: Have a nice weekend Tesira
