Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Welcome to Character Creator 2.0 Beta - Work-In-Process Sharing Center
We look forward to all Beta Users sharing your learning experience and test renders through this Beta Program. Any video tutorials showing your findings on the best use of Character Creator 2.0 Beta are highly welcomed! iClone 6 PRO users and all iClone 7 pre-order users will get a full version of CC 2.0 when CC 2.0 officially launches. With the upcoming PBR support you will get a glimpse of the improved visual quality anticipated for iClone 7. For loyal iClone 6 users, we have you covered as well! All the materials are backwards compatible. PBR materials can automatically convert to their Classic equivalents, not only are they fully compatible, but also visually appealing. Keep in mind that for iClone 6 users, you will not be able to take advantage of the benefits of PBR rendering available in iClone 7. Click HERE to know more about Character Creator 2.0.
Here is a little test picture... 76% of original size (was 663x19) - Click to enlarge I applied a SUBSTANCE to both the dress and to the lady. Yay! :) In the process, I discovered the dress seems hard-coded to "Classic" shader, with no ability to use PBR. You can really see a difference between the appearance of the dress and the skin. (Sorry if that's a "known issue" that I already forgot about.) I'll look into that a bit more, and if it's not listed as a known issue I'll officially write it up. P.S. I also discovered a Substance that I cannot get to appear on the dress, though it displays fine in Substance Player. That also needs more investigation. UPDATE: I got "PBR" to work on the dress now.I have no idea why it wasn't working before but is now. Something to keep an eye on, I guess. (Still need to investigate that other Substance, too.) 76% of original size (was 663x19) - Click to enlarge
alemar
alemar
Visits: 10.1K
alemar
alemar
Visits: 10.1K
Hi guys just start to play around and having fun with PBR and IBL settings.PBR on skin give great control... 76% of original size (was 663x19) - Click to enlarge 76% of original size (was 663x19) - Click to enlarge 76% of original size (was 663x19) - Click to enlarge a little question: how can I insert lights? this default scene had 2 but I created another one that have just 1 ...
 ALEMAR GAMES MARKETPLACE STORE
alemar
alemar
Visits: 10.1K
Visits: 62.5K
Alemar. To get extra lights you can create atmospheres in iClone and put them in the atmosphere folder for CC 2. You also need to save a JPG so you can see a thumbnail in the CC atmosphere panel. Here I copied the atmospheres from iClone. There very old, so there are 4 spots and 4 points from back in the old days. ;) 76% of original size (was 663x19) - Click to enlarge
hirospot
hirospot
Visits: 5.9K
Lerning Experience of CC2.0 Beta and Bonus Pack:
This post is moved to Other Features & Enhancements:
Thank you. Hiro
alemar
alemar
Visits: 10.1K
Posts: 5.7K,
WarLord
WarLord
Last Active: 4 days ago
Visits: 3.6K
Final touches to the pipeline genie. The metal was easy enough to get the look I wanted and ended up settling on a porcelain type skin instead of fleshy. The FBX out of Studio Max imported into CC2 with no problems. 76% of original size (was 663x19) - Click to enlarge
