Lightwave Workflow
Posted By Miranda (RL) 10 Years Ago
Rated 4 stars based on 1 vote.
3
4
t2j
t2j
Posted 10 Years Ago
New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)
Posts: 5, Visits: 81
If you sure your mesh have weight map,when you sent it to Layout,you should check "Use Bone From Object" and choose Base Mesh's bone as your mesh's bone,then your mesh will be controlled by Base Mesh's bone.then yo can export the FBX to CC and can import it correctly.Wish this help.
hattori kun
hattori kun
Posted 10 Years Ago
Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)Distinguished Member (6.9K reputation)
Posts: 868, Visits: 4.1K
Miranda (RL) (10/1/2016)
Hi paulg625 and hattori kun,
The official version CC1.52 of fixing the issue will be available next week. :)
Thanks I see CC 1.52 now in downloads
borgman
borgman
Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)Veteran Member (666 reputation)
Posts: 21, Visits: 3.5K
Hi, I followed the methods shown in this thread,and exported this model from Character Creator 2 into Lightwave 3D (using most recent versions) with the following results.
I have managed to get this working fine previously with earlier versions of Character Creator.
Is anyone else having the same issues and can anyone help with this please?
Thank youhttps://forum.reallusion.com/uploads/images/5fe82a45-8a75-4a87-bd49-2546.jpg
paulg625
paulg625
Posts: 388, Visits: 1.4K
having same problem thought I had it but went back and tried to move the mesh and realize I changed the bone base
borgman
borgman
Hi paulg625,
Thanks for the reply.
How do you mean?
I tried exactly as you said,and the mesh still looks the same.
I've found that some of the bones are not active in Lightwave,and
hitting R corrects this,though it is a bit hit and miss/trial and error at the moment,
going through each bone individually.
There's gotta be an easier way.
It used to load fine into LW.
Appreciate your help.
borgman
borgman
oops.double post.
paulg625
paulg625
Spoke to soon still working on it.
borgman
borgman
I've tried importing several characters this evening,all with the same results.
I haven't been able to do any iClone CC/LW work in months, something's changed since I last did.
paulg625
paulg625
Yeah I hate having so much trouble using lightwave. I love it. But actually started trying to learn blender as a gap filler because of the problems. Didn't realize was having trouble bringing in characters. I was working on refining an animation using FBX and it worked most of the time but did have a similar problem after a while. Will keep working at this tomorrow. Let me know if you figure anything out. plus there are several users here who use lightwave we'll see if any of thrm have seen this, We might need to start a trouble ticket
borgman
borgman
Thanks Paul,I appreciate you looking into it.
Yes, I love Lightwave too, been using it for years. This is frustrating , cos it has worked perfectly well in the past.
I was able to create clothing/accessories in LW/ZBrush/3DCoat and send back into iClone/Character Creator successfully using the
workflow method that you and t2j show earlier in this post.(btw thanks for sharing)
I'll get back on this first thing in the morning,and let you know if I have any luck.
Cheers.
3
4
