OFFICIAL iClone 6.5 Issues Thread
Posted By Peter (RL) 10 Years Ago
3
4
5
6
7
24
BiggsTrek
BiggsTrek
Posted 10 Years Ago
Last Active: 6 Months Ago
Posts: 950, Visits: 12.3K
Not sure what the trigger is, but when working on a project and deleting a prop and then undoing it (I think this is the trigger) my screen gets filled with the iClone Watermark, even though everything is purchased.
I'll investigate further (different project, etc) and see if I can find a pattern, but wanted to give the Devs a heads up.
https://marketplace.reallusion.com/iclone/author/biggstrek
BiggsTrek
BiggsTrek
Posted 10 Years Ago
BiggsTrek (7/15/2016)
A quick update on this:  I loaded several of my current projects and almost all of them do the same thing.  I delete a prop/avatar/accessory (pretty much anything), then UNDO the delete and the watermark appears.
I then went to the Help menu and selected "Buy all trial contents" to see what it was complaining about, and in each of the projects it came up with this one, common accessory I had in each of them  (a little shoulder loop I got with a costume I bought a year or two ago - http://city.reallusion.com/ContentPreview.aspx?i=JIC69a78e1d61d0827f1)
I actually use two in the project and if I then delete ONE of them (doesn't matter which), the watermark vanishes even though one remains.  (That's not a solution, just a phenomenon I discovered.)
Very peculiar, and quite annoying bug you've got there.  Hope to see a fix soon (let me know if you need specific details beyond the above.)
Gentlegiant783
Gentlegiant783
Posted 10 Years Ago
Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)Veteran Member (826 reputation)
Posts: 82, Visits: 631
a majority of projects I've opend, and even knew ones started just to see what happens,  has this issue, just about everything I've manipulated, customized in some way is doing this,  but it can't seem to make up it's mind on what it's considering Trial Content, it' goes back and forth about it, I change a shirt, remove hair, Watermark disappears.
lol, I certainly have no intention of Re-purchasing anything, especially since I've had alot of this stuff for years without incident
BiggsTrek
BiggsTrek
Posted 10 Years Ago
Gentlegiant783 (7/15/2016)
That's not good, but good to know I'm not the only one suffering from this.
For me it's a deal breaker.  I cannot continue working on my movie with this bug.
REALLUSION, please advise us on what steps you are taking to rectify the issue!  Even a roll back to the previous version would be better than what we have now.
Thank you.
Posted 10 Years Ago
Posts: 5.7K, Visits: 26.5K
I'm getting the same watermarked scene when using delete/undo.
https://forum.reallusion.com/uploads/images/73eceed3-c126-4ac2-8276-9ccd.png
Posted 10 Years Ago
I've added this watermark problem to the Feedback Tracker here. It would help if others suffering from this problem would at least post a comment to reinforce it.
Postfrosch
Postfrosch
Posted 10 Years Ago
Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)
Posts: 6.9K, Visits: 18.4K
I habe the same error when i delete/undo = Watermarket
Greets from Germany
Postfrosch
BiggsTrek
BiggsTrek
Posted 10 Years Ago
wires (7/15/2016)
Have done so, thanks!
STENDL
STENDL
Posted 10 Years Ago
New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)New Member (7 reputation)
Last Active: 9 Years Ago
Posts: 2, Visits: 33
Hello
I would like to say i too am having problem with the alembic exporter not appearing after installing the 6.5 update.
Kind Regards
Dominic C
https://forum.reallusion.com/uploads/images/d1d23ce1-c5a8-406c-b12e-0784.png
brand468
brand468
Posted 10 Years Ago
Posts: 231, Visits: 7.8K
Hi, STENDL,
I had the same problem you after the update.
Solved the problem by uninstalling 3DXchange and then reinstall it again.
My computer: Intel i7-7700K 4.2Hhz 64Gb, Windows 10, GeForce GTX 1080 + GeForce GTX 1070, Phillips monitor 40" 4K  3840x2160 + 2x28"
3
4
5
6
7
24
