wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
yes that older driver fixed it and Octane 4 seems OK with it I might run into issues with the DAZ studio beta though, not tested yet Character Creator too now opens
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
Yes Octane 4 stopped working with the 30+ drivers until the last two Was a fuss similar to this here about the latest ones on the Otoy forum DAZ studio needs the later ones for Strand Hair AFAIK too but unsure know they stressed updating I may try and see but if Octane fails to see the driver as happened before will need to go back.
Last Active: 4 days ago
Visits: 62.6K
The most recent known working driver (I am using it) is the "Studio Driver 431.86" from Sept. 4th. If that is not an option for your card, then the 431.xx game driver is what you will need. Do Octane and Daz actually need 436.xx? For the trees, try deleting your temp file before you next start iClone 6.5. Also make sure you have updated to the latest iClone 6 version. Download from your account, or update with the Hub. Find this directory: C:\Users\your name\AppData\Local\Temp Delete this folder: iClone7Temp if it is there. Note that AppData is a hidden folder, and you may need to set "Show hidden files and folders" for Windows Also note that "your name" is your user name on your computer.
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
Yes I do have the latest driver which could be the issue but the earlier ones won't work with Octane 4 and the latest DAZ studio beta so I am really screwed if that's the reason. I cannot use Octane at all on my other computer but I can use iClone just a bit limited in scene size, well considerably limited but it works. So for now at least it might have to be limited to direct X9 and do my character creation on my other PC and my Speedtrees. I may try the older rougher ones I own from iC5. 980ti has no studio driver.
Last Active: 4 Months Ago
Posts: 5.7K,
Wendy, I have iClone 5, 6 and 7 all working without any issues on the system listed in my signature. You don't mention which driver you are running for your Graphic card, as Job suggested try the Nvidia game driver 431.60 or earlier and see if that makes any improvements.
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
I did think of the driver But That will open a whole new can of worms with DAZ studio and Carrara Octane render 4 incompatibility I might just have to be patient and see if that's the issue if Nvidia fixes it Or less likely given I use iClone6 not 7 Reallusion does. That is if that's the issue.
Posts: 15.8K,
Visits: 31.4K
iClone 6 runs on Windows 10. As to your DirectX problem: run dxdiag.exe and check the Display tab. Under Feature Levels it will state all DX levels supported. I have a laptop with DirectX 12, but 11 is listed as well. Very few applications are DirectX 12 only, so 11 should be supported. Another issue may be the drivers. The latest NVidia versions don't work. You need game-ready 431.60 or earlier.
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
speedtrees need direct X11 I have 12 actually well crap I am not happy I bought this PC because my other one had a hardware issue and I could not mount a graphics card yet THAT loads iC6 direct X11 and speed trees on the on board intel graphics, .............. just not many
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
ah direct X 9 it will run odd is my 980ti card from my other machine in this one
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
Does iClone 6 work on Windows 10? I just got a Windows 10 PC and it won't launch first go saw a specifications page now not at all neither does CC2 3DX6 does
