STENDL
STENDL
Last Active: 8 Years Ago
Visits: 33
I have tried that and it didn't work for me what version of 3DXchange is required, is there a patch for that also?
Posts: 15.8K,
Visits: 31.3K
There is a 3DXchange 6.5 patch. You will find it on your member page.
Posts: 15.8K,
Visits: 31.3K
I've encountered the watermark issue (although not as excessively as reported now) and reinstalling the offending content resolved it. So the problem is real, and it wouldn't do to have to reinstall all content.
BiggsTrek
BiggsTrek
Visits: 12.3K
animagic (7/15/2016) I've encountered the watermark issue (although not as excessively as reported now) and reinstalling the offending content resolved it. So the problem is real, and it wouldn't do to have to reinstall all content. Glad that worked for you! :) Unfortunately I tried it to no avail. :(
https://marketplace.reallusion.com/iclone/author/biggstrek
brand468
brand468
Visits: 7.8K
STENDL (7/15/2016) I have tried that and it didn't work for me what version of 3DXchange is required, is there a patch for that also?
I have 3DXchange pro pipeline, and first time i used the 1.5 patch. Then i uninstalled all and make a full install.
My computer: Intel i7-7700K 4.2Hhz 64Gb, Windows 10, GeForce GTX 1080 + GeForce GTX 1070, Phillips monitor 40" 4K 3840x2160 + 2x28"
borgman
borgman
Visits: 3.5K
Hi , I've noticed that the Perception Neuron Motion Capture beta plug-in is not working with the latest iClone build. I'm using the same settings as before,it's always worked perfectly fine previously. The Neuron Console panel Server Settings allows you to connect and disconnect , but the Preview and Record buttons on Neuron Console panel are frozen. So no motion is picked up from Axis Neuron.
gregsin
gregsin
Last Active: 5 days ago
Visits: 1.4K
Water marks all over the screen. It seems to have to do with the undo function. My first experience with this was this morning, I hit control z to undo the previous task and watermarks appeared all across the screen. It showed I had trial content in the scene. The supposed trial content was Appartions Christmas Carolers (which I had purchased with DA points) and a dried mud prop from the movies 4 pack (I had purchased from the content store. I couldn't find the two products and wanting to continue I repurchased them (hoping to get my points refunded) and the water marks went away. As the scene progressed I added a couple of custom Gen 5 Characters (custom chucks) to the scene and with the next use of control z the water marks reappeared showing the two chucks as trial content. It's getting frustrating. I would suggest holding off on the update until this is fixed.
Greg
mariusjensen01
mariusjensen01
Visits: 2.2K
After upgrading 3DXchange 6.4 PRO to 3DXchange 6.5. PRO program will not start at all. There comes up message that says: System error. It is claimed that a system file mfc120u.dll is missing. Why is that? - And what do I do? WIN 10 – Intel Core i7 - 8GB Ram- GeForceGTX 745
Tapani
Tapani
Visits: 943
rgreenidge
rgreenidge
Visits: 1.7K
I was working on a scene in a limo I purchased on iClone. I had to go check to see if I actually bought it. I wanted to place some avatars sitting in the limo, when I accidently changed the maximum clipping settings, instead of the minimum so I could see the avatars in the back of the limo through the backs of the front seat. When I put the maximum setting back to it's default 9999 value, the watermark filled the screen. No click to buy or any option could be found to remove or acknowledge it. I had to delete the limo, and the watermark disappeared. I put the same limo back in the scene and so far no watermarks.
Home built; ASRock X570 Pro 4, AMD Ryzen 9-5950X CPU, AMD RADEON RX6900XT, 16GB video card, 131GB of RAM.
