iClone4 - Issues Thread
Posted By Peter (RL) 17 Years Ago
Rated 3 stars based on 3 votes.
Posted 16 Years Ago
Posts: 23.1K, Visits: 36.6K
Thanks to everyone for the continued feedback in this thread. As always, all issues raised in this thread are passed to the iClone development team who will look into them.
However if you are having any problems that are seriously affecting your use of iClone then please contact Technical Support using the link below. They will work with you on a one to one basis to help resolve your problem quickly.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Posted 16 Years Ago
RiViT (10/14/2010)
iClone skin color change only works the first time. Once the skin color has been applied, no other iSkin can be selected or applied until I switch to another section of the Avatar editor (Persona, Hair, Upper Body, etc.) and then switch back to Skin. Then a second skin color change can be made, but if I want to change it a third time, the same switching procedure must be followed.
This happens with G3 characters Benny, Dylan and Jana from a 'cold start' of iClone. I didn't try it with any others.
My system:
Dell Precision 670 (3.2 gHz, dual Xeon)
4 gb RAM
nVidia GT220 PCIe (16x)
Windows XP (SP3)
Software:
iClone 4.3.1929.1 Pro
Hi Ron..
We have not been able to reproduce this issue. Changes can be made unlimited times.
If you are still experiencing this problem please contact Reallusion Support using the link below. They will try to help you resolve this.
Thanks.
Posted 16 Years Ago
cont (10/13/2010)
Hello i have a problem with one project which ask 1.7 gb of RAM and than application is crashing...Especially under windows 7 64 bit...However it works under xp service pack 3 32 bit, but ask same volume of memory and crash after i`m changing size of textures from 1024 to 2048..I have now 6 Gb of RAM and 2Gb of video memory on PAlit sonic GTX460...Of coarse project works if i`m using 512 on 512 size of texture, but i would like to use at least 1024...Please advise something for iclone 4.3 and such sort of machine( i use to have asus 260 gtx and 4 Gb and than i`ve change config and hope that 2 gb of video can help)!!???Cheers.
p.s. oh and Iclone says "out of memory" before crash and project has about 330 - 350 mb size
This issue has been reported but for one on one support, please use the link below. The Support Team will help you with this problem.
Thanks.
rontarrant
rontarrant
Posted 16 Years Ago
Last Active: 11 Years Ago
Posts: 231, Visits: 571
Peter (RL) (11/1/2010)
We have not been able to reproduce this issue. Changes can bemade unlimited times.
Thanks, Peter. I tried it again just now, and it's still doing the same thing. Very strange.
- Ron T.
mathahn
mathahn
Posted 16 Years Ago
Last Active: 13 Years Ago
Posts: 116, Visits: 333
I'm having two problems right now.
When I play back some of my scenes in editor mode, the sound is intermittent and not synched to the picture, which also jumps around.
When I export a scene in iClone 4, there is no sound. I have tried exporting in .avi, .wmv, and flash-- nothing.
Any help is appreciated. Thanks.
Magique
Magique
Posted 16 Years Ago
Posts: 315, Visits: 1.4K
I am having an issue with 3DXchange 4. I have a bunch of models that were originally done in 3DStudio Max and then converted to Lightwave. In Lightwave, I export the files as FBX and then import them into 3DXchange. For the most part, the models come in OK, but due to the original 3DStudio Max conversion, there are some normals that are flipped (quite a lot actually). In some cases I can select the offending object and put the editor into Flip Normals mode and do a simple Flip and they are fine. However, in other cases, the normals are half one way and half the other way and flipping just gives me the same result except that the half that were correct are now incorrect and the other half are correct.
Then I discovered this great button called Unify, which is supposed to take all the normals in the object and make them all the same. This would solve all my problems if it worked. However, so far I haven't seen anything at all happen no matter how many objects I've tried this function on. The program seems to be doing a ton of work though as the app even goes to a Not Responding state while performing this operation. Once it comes back, however, nothing has changed. Not one single thing. So I have had to resort to zooming in and individually flipping thousands of polygons. This is tedious and annoying.
Is there a fix coming for this feature?
I noticed that earlier versions of 3DXchange had a 2-sided feature that would render an object double-sided if flip or unify didn't work. This would definitely have solved my problem since Unify isn't working. Is this feature still in there somewhere or some sort of alternative?
Seeker769
Seeker769
Posted 16 Years Ago
Posts: 422, Visits: 1.1K
I don't know much about it, but have you tried using unify on just the problem areas?
Is this the 2-sided feature your looking for? It's at the bottom of the materials panel.
Hope this helps,
Chris
iClone training resources  https://forum.reallusion.com/Topic70771-161-1.aspx
Magique
Magique
Posted 16 Years Ago
Yes, thank you. I didn't realize this was the same thing. That will work for me. I still wish I knew why the unify normals doesn't work though.
Seeker769
Seeker769
Posted 16 Years Ago
Hi,
This might be of a little more help, open 3DX4 and press F1, now go to the sections I've circled.  This explains what to do if unify is not getting the desired results.
Hopefuly this will make things easier.
Happy modding,
Chris
rontarrant
rontarrant
Posted 16 Years Ago
I think I may have found an issue with rotation. Please forgive me if this has already been reported; I did a search of the forum and found nothing about it.
This happens with 3D Blocks and only when rotating around the Y axis.
To recreate this, drop any 3D Block into a new project, open the Timeline and the Transform track for the object.
Every twenty frames or so, change the Y axis by any amount between 30 and 60. Do this up to frame 100.
Now go back and look at the rotation values in the key frames you've set. They will not all remain at the values set... unless I'm the only one having this problem.
It seems the greater the difference between the rotation in one frame and the next, the more keys will have been changed by the time you get to frame 100.
EDIT:
The value for the Z rotation will also change sometimes, even though no value has been set.
EDIT 2010-11-07:
I tried this again yesterday after a clean reboot, just to be sure. No other software was running. Here is the test I performed:
- new Project
- drag in a ball
- open the timeline and click Transform to show rotation/scale/move keys
- set keys of these values at these frames:
- frame 20: Y rotation 20
- frame 40: Y rotation 40
- frame 60: Y rotation 60
- frame 80: Y rotation 80
- frame 100: Y rotation 100
Then I clicked on each of the keyframes I'd set. They were fine. Then I clicked on each again, and there were X and Z rotations of 180 set in frame 100 (which I hadn't set).
I then took out the X and Z rotations and set these keys:
- frame 20: Y rotation 30
- frame 40: Y rotation 60
- frame 60: Y rotation 90
- frame 80: Y rotation 120
- frame 100: Y rotation 150
Clicking back through the keys, I found this:
- frame 20: Y rotation 30 (OK)
- frame 40: Y rotation 60 (OK)
- frame 60: Y rotation 90 (OK)
- frame 80: Y rotation 60, X = 180, Z = 180 (RESET by iClone)
- frame 100: Y rotation 30, X = 180, Z = 180 (RESET by iClone)
Is no one else having this problem?
- Ron T.
