Paumanok West
Paumanok West
Posted 16 Years Ago
Last Active: 12 Years Ago
Posts: 2.5K,
Visits: 7.0K
teknology3d (8/8/2010) sorry for the silly question, but how I can copy and paste an object already in the scene? ThanksIf you loaded the object from the scene tree on the left hand of the screen, select the object in the tree again and click the load arrow (the one which points towards the scene). If the object is something you've created anew from merging various props, then add your new merged object to the list of custom props using the "+" button. Once it has been saved as a custom prop, use the same technique described above for loading another copy.
General Picture - animating now to life itself(tm) Member of Content Wizards
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
teknology3d (8/8/2010) sorry for the silly question, but how I can copy and paste an object already in the scene? ThanksAlso select the object and then select Move (W). Hold down the CTRL key and drag on the object that is selected. A copy of it will be added to your scene. :)
wjm48
wjm48
Posted 16 Years Ago
Last Active: 15 Years Ago
Visits: 17
shockwave_pulsar00 (8/8/2010)
steven.goeman1 (8/6/2010) I just installed patch 4.3 onto my Iclone 4.2 version.
Result is that some of the custom projects, created and working fine with Iclone 4.2,can no longerbe loaded anymore: The AP crashes and I have to restart Iclone.
Some other custom projects created by Iclone 4.2 still work fine.
Thanks.Guess it wasn't just me then. I hope this is fixed :ermm: Me too. This couldn't have happened at a worse time, I'm supposed to present what I've worked on tomorrow morning. Now every time I try to load my custom project it crashes. My mistake for blind patching, I should have known better. Please fix soon!
teknology3d
teknology3d
Posted 16 Years Ago
Visits: 211
Thank you guys!
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
At the present time it appears the problematic projects are those using Jam Band characters in them. For anyone encountering problems with iClone 4.2 projects not working in iClone 4.3, please contact Reallusion Support using the link below. Reallusion Support will work with users on a one to one basis to resolve these problems until a general patch is produced. http://www.reallusion.com/CustomerSupport/User/QForm.aspx Thanks.
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
UPDATE:For those who have been having difficulties with iClone 4.2 projects in iClone 4.3 then please download the patch again from your account and install again. A fix has been made to the patch that should resolve the problems that have been occuring. Thanks.
Akura
Akura
Posted 16 Years Ago
Last Active: 16 Years Ago
Visits: 9
what does serial invalid number mean. iclone will now close. cause it been working for over 4 days and suddenly when i installed new content that pops up. is something special i need to do or something?
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
Akura (8/28/2010) what does serial invalid number mean. iclone will now close. cause it been working for over 4 days and suddenly when i installed new content that pops up. is something special i need to do or something?If you are continuing to get this error message, please contact Reallusion Support who will be able to check your serial and give you help on resolving this issue. Please use the link below to request assistance. http://www.reallusion.com/CustomerSupport/User/QForm.aspx Thanks
wjm48
wjm48
Posted 16 Years Ago
Visits: 17
Hello again,
Thank you very much for the quick response last time, I was able to get my old stuff working.
Now, however, I am trying to do walk/run path animation but every time I use move walk_forward or run_forward I get the response Error adding 'Move' command. I've tried this with all my characters and the only ones who work are Trinity, Violet, and Kane. Trinity and Violet both use the same female animations and Kane used an entirely different set than any of the other characters. This leads me to believe this is something with the male animation set.
They used to work fine in the past but I haven't used path animations in a while so I'm not sure what patch caused them to stop working.
Any help would be appreciated.
Posted 16 Years Ago
Last Active: 3 Weeks Ago
Posts: 15.8K,
Visits: 31.4K
This may be related to some AML scripts that are not properly read by iClone 4.2 and later. If you select an animation from the menu, an AML script runs, but because iClone can't read it, you get an error. A fix has been promised... This is an issue with some packs as well. The following post provides a solution for that: https://forum.reallusion.com/FindPost53726.aspx. It may be worth a try.
