gizmo
gizmo
Posted 16 Years Ago
Last Active: 8 Years Ago
Visits: 1.6K
Thank you Mick.
:cool: gizmo
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
robar_20090922185155937 (1/7/2010) Thanks Peter, but why does it work OK in iclone3 and not iclone4? If I scale to 9999.9 in 3DEx the models are too small and because that is the iclone4 limit I can't make them any bigger. My main problem is that Poser models I converted and used in iclone3 are no good in iclone4 as they cannot be scaled up. I'll try scaling them up in Poser, and if that works I will have a huge task in remaking several hundred Poser props that I have in iclone3, which are now useless. Unless I throw out iclone4 and revert to iclone3, which means I've wasted 100's of dollars for nothing!
This is not a 3DExchange problem, it is an iclone4 bug and should be fixed.
Not impressed
RobarHi Robar, I have passed this to the Developing Team who will be looking into your complaint. Once I know anything more I will report it in this thread. Thanks for your feedback.
mark
Posts: 4.9K,
Visits: 16.7K
Was hoping my "Shadow" problem would be fixed with the 4.12 patch. The team seemed to understand the issue when I sent in a ticket on it. It was great to get a quick response but I don't guess it's a priority or it's a very big problem to get fix or it's my weird system. It's pretty much a "deal-killer" for me though. I upgraded to a decent INVIDA GeForce with a gig of memory to help with other shadow issues but this one is bad news for me. I'm real bummed. mp
ericsencer
ericsencer
Posted 16 Years Ago
Last Active: 15 Years Ago
Visits: 21
When I try to freeze an image layer by highlighting it and clicking "freeze' in the screen manager it does not prevent me from manipulating it further.
cimjd
cimjd
Posted 16 Years Ago
Last Active: 9 Years Ago
Visits: 400
I am having render quality problems with IClone4. I have been trying to render a virtual set with an avatar. My settings are 720 x 480 full frames uncompressed. After I import the file into my editing app and burn a dvd the quality of the virtual set is good but the avatar looks fuzzy and jagged. Is there anything any one can tell me to fix this? I am a newbie here so if I haven't provided enough info please let me know.
Posted 16 Years Ago
Last Active: 3 Weeks Ago
Posts: 15.8K,
Visits: 31.4K
I don't know if the following is a bug or a feature, but IC4 has some interesting rescaling behavior. I had noticed something funny earlier, but tonight it was very obvious. I was doing the tutorial to import SIMS props into iClone via 3DXchange. To get the size right, the instructions say to set the scale to 8,500. I loaded the loveseat in iClone and applied the texture. So far so good; I have a nice loveseat of the right size. I notice that In iClone the scaling factor is reported as 8,500, as expected. I then decided for some reason to play with the pivot setting and whoa! what happened to my couch? It becomes gigantic, in fact, 85 times so. Interestingly, by resetting the scale to 100%, the original size was restored... I call this a feature, as it is a way to bring the scaling factor of highly scaled up objects back to 100%, which would solve the problem of having a not enough scaling "room", as reported earlier in this thread.
Posted 16 Years Ago
Posts: 15.8K,
Visits: 31.4K
There is a version matrix on the product page that explains the differences between Standard and Pro: http://www.reallusion.com/iclone/iclone_matrix.asp. Only Pro has an advanced timeline with a multiple camera switch.
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
paul.chatman (1/21/2010)
No one has responded to my main thread, probably they think I'm a ranter; however, I'm angry for a reason. :angry: So I'll bring it up here since I deem it "an issue with iClone". I have iClone 4.12 Standard. I want to switch cameras in between takes. I'm trying to switch between Camera 1 and 2, but I can't get the little menu to pop up. This screenshot* shows the tutorialist clicking the key-frame and selecting the camera at the point on the timeline he wanted the camera angle to switch. But he is using Pro. I have Standard, not Pro. How can I switch cameras in between takes in iClone 4 Standard? This program would seem a complete waste of money, if I would have to export EVERY SINGLE INDIVIDUAL CAMERA ANGLE just to complete a shot. :crazy: * My gallery is locked. Use username: guest and password: 2010GUEST. They are both caSe SeNistIve Hi Paul, Please don't duplicate post. This makes it very confusing for those replying to keep track. While you may not get an immediate reply to your original thread, multiple posting just causes confusion. In this case I have replied to your other post HERE. Thanks.
Posted 16 Years Ago
Posts: 23.1K,
Visits: 36.6K
paul.chatman (1/22/2010)
Peter Edwards (1/21/2010)
Please don't duplicate post.I was actually on my way to delete the other post when I found this thread, but I had to go to work. While I would've deleted it via my Blackberry, I was listening to music and forgot - out of sight, out of mind. No problem. :)
paul.chatman
paul.chatman
Posted 16 Years Ago
Visits: 179
This regarding backstage under iC4.12 Std. I downloaded the free Rifle. It says it would accessible via Actor / Accessories...but I can't find it. I even looked in all the other categories.
I shut down iClone, and restarted and I still can't find my rifle. It's listed in the Backstage inventory as retrieved, though. Where is it? :(
