Snarp Farkle
Snarp Farkle
Visits: 3.6K
It also may have something to do with removing all animation from a CC avatar in iClone and freezing it with an 'other than standard pose' before sending it to CC and then saving it in CC as a custom avatar, to be used the as a morph slider, look at this example:
Snarp Farkle
Snarp Farkle
Visits: 3.6K
It is my best guess that this may have something to do with removing all animation from a CC avatar in iClone thus freezing the pose with an 'other than standard pose' before sending it to CC and then saving it in CC as a custom avatar, then used as a morph slider. My fix was just to save the head in iClone, then try to make another body as close to what I had done.
Snarp Farkle
Snarp Farkle
Visits: 3.6K
TheOldBuffer (5/11/2016) Just a thought !!! If the characters with sloppy tpose gets opened in 3dx does it then assume the correct tpose and could it then be saved into Iclone??For me the twisted Tpose showed in 3DX as well.
VirtualMedia
VirtualMedia
Visits: 19.0K
Just had the very same issue, It happened every time I applied a morph slider and tried to send it to IC. After the morph was removed and sent to IC it no longer had the arms pinned behind the back. Snarp Farkle, how did you save only the head in IC?
Virtual Media® / VTV® / The Virtual Entertainment Network... http://VTVLive.com
Last Active: 3 hours ago
Visits: 60.6K
Seeing that the arms are not actually distorted, but rotated wrong, I'd say it's a bone rotation morph that is being applied. CC does do bone morphs. That's how the arms change length, for instance. I would guess that something is "zeroing" the joints in the new rotation, thus offsetting the expected rotations during animation.
You'll see a very similar thing happen if you characterize an animal, like a horse. The joints for the legs are initially in a different rotation so that when a biped T-pose is applied, they rotate in a way that is incorrect for a biped.
VirtualMedia
VirtualMedia
Visits: 19.0K
rampa (7/11/2016) Seeing that the arms are not actually distorted, but rotated wrong, I'd say it's a bone rotation morph that is being applied. CC does do bone morphs. That's how the arms change length, for instance. I would guess that something is "zeroing" the joints in the new rotation, thus offsetting the expected rotations during animation.
You'll see a very similar thing happen if you characterize an animal, like a horse. The joints for the legs are initially in a different rotation so that when a biped T-pose is applied, they rotate in a way that is incorrect for a biped.Any thoughts on how to resolve this?
Visits: 60.6K
I tried to replicate it using CC 1.4.3, but could not. I'll try a few more ideas as I think of them. I can set a calibration pose and bake it, but it does not end up making that happen. I would encourage everyone to review their work-flow for maximum efficiency. One thing I've noticed is that occasionally people are sending CC characters back and forth between CC and iClone needlessly. If the character is already in CC, it makes more sense to just continue adjusting it in CC and send it to iClone again. Sending a character back to CC that just came from there is not only an extra step, but bakes the textures so they will be "reset" if edited in CC. There are couple reasons someone might need to though. If they added accessories in iClone that they want in CC, or they only have the iClone version of a character. I don't think you can adjust CC bones in 3DX, so you may not be able to reset to a proper T-pose.
8 Years Ago by
rampa
Visits: 60.6K
I would try re-saving the morph slider. I think you should apply it to the default source morph in the box that pops up.
Snarp Farkle
Snarp Farkle
Visits: 3.6K
VirtualMedia (7/11/2016) Just had the very same issue, It happened every time I applied a morph slider and tried to send it to IC. After the morph was removed and sent to IC it no longer had the arms pinned behind the back.
Snarp Farkle, how did you save only the head in IC?I saved the head in iClone, then applied it to a different body. Then I could send it to CC and make some changes. Also ToKoMotion gave a tip on separating the head and body morphs sliders HERE which I haven't tried to figure out yet.
VirtualMedia
VirtualMedia
Visits: 19.0K
Snarp Farkle, can't believe I didn't realize this
