dvande
dvande
Posted 10 Years Ago
Last Active: 9 Years Ago
Visits: 145
Added info. The displacement does show up in texture settings when I click on one of the planes (like it's supposed to), however, everything stays flat in the project no matter what settings I use in the texture settings (unlike the video).
Posted 10 Years Ago
Visits: 62.6K
Could this be a standard vs pro difference?
dvande
dvande
Posted 10 Years Ago
Visits: 145
I get the same results in both Directx 9 and 11. How about you?
Posted 10 Years Ago
Posts: 15.8K,
Visits: 31.4K
You are using DirectX 11? It wouldn't work in DirectX 9.
dvande
dvande
Posted 10 Years Ago
Visits: 145
iClone 6.41 / windows 8.1 x64 / Directx 9 and 11 When I load the Displacement Map projects, I see no displacement in the project, and displacement is missing in the Texture Settings. Doesn't look anything like the tutorial: https://www.youtube.com/watch?v=4MEWUUr7yUcAnyone else with this issue?
Alien Maniac
Alien Maniac
Posted 10 Years Ago
Visits: 2.1K
A solution I have been advised to do: 1. For a full screen background image/video: Open the project menu> tic Activate image > load a video or image. Wala
2. For a video to be added to a screen/TV or billboardSelect the object to be added to > open the materials menu>select diffuse>load your video/image. Wala
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
Cricky
Cricky
Posted 10 Years Ago
Posts: 2.8K,
Visits: 13.8K
A Physical Button has to be generated on the timeline manually because the timeline does NOT coincide with the Actual Panel Button that says the emitter is OFF. This is only for the first frame, as far as I can tell. You have to choose ON then OFF (either in the Panel or by R_Clicking on the Timeline) to make the particle desist from generating in the beginning. https://youtu.be/2AewKN-UCFg
SKYPE ID: rc.650
Alien Maniac
Alien Maniac
Posted 10 Years Ago
Visits: 2.1K
OK, I can drag from within IC Video and images. BUT Nothing from outside it will load into the screens. .
Alien Maniac
Alien Maniac
Posted 10 Years Ago
Visits: 2.1K
Hi Peter Thanks for the quick reply. Nothing will drag and drop in to the scenes or boards. I will try your suggestion and get back here to let you know asap....
Thanks
Posted 10 Years Ago
Posts: 23.1K,
Visits: 36.6K
Bray42 (3/7/2016) Anyone having problems adding a video to the 3dFX Virtual Studio boards? I have tried to drag and drop vids onto the boards/screens but no format works. MP4, WMV, MOV and AVI just will not work on the screens by drag and drop.
Is this a new issue in 6.4??? or Did we lose that ability completely now?
Any ideas? I am working on a paid advertisement project and really need this to work.....yesterday LOL Thanks in advance I have no trouble adding avi and wmv videos to the virtual studio screens or any other props when using drag and drop. Are you able to right click and drag video into your scene and add to a Plane, Billboard or Background? What about dragging an image onto the boards? To eliminate an issue with the videos themselves, are you able to drag in one of the sample videos found under Media > Video in Content Manager?
