Peter (RL) (3/9/2016)
Bellatrix (3/9/2016)
I've submitted bug report on 6.3, 6.4 and 6.41 crashes related to
Content Manager> Media> Material Lib
(crash style is freeze hang; subfolders will cause hang just select highlight; subfolders like Substance material/ Power tools no longer accessible)
Content Manager> Avatar> Custom
(custom characters can't double click to load, will cause instant-crash)
Also
Media > Custom is totally greyed out
Anyone with similar issue please kindly report.
Thanks...
There is often a misconception that if you have a problem it is a bug. This doesn't appear a bug. A bug will affect everyone or at least a large number of users. This appears a localised issue with your setup, or there is a compatibility issue with some content. We will however investigate to see what the problem could be.
Indeed I so agree.
IClone6 Pro Pipeline appears consistent but appearance could deceive.
And indeed, misconceptions abound in the land of unsolved inconsistency mysteries and imprecise information availability.
Good to know these two crash hang + instant-crash investigations are ongoing
(in spite of the theory that is a one-person localized issue)
Very very grateful for that!
:kiss::kiss::kiss::kiss::kiss:My system is kept clean and legit and all was well during 6.2 when I got onboard Pipeline suite, I hope that stability will return.
Not hard to imagine a pipeline workflow that crashes when saving a custom avatar or clicking on a subfolder is not feasible at all
On my part I'm continuing to earnestly and diligently investigate and precision-report to the tech dept (as I have been)
reporting it here in an issue thread is part of a broader continual verification exercise (just in case others have similar issue)
will continue to verify back and forth until a solution or concrete is reach
might post my hours and days of stringent elimination test results here as a demo of precision reporting
;)Will keep the issue reports uber-precise too (and won't use the b word I promise)
Regarding the Custom Media tab being greyed out. This is because there is no support for custom media via Content Manager. This has always been the case. Custom media should be loaded in manually or by using the right click and drag method where you will be presented with a number of options on how you wish to use the media.
Thanks for the useful info.
Evidently I'm not the only user confused by content manager imprecise information availability and behavioral inconsistency.
At least now users know iClone Pipeline Pro Content Manager Custom folders content do not behave/ create subfolders/ save/ load files consistently!
Should reduce expectation and brace for localized content manager oddity!
Cheers.
Now let me go and cheer myself up and go play with toonmaker eyes!
Hope it won't crash mysteriously when I save a custom one to the library....
>>> Indie Generalist modeler-rigger-animator <<< Hardware: AlienWare i7-HK 32G GTX1080 2T-SSDs BenqSW320 Wacom-Intuous 3Dconnexion ||| Software: IC6 Pipeline - CTA3 Pipeline - ATK2 - Indigo ||| Zbrush4R8. Blender 2.79. DazStudio 4.9. Carrara. Poser. Octane.
