Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
Agonos (12/21/2015) I have to find and load a file causing no problem and then, I can load and use the file that was crasche IC6Thanks for this tip! I had a project I worked on all evening yesterday and loading it would crash iClone...:crying: However, after loading another project it loaded fine... :)
Lawsuit Pending Records
Posted 11 Years Ago
Visits: 2.1K
Got this thing going on with flickering. I was working on this car and it started to flicker at random could be one wheel, body then a door, something in the interior. In this case it appears to be with reflection surfaces I had experienced similar a long time ago in 5.5 but they were skp projects and were not always set up the best and found double/overlapping mesh on a door etc and nothing to do with the reflection. (Reflection iClone library images not the Reflection slider activated) These are well crafted I have about 10 loaded and this is only one that seems to do it(So far). If I open anything ie the task manager over top it held it long enough to get some screen shots at it stops. Bit like a disco. Any ideas thanks. Drivers up to date All RL software up to date Not getting it with other vehicles so far but this just started suddenly and apart from vehicle model type they are identical builds and procedure. Reason why I ask because I have been getting similar with the CC eyes in Character Creator constant flickering, however once in iClone it does not appear to be happening at all. A few Daz characters have done similar with eye lashes in iClone 6
iC5 Pipeline, iC6 Pipeline, CTA2 Pipeline, CTA Pro, Crazy Talk, Facefilter, POP. LAWSUIT PENDING RECORDS - Label-Logos-Web Design-Artist Roster-Licensing - Flip type interactive magazine production
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
hj (12/21/2015)
I have updated an d Face-Key Funkltion- The bug is still there
i use function every time with creating pictures and i miss it since iclone 6.3 :sick::sick::sick:
hj As I mentioned before this is working fine for me so it doesn't look like a bug. I would advise uninstalling iClone and perform a clean install. Then check the problem again. If anyone else has this problem, please do let us know.
mark
Posts: 4.9K,
Visits: 16.7K
Thanks Peter will do. ;)
hj
Posts: 3.5K,
Visits: 18.7K
hj
Fehler gehören zum Leben. Was zählt, ist, wie man auf Fehler reagiert Niki Giovanni
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
hj (12/21/2015) What about the Face-Key Funkltion- The bug is stiil there
FACE-Key- Funktion does not work with any CC-Charcters, G3. G5, DAZ-Chacters and Mason too :blush::blush::blush::blush::blush:
hj This appears to be working fine in build 6.3.2421.1. Please update via LiveUpdate if you haven't already and see if it makes a difference. Do also ensure you are moving the mouse in the Face Key window itself and not the main preview window.
Agonos
Agonos
Posted 11 Years Ago
Last Active: 7 Years Ago
Posts: 1.1K,
Visits: 3.1K
Version 6.3.2421 Hi, I have projects that crash the software. And when I try to recover using the "restore" I have this on the screen as an image file "restore"
 If I select it, he loads an empty stage. I have to find and load a file causing no problem and then, I can load and use the file that was crasche IC6
hj
Posts: 3.5K,
Visits: 18.7K
There is a bug with the package 1. load from package  2 go back to normal Screen  after this try package again iClone crashed atonce Here the Windows-report: Name der fehlerhaften Anwendung: iClone.exe, Version: 6.2.2421.1, Zeitstempel: 0x567770cc Name des fehlerhaften Moduls: ICCreateFaceQt.dll, Version: 0.0.0.0, Zeitstempel: 0x5677704d Ausnahmecode: 0xc0000005 Fehleroffset: 0x00000000008bef1d ID des fehlerhaften Prozesses: 0x710 Startzeit der fehlerhaften Anwendung: 0x01d13c2151e2a922 Pfad der fehlerhaften Anwendung: C:\Program Files\Reallusion\iClone 6\Bin64\iClone.exe Pfad des fehlerhaften Moduls: C:\Program Files\Reallusion\iClone 6\Bin64\Plugin\ICCreateFaceQt.dll Quit bad hj
hj
Posts: 3.5K,
Visits: 18.7K
hj
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
mark (12/18/2015) Still don't see the "Shadow Bias" working for Spotlights in 6.3... at least on my system...
Hi Mark, Please can you send us your project so we double check the problem. Again you can use cloud services like Dropbox, OneDrive, Google Drive etc to make the download available to us. Then send the download link using the Support Form below. We will then get back to you when we have more information. Thanks. http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
