RobertoColombo
RobertoColombo
Posted 11 Years Ago
Posts: 1.6K,
Visits: 3.0K
Bigus (12/30/2015) No DOF in final rendered (pic/vid). Looks correct in viewport, but results - the whole scene in focus. Rendered same projects in previous versions, (6.x) it was all right. Can anyone confirm?
Hi, I just tried it and I cannot confirm the problem: in my case, the DOF works correctly. Roberto
Bigus
Bigus
Posted 11 Years Ago
Visits: 1.8K
No DOF in final rendered (pic/vid).Looks correct in viewport, but results - the whole scene in focus. Rendered same projects in previous versions, (6.x) it was all right.Can anyone confirm?
Embrace simplicity Reduce selfishness Have few desires (Lao Tzu)
dsebald
dsebald
Posted 11 Years Ago
Visits: 121
Wow, I'm really having problems with 6.3. Tried to render a short test scene that included a green screen video of myself from popVideo Converter, but the output video skips frames like crazy. (Example: http://aim-ed.com/experiments/rendertests/test9.html ) 6.2 had no problems with the same scene just days before ( http://aim-ed.com/experiments/rendertests/test2.html ). I'm also noticing that 6.3's interface seems really unresponsive. When I drag the window containing the program, the movement is really jerky. This is unlike any other program on my new expensive game machine. Even mouse movements are jerky when the program is active. Maybe I did something to cause these problems, but I sure don't know what it was. Any ideas or confirmation?
RobertoColombo
RobertoColombo
Posted 11 Years Ago
Posts: 1.6K,
Visits: 3.0K
Hi Mark,
do not see any of my issues ? Just to know... So far, I am forced to apply the animation clip by dragging them from the Windows explorer till the target avatar.... really awkward! Clearly a problem with the GUI SW coding.
Cheers
Roberto
EDITED: problem solved!! :-) The issue was due to a couple of non .iMotion files that, for some unknown reasons, existed in some of the motion packs. Probably iClone tried to read and resolve them, in order to populate the content window with teh various motion thumbnails and crashes because teh format of those file was completely different! If this is the case, RL should filter the file vs. the extension or at least put an header into them, so that the SW does not crash upon a different file but just ignore it.
mark
Posts: 4.9K,
Visits: 16.7K
Thanks - it never even occurred to me to look for an invisible button, but now that you mention it, I found it and can link camera to the Root again. :) Glad you found it...the force is still with us Obie! It's just invisible!!! :P:P:P
RobertoColombo
RobertoColombo
Posted 11 Years Ago
Posts: 1.6K,
Visits: 3.0K
Hi there,
I think I nailed down the problem: if I drag an animation clip over the avatar, then it is applied with no crash. But if I DOUBLE-CLICK the animation click (with the avatar selected), then iClone crashes. This happens in a deterministic way with every animation clip and avatar. Anybody experiencing the same ?
EDITED: unfortunately this latest patch did not create only this problem. Now, quite often when I click the Content window to select a folder containing some animation clips, iClone crashes. Noe, only in the case of animation clips: it works fine if i select avatars, props, etc. I can't imagine anything worst than this and I can't even imagine that is due to my system, considered that till before I installed this patch, iClone was super-stable. Really depressed and angry...
Roberto
EDITED AGAIN: problem solved!! :-) The issue was due to a couple of non .iMotion files that, for some unknown reasons, existed in some of the motion packs. Probably iClone tried to read and resolve them, in order to populate the content window with teh various motion thumbnails and crashes because teh format of those file was completely different! If this is the case, RL should filter the file vs. the extension or at least put an header into them, so that the SW does not crash upon a different file but just ignore it.
OnlyOneKenobi
OnlyOneKenobi
Posted 11 Years Ago
Last Active: 6 Years Ago
Visits: 588
mark (12/29/2015)
OnlyOneKenobi (12/29/2015) With the 6.3 update I can no longer link a camera to an iavatar's "root bone" meaning the camera cannot smoothly follow my actors anymore...Well it will link, for me, but I noticed on my system that the linking menu "button" is invisible, it's there, but it's invisible. If I hover the cursor over the area where the button should be it will become visible and I can bring up the link selection menu. So we need to check that possible issue out. ;) Thanks - it never even occurred to me to look for an invisible button, but now that you mention it, I found it and can link camera to the Root again. :)
RobertoColombo
RobertoColombo
Posted 11 Years Ago
Posts: 1.6K,
Visits: 3.0K
Hi guys,
thanks for the replies. On my system, after I updated, EVERY animation clip crashes iClone. Total disaster!!
I will try to revert back (I made a Windows restore point BEFORE the update) and retry again. Btw, did you installed directly the patch over the existing iClone or re-installed the whole SW ?
Roberto
EDITED. problem solved!! :-) The issue was due to a couple of non .iMotion files that, for some unknown reasons, existed in some of the motion packs. Probably iClone tried to read and resolve them, in order to populate the content window with teh various motion thumbnails and crashes because teh format of those file was completely different! If this is the case, RL should filter the file vs. the extension or at least put an header into them, so that the SW does not crash upon a different file but just ignore it.
mark
Posts: 4.9K,
Visits: 16.7K
Sorry Roberto, haven't be able to replicate the issue on my system ;)
nlprod1
nlprod1
Posted 11 Years Ago
Visits: 4.5K
Hi Roberto,
Followed your example steps and all worked out fine. No crashing at all. I'm running ic 6.3.2422.1 (latest patch).
