mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
I'm assuming that if you are using the 3DXchange method, then you are getting perfect 1-to1 mocap data into iClone for every bone, including the hands?
You can select the maya setup in 3dxchange , auto-retarget done!! but yes I have to reset the rotation bone to zero. When I said T-pose , means you have to make a t-pose when you mocap in Axis neuron and THIS t-pose is your reference.
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
Yesterday an auto-update of Iclone poped, it's 6.3.2422.1. Now all is working .
sterlingy
sterlingy
Posted 11 Years Ago
Last Active: 4 days ago
Visits: 714
mtakerkart (12/26/2015) Yesterday an auto-update of Iclone poped, it's 6.3.2422.1. Now all is working . All, as in hands fixed and everything? -Sterling
Stick with the flock, end up a lamb chop!
www.ShivooStudios.com
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
I can't answer for hands because I've an 11 Neurons kit, but now I've no iclone crash when broadcasting from Neuron Axis.
sterlingy
sterlingy
Posted 11 Years Ago
Visits: 714
mtakerkart (12/26/2015) I can't answer for hands because I've an 11 Neurons kit, but now I've no iclone crash when broadcasting from Neuron Axis.I saw that update and decided not to install it for fear that things would stop working for me. Had it been an update to the plugin, I would have done it in a heart beat. I wish they would have a log of changes for these patches, so we would know what to expect. -S
Firepro
Firepro
Posted 11 Years Ago
Last Active: 7 Years Ago
Visits: 246
mtakerkart (12/26/2015) Yesterday an auto-update of Iclone poped, it's 6.3.2422.1. Now all is working . Confirmed, new update fixed PN Plugin crash, tested with 3-neuron arm, still have to use Plug-In Menu. Thank you RL!
sterlingy
sterlingy
Posted 11 Years Ago
Visits: 714
I've installed the latest patch, and I'm still having trouble with the thumb. It would seem that the rotation on one axis is not functioning correctly. Also, and I think this is a Neuron issue, but when I put my fingers together, the appear to still be spread apart. Does this happen for others? -S
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
I suggest you to switch the sensor having trouble with upper arm for exemple to see if it's the sensor. If yes ,may you've an magnetic sensor issue. You can fix it with the Neuron doctor.Just follow the instructions. 7 of mine had trouble, Daniel from Neuron helped me to fix it with a Skype session.
sterlingy
sterlingy
Posted 11 Years Ago
Visits: 714
Is that for the thumb issue or the fact that I can't un-spread all of my fingers?
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K,
Visits: 29.2K
My suggestion was for the thumb issue. Did you try the Arm setup with only 11 sensor ? Just to see if you can spread your fingers with one hand?
