Technical Issues
Posted By Realtimer (RL) 11 Years Ago
Realtimer (RL)
Realtimer (RL)
Posted 11 Years Ago
Posts: 226, Visits: 3.0K
Do you have any issues with the Live Motion Capture System? If you do, then please post your issues in this thread.
NOTE: In order to streamline the solution process, we kindly ask that you be as detailed and specific with your issues as possible, so that our team can replicate the problem.
BEFORE YOU BEGIN - Make sure that you have first checked that your PC system has all the necessary system requirements, and tested your issues then, before reporting a bug. For more information on system requirements, go HERE.
https://forum.reallusion.com/uploads/images/2a917a32-2b0c-4a9f-adc7-d661.jpg
Threaded View
Threaded View
Forum Post Technical Issues By Realtimer (RL) ( 11 Years Ago )
Forum Post With Mirror Motion enabled, finger and hand bones are mixed up between... By ceesmailkajr ( 11 Years Ago )
Forum Post oops. see one thread up under subject Load Mocap Device Plug-in... By dallasvr ( 11 Years Ago )
Forum Post I cannot get Perception Neuron to work with iClone (I want to make it... By CyBoRgTy ( 11 Years Ago )
Forum Post I found what the problem was. I ran netstat -ab to see what ports... By CyBoRgTy ( 11 Years Ago )
Forum Post Actually for me, it does not make sense to change the Sentinel port... By CyBoRgTy ( 11 Years Ago )
Forum Post Hello CyBoRgTy, Currently there is no way to change the listening... By Eric (RL) ( 11 Years Ago )
Forum Post Thanks for the consideration. On a different problem, I have the 31... By CyBoRgTy ( 11 Years Ago )
Forum Post Dear all, I tested several setups in the Neuron-Settings. The... By Beat_CH ( 11 Years Ago )
Forum Post Just tried it on another machine with windows 10 installed instead of... By e1_scheer ( 11 Years Ago )
Forum Post Dear all, I started new with the Neuron and the iClone-plug-in in a... By Beat_CH ( 11 Years Ago )
Forum Post [quote][b]Beat_CH (12/17/2015)[/b][hr] The only issue is that the... By animagic ( 11 Years Ago )
Forum Post Hi, Every time i load in a G6 character and push the neuron mocap... By e1_scheer ( 11 Years Ago )
Forum Post [quote][b]e1_scheer (12/20/2015)[/b][hr]Hi, Every time i load in a G6... By animagic ( 11 Years Ago )
Forum Post Yes! I just started having this issue a few days ago, any luck as to... By Aysterix ( 10 Years Ago )
Forum Post Finally received my Neuron. A few things missing, but I have it... By sterlingy ( 11 Years Ago )
Forum Post Is it possible to roll back to a version of iclone 6 and the mocap... By e1_scheer ( 11 Years Ago )
Forum Post well I got the mocap suite today. I have the plug in, I have fallowed... By MnerosNaRa ( 11 Years Ago )
Forum Post [quote][b]e1_scheer (12/22/2015)[/b][hr] @sterling have you changed... By sterlingy ( 11 Years Ago )
Forum Post Hi, I used it with the following settings in neuron (using Win 7, and... By Beat_CH ( 11 Years Ago )
Forum Post BEAT_CH, I did as you suggested and started the plugin from the menu,... By sterlingy ( 11 Years Ago )
Forum Post Same problem here. Works perfectly with 6.2 but crash with 6.3 when... By mtakerkart ( 11 Years Ago )
Forum Post After a few days I was able to get it to work, I had to purge my comp... By MnerosNaRa ( 11 Years Ago )
Forum Post How well did your feet align to the floor plane? By sterlingy ( 11 Years Ago )
Forum Post Some times it's great, other times it sucks. In the case of this film... By MnerosNaRa ( 11 Years Ago )
Forum Post [quote][b]MnerosNaRa (12/24/2015)[/b][hr]After a few days I was able... By Firepro ( 11 Years Ago )
Forum Post [quote] Just wondering, other than doing an uninstall on the Kinect... By MnerosNaRa ( 11 Years Ago )
Forum Post Thanks to everyone posting their results! I hope you'll have some time... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (12/24/2015)[/b][hr]Thanks to everyone posting... By sterlingy ( 11 Years Ago )
Forum Post [quote][b]sterlingy (12/24/2015)[/b][hr][quote][b]animagic... By MnerosNaRa ( 11 Years Ago )
Forum Post [quote][b]MnerosNaRa (12/25/2015)[/b][hr][quote][b]sterlingy... By sterlingy ( 11 Years Ago )
Forum Post Today, I put the rig on myself for the first time. Previously, I had... By sterlingy ( 11 Years Ago )
Forum Post So close but no cigar. Got my new Perception Neuron suit, works okay... By Firepro ( 11 Years Ago )
Forum Post [quote][b]Firepro (12/25/2015)[/b][hr]So close but no cigar. Got my... By sterlingy ( 11 Years Ago )
Forum Post [quote][b]sterlingy (12/25/2015)[/b][hr][quote][b]Firepro... By Firepro ( 11 Years Ago )
Forum Post While the bugs in the plug-in get fixed I was wondering if I can still... By Firepro ( 11 Years Ago )
Forum Post [quote][b]Firepro (12/25/2015)[/b][hr]While the bugs in the plug-in... By sterlingy ( 11 Years Ago )
Forum Post FBX 2012 would be pretty good for 3DXchange. I believe that's the... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (12/25/2015)[/b][hr]FBX 2012 would be pretty good... By johnb4467 ( 10 Years Ago )
Forum Post It looks like it is indeed something to do with the capture plug-in,... By johnb4467 ( 10 Years Ago )
Forum Post [quote][b]johnb4467 (1/9/2016)[/b][hr]It looks like it is indeed... By sterlingy ( 10 Years Ago )
Forum Post [quote][b]sterlingy (1/9/2016)[/b][hr][quote][b]johnb4467... By johnb4467 ( 10 Years Ago )
Forum Post [quote][b]johnb4467 (1/10/2016)[/b][hr]When you mentioned "curl your... By sterlingy ( 10 Years Ago )
Forum Post [quote][b]Firepro (12/25/2015)[/b][hr]While the bugs in the plug-in... By MnerosNaRa ( 11 Years Ago )
Forum Post Because of the 6.3 bug , I use the bhv from Axis Neuron and retarget... By mtakerkart ( 11 Years Ago )
Forum Post [quote][b]mtakerkart (12/25/2015)[/b][hr]Because of the 6.3 bug , I... By sterlingy ( 11 Years Ago )
Forum Post [quote] I'm assuming that if you are using the 3DXchange method,... By mtakerkart ( 11 Years Ago )
Forum Post Yesterday an auto-update of Iclone poped, it's 6.3.2422.1. Now all is... By mtakerkart ( 11 Years Ago )
Forum Post [quote][b]mtakerkart (12/26/2015)[/b][hr]Yesterday an auto-update of... By sterlingy ( 11 Years Ago )
Forum Post I can't answer for hands because I've an 11 Neurons kit, but now I've... By mtakerkart ( 11 Years Ago )
Forum Post [quote][b]mtakerkart (12/26/2015)[/b][hr]I can't answer for hands... By sterlingy ( 11 Years Ago )
Forum Post [quote][b]mtakerkart (12/26/2015)[/b][hr]Yesterday an auto-update of... By Firepro ( 11 Years Ago )
Forum Post I've installed the latest patch, and I'm still having trouble with the... By sterlingy ( 11 Years Ago )
Forum Post I suggest you to switch the sensor having trouble with upper arm for... By mtakerkart ( 11 Years Ago )
Forum Post Is that for the thumb issue or the fact that I can't un-spread all of... By sterlingy ( 11 Years Ago )
Forum Post [quote][b]sterlingy (12/26/2015)[/b][hr] Also, and I think this is a... By johnb4467 ( 10 Years Ago )
Forum Post My suggestion was for the thumb issue. Did you try the Arm setup with... By mtakerkart ( 11 Years Ago )
Forum Post [quote][b]mtakerkart (12/26/2015)[/b][hr]My suggestion was for the... By sterlingy ( 11 Years Ago )
Forum Post Hi all, That was quick, if the broadcasting issue is now fixed. I... By e1_scheer ( 11 Years Ago )
Forum Post [quote][b]e1_scheer (12/28/2015)[/b][hr] As for the thumb, I'm having... By johnb4467 ( 10 Years Ago )
Forum Post I just can't install it on win10 with iClone 6. It work's on my laptop... By fertigo ( 10 Years Ago )
Forum Post @Fertigo It's the Maya preset. Before clicking on convert button ,... By mtakerkart ( 10 Years Ago )
Forum Post [quote][b]mtakerkart (1/22/2016)[/b][hr]@Fertigo It's the Maya... By johnb4467 ( 10 Years Ago )
Forum Post Watching the video on Youtube " Iclone Live Mocap with Perception... By gosolo2 ( 10 Years Ago )
Forum Post [quote][b]gosolo2 (1/24/2016)[/b][hr]They say I could download The... By sterlingy ( 10 Years Ago )
Forum Post [quote][b]gosolo2 (1/24/2016)[/b][hr]Watching the video on Youtube "... By johnb4467 ( 10 Years Ago )
Forum Post Hey folks, I am now forced to use 3DXchange to bring my data from... By sterlingy ( 10 Years Ago )
Forum Post May if you click on the " Align to ground" before converting it... By mtakerkart ( 10 Years Ago )
Forum Post So I seem to have worked out a few things, but when the performer's... By sterlingy ( 10 Years Ago )
Forum Post I too can not get my 32 neuron suite to work with I-clone. I am... By shmedia ( 10 Years Ago )
Forum Post [quote][b]shmedia (2/28/2016)[/b][hr]I too can not get my 32 neuron... By sterlingy ( 10 Years Ago )
Forum Post Hi, Thanks for your response. It took some doing because during my... By shmedia ( 10 Years Ago )
Forum Post I'm glad I could provide some help. I further advise that you ZERO... By sterlingy ( 10 Years Ago )
Forum Post Thanks everyone for reporting their progress and issues. I'm still an... By animagic ( 10 Years Ago )
Forum Post [quote][b]david.janko (3/1/2016)[/b][hr] I select Connect from within... By luke (RL) ( 10 Years Ago )
Forum Post axis neuron version is 3.6.32.3903 this is the pro version axis neuron... By david.janko ( 10 Years Ago )
Forum Post it' work's fine with the standard version not the pro. just crazy By david.janko ( 10 Years Ago )
Forum Post Hi ! To make the new AXIS Pro version work again with iClone you... By tycho6 ( 10 Years Ago )
Forum Post I select Connect from within the Plugin menu -> Neuron Mocap... By david.janko ( 10 Years Ago )
Forum Post [quote][b]david.janko (3/1/2016)[/b][hr] I select Connect from within... By sterlingy ( 10 Years Ago )
Forum Post In the early days of this plugin, I remember issues with the thumb. It... By sterlingy ( 10 Years Ago )
Forum Post Yes, we will solve this issue at official launch. By luke (RL) ( 10 Years Ago )
Forum Post I have iClone 6.4 and am working on a project. I make a path for my... By DebMark Productions ( 10 Years Ago )
Forum Post hi, here is my neuron's settings ... and my iclone 6.42 with... By davood.kharmanzar ( 10 Years Ago )
Forum Post You need to enable the "use old header" checkbox should be work By luke (RL) ( 10 Years Ago )
Forum Post thanks a lot ;) By davood.kharmanzar ( 10 Years Ago )
Forum Post seems that the neuron plugin needs an UI update for iclone 6.5 ...... By davood.kharmanzar ( 10 Years Ago )
Forum Post I'm using the iClone 6.5 trial and I've been trying to get the... By nickcmcclure ( 10 Years Ago )
Forum Post [quote][b]nickcmcclure (8/2/2016)[/b][hr]I'm using the iClone 6.5... By tycho6 ( 10 Years Ago )
Forum Post Hi folks, We'll be releasing official version of iClone mocap plug-in... By Melanie (RL) ( 10 Years Ago )
Forum Post Hello folks! I have a question. I am expecting my Neuron suite to be... By Mr. Perfect ( 10 Years Ago )
Forum Post [quote][b]Mr. Perfect (8/16/2016)[/b][hr]Hello folks! I have a... By tycho6 ( 10 Years Ago )
Forum Post [quote][b]info_54_54 (8/16/2016)[/b][hr][quote][b]Mr. Perfect... By Mr. Perfect ( 10 Years Ago )
Forum Post [quote][b]Mr. Perfect (8/16/2016)[/b][hr][quote][b]info_54_54... By tycho6 ( 10 Years Ago )
Forum Post [quote][b]info_54_54 (8/16/2016)[/b][hr] Hi ! Having only SSD... By Mr. Perfect ( 10 Years Ago )
Forum Post [/quote] Funny! I just came back with this app on my phone and you are... By tycho6 ( 10 Years Ago )
Forum Post [quote][b]info_54_54 (8/16/2016)[/b][hr] :-) That's really fine.... By Mr. Perfect ( 10 Years Ago )
Forum Post BUMMER! I am so frustrated! I just got my Suite delivered after only 6... By Mr. Perfect ( 10 Years Ago )
Forum Post Jeeeezzz! How confusing was that? I found the gear hidden in the... By Mr. Perfect ( 10 Years Ago )
