Technical Issues
Posted By Realtimer (RL) 11 Years Ago
e1_scheer
e1_scheer
Posted 11 Years Ago
Posts: 120, Visits: 1.1K
Hi,
Every time i load in a G6 character and push the neuron mocap plugin Iclone crashes with the following
error message :; "iclone 6ap has stopped working"
 Problem Event Name:    APPCRASH
  Application Name:    iClone.exe
  Application Version:    6.2.2416.1
  Application Timestamp:    567162d8
  Fault Module Name:    ICCreateFaceQt.dll
  Fault Module Version:    0.0.0.0
  Fault Module Timestamp:    5671620c
  Exception Code:    c0000005
  Exception Offset:    00000000008be79d
  OS Version:    6.1.7601.2.1.0.768.3
  Locale ID:    2060
  Additional Information 1:    8e82
  Additional Information 2:    8e82304a30d732412bc6937cd552553c
  Additional Information 3:    3076
  Additional Information 4:    307682633391d8bcf916f49b6e1c9994
Any help would be welcome,
e1
Beat_CH
Beat_CH
Posted 11 Years Ago
New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)New Member (12 reputation)
Last Active: 10 Years Ago
Posts: 5, Visits: 39
Dear all,
I tested several setups in the Neuron-Settings.
The following settings are working fine:
Rotation: YXZ (figure move identical as in the neuron., Other settings: Orientation of the figure changes.)
Displacement: on,  (if off. figure moves at the same spot)
Reference: off  (if on: figure collapses)
So far it works fine with the data-recording, when starting the Plug-in via "Pull-Down-Menu": Plugins.
Regards
Beat
e1_scheer
e1_scheer
Posted 11 Years Ago
Just tried it on another machine with windows 10 installed instead of win 7,
but I get the same crash.  Just wondering, does the neuron mocap plugin
actually work with the latest iclone trial version or do you need a specific
iclone version?
e1
Posted 11 Years Ago
Posts: 15.8K, Visits: 31.4K
e1_scheer (12/20/2015)
Hi,
<snip>
  <snip>
e1
 ICCreateFaceQt.dll is a new DLL that has been added in the 6.3 release to allow creating a face from a photo. I have had a few crashes as well with the same error. I'm not using Neuron, so it seems that the problem is broader. I hope we will see a fix soon!
sterlingy
sterlingy
Posted 11 Years Ago
Last Active: Today @ 5:12 AM
Posts: 206, Visits: 714
Finally received my Neuron. A few things missing, but I have it working with the Axis software.
When I connect with the iClone plugin, I'm left with a message:
https://forum.reallusion.com/uploads/images/efd58853-5eb7-4359-ba96-1828.png
-Sterling
Stick with the flock, end up a lamb chop!
www.ShivooStudios.com
e1_scheer
e1_scheer
Posted 11 Years Ago
Is it possible to roll back to a version of iclone 6 and the mocap plugin that work?
Can you download archived installs from the reallusion website?
@sterling
have you changed your axis neuron settings to broadcast the bvh data
that fixed your error message for me
e1
MnerosNaRa
MnerosNaRa
Posted 11 Years Ago
Veteran Member (795 reputation)Veteran Member (795 reputation)Veteran Member (795 reputation)Veteran Member (795 reputation)Veteran Member (795 reputation)Veteran Member (795 reputation)Veteran Member (795 reputation)Veteran Member (795 reputation)Veteran Member (795 reputation)
Posts: 99, Visits: 1.5K
well I got the mocap suite today. I have the plug in, I have fallowed the step by step instructions. but when i go to open the plug in I crash, I dont even get an error message. so I'm not sure how/or where to go from here, I hope there is an update in the future soon. I have all the RL updates, I'm on win 10. PN works great on its own.
sterlingy
sterlingy
Posted 11 Years Ago
e1_scheer (12/22/2015)
@sterling
e1
Yes, I had changed that setting before I tried to use iClone. I also closed and restarted everything to make sure the setting had stuck, which it had, but still no luck.
I should give my system specs if it matters:
GTX 980Ti
AMD 8 Core 4GHz CPU
32 GB Ram
Win10 Pro
All RL software running the latest updates
-Sterling
Beat_CH
Beat_CH
Posted 11 Years Ago
Hi,
I used it with the following settings in neuron (using Win 7, and Iclone 6.21, Trialversion)
Neuron Settings:
Broadcasting:
BVH. Port: 7001
Output format:
Freq: 1
Block..: Binary
Rotation: YXZ
Displacement: on
Reference: off
In Iclone:
Start the Plug-in Using the Pull-Down menu: "Plugins" in the Top Menu bar
It does not work using the Avatar-Modify Window under Motion, Device Mocap.
Regards
Beat
sterlingy
sterlingy
Posted 11 Years Ago
BEAT_CH,
I did as you suggested and started the plugin from the menu, and everything work perfectly. THANK YOU!!
I didn't monkey with any of the other settings. When I have time, I'll give it a more thorough look.
Two things I noticed in my first test are that the thumbs are having problems and the feet aren't aligned with the floor. To be fair, I really didn't spend much time on this. I just wanted to see if things would connect, and they did.
-S
