Technical Issues
Posted By Realtimer (RL) 11 Years Ago
tycho6
tycho6
Posted 10 Years Ago
Posts: 27, Visits: 142
Hi !
To make the new AXIS Pro version work again with iClone you simply go to File \ Settings\ Broadcasting and click the checkbox Use old header.
This enables the compatible data stream.
Regards,
Marcus
cine-vfx.com
david.janko
david.janko
Posted 10 Years Ago
New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)
Last Active: 8 Years Ago
Posts: 3, Visits: 25
it' work's fine with the standard version not the pro.
just crazy
david.janko
david.janko
Posted 10 Years Ago
axis neuron version is 3.6.32.3903
this is the pro version axis neuron in fact
thx
an another "track" to test for me i was in a "cul de sac" as we said here.
luke (RL)
luke (RL)
Posted 10 Years Ago
Group: Power Developer
Posts: 289, Visits: 5.6K
david.janko (3/1/2016)
I select Connect from within the Plugin menu -> Neuron Mocap plugin -  Neuron Console, it appears to connect but the Preview / Record buttons are still not available
the port 7001 is free i stop the sentinel program on this port but still no preview or records button
any ideas?
Can you check your version of Axis Neuron ? If you're using 2740, it's not support right now, because Noitom changed the stream format in this version, we gonna fix this asap, thanks
sterlingy
sterlingy
Posted 10 Years Ago
Posts: 206, Visits: 714
any ideas?
Just a random thought. For a while, the connection between Axis and iClone was not working with the Pro version of Axis. Which version are you using. Since I mocap with two rigs, I don't use the plguin as it doesn't support more than one rig. It may be the case that Axis Pro is still not working with iClone. I'm not near my mocap  machine, so I can't check at the moment.
Stick with the flock, end up a lamb chop!
www.ShivooStudios.com
david.janko
david.janko
Posted 10 Years Ago
any ideas?
Posted 10 Years Ago
Posts: 15.8K, Visits: 31.4K
Thanks everyone for reporting their progress and issues. I'm still an interested bystander, but from what I've seen this will beat the Kinect. It would be helpful if you indicate of you needed to do much cleaning up of the motions and what you used for it.
sterlingy
sterlingy
Posted 10 Years Ago
I'm glad I could provide some help. I further advise that you ZERO your rig before each recording of the mocap, and then just start your real actor in the t-pose before they do their performance. Zeroing the rig, resets the sensors and clears out drift that occurs over time.
-Sterling
shmedia
shmedia
Posted 10 Years Ago
Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)Junior Member (180 reputation)
Posts: 25, Visits: 225
Hi,
Thanks for your response. It took some doing because during my first test recording  I failed to record a T-Pose (Stupid me). Anyway, I had a pose close enough that I could rotate the bones back to a basic T-pose. Then followed the steps you suggested. They seem to be working ok now. I need to work on posing the figures a little better in the T-pose, but this is the most progress I have had so far. I made sure to save the T-pose for this actor so I can bring it it again for other recordings made with this subject. Thanks a bunch. I ordered the suite in November 2015. I didn't get it until January 2016 and have been trying to get the plugin and/or 3d exchange to work every since. I believe the plugin not working may be due to a windows 10 issue. I currently am having problems with a frozen start bar. When windows 10 updates I can't use the search windows or the the start button. Fixed it myself twice by following online tips, but after the third time a month ago I could not. Will send it in to be fixed next week. Hopefully, if that starts working the broadcast feature in neuron will work properly as well. Anyway, thank for a little light at the end of the tunnel.Go here for video.
sterlingy
sterlingy
Posted 10 Years Ago
shmedia (2/28/2016)
I too can not get my 32 neuron suite to work with I-clone. I am running on windows 10 and perception neuron does not seem to broadcast. I followed all the suggestions. I have the pro version of axis neuron.  I have the newest version of I-clone 6.4. Every time I open the plugin the record and preview buttons are grayed out and locked. Any suggestions what to try? I have update/ uninstalled and reinstalled both axis and I-clone about two times each. I make sure the "use old headers" box is checked. Nothing I try seems to fix it.
So I figured I could at least take the motion files into 3d exhange and use them that way. However, I can't apply the motions to the existing figure. It say figure does not match , it also says  convert to non standard. If I try this  won't let me set bones. both legs seem to be opposite.  Any suggestions would be welcome.
For starters, are you launching the plugin from the plugin dropdown menu?
Make sure your character in iClone is selected when you are trying to sync with Axis
Sometimes, I have had to play the mocap in Axis for the preview or record button to become active.
As for 3DXchange, you load the BVH in and then click convert to non-standard. next you may have to rotate the hip bone, depending on which way your real actor was facing when you recorded the mocap. Rotate so that the skeleton is facing the camera in 3DXchange. Now select the Maya preset and click on Active. You should have recorded your mocap with a t-pos at the start. Next to the actove button make sure t-pose is selected in the dropdown (default). And click CONVERT.
Next make sure your character is selected in iClone and then under the list of Animations window, click "add to iclone"
Hope that helps.
