Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
Peter (RL) (6/4/2015)
Dragonskunk (6/4/2015) One more major problem surfaced with iClone 6.11
When you rotate the head by using the X Y Z rings the head keeps snapping. -Any character. -More noticeable when other angles not being rotated are not default angles.
Hi Dragonskunk, Thank you for notifying us of this issue. We will get this corrected before the final 6.11 update is released. Apologies for the inconvenience caused by this issue. This is not just limited to the head. Hands have the same problem.
Posted 11 Years Ago
Visits: 62.6K
[/quote] This is not just limited to the head. Hands have the same problem. [/quote]
I tested that the other day. It's the same for any bone.
Dragonskunk
Dragonskunk
Posted 11 Years Ago
Visits: 1.4K
I can't wait till I am able to use 3DX v6 as anything exported form v6 doesn't load into iClone v6 unless you have at least v6.1 and I have to use v6.02 and can only use 3DX v5.51 so hoping soon the RL team will refocus on iClone troubles soonest.
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
Hi Everyone, The official release of the full iClone 6.11 update is not until Monday, but for those needing a solution for the "Edit Motion Layer" problems, I have provided the download links below. I hope this helps. :)iClone 6.11http://file.reallusion.com/patch/ic/iC611_Enu_Full_Patch.exeVersion: 6.11.1809.1 Fixed: Timeline doesn't refresh when a keyframe is added using the Edit Motion Layer tool. Ref: https://forum.reallusion.com/FindPost237668.aspxFixed: Content Manager now shows .iSubstance files. Ref: https://forum.reallusion.com/FindPost237452.aspxFixed: "Hide Navigation Panel" state in the Content window not remembered. Ref: https://forum.reallusion.com/FindPost237391.aspxFixed: Project name does not appear on title bar and doesn't update when changed. Ref: https://forum.reallusion.com/FindPost237658.aspxFixed: G6 Bones not showing when selected in "Edit Motion Layer" settings. Ref: https://forum.reallusion.com/FindPost237673.aspxFixed: Cannot open crash recovery file. Ref: https://forum.reallusion.com/FindPost237640.aspxFixed: Additional head rotation attempts in the Edit Motion Layer tool will cause snapping. Ref: https://forum.reallusion.com/FindPost238084.aspx3DXchange 6.11http://file.reallusion.com/patch/ic/3DX611_Enu_Full_Patch.exeVersion: 6.11.0609.1Fixed: . Fixed: Normal texture channel assignment not working.
Agonos
Agonos
Posted 11 Years Ago
Last Active: 7 Years Ago
Posts: 1.1K,
Visits: 3.1K
Thank you. But this is the first time a "patch" asks me to restart the computer.
Krusher
Krusher
Posted 11 Years Ago
Visits: 1.2K
Has anyone experienced looping when using Motion Puppet. This has occurred after the most recent update ver. 6.1.1728.1 It is not a show stopper and I must say iclone crashes less often these days. :blink:
Haswell i7-5930K (3.5 GHz, 140W, 15MB Cache) 16GB RAM, 1.0TB SSD, 3.0TB HD NVIDIA GeForce® GTX™ 980 (X3/SLI) 4GBx3
rgreenidge
rgreenidge
Posted 11 Years Ago
Visits: 1.7K
This is probably not a new bug, and I don't know what version it started with, but it's definitely on the iC6 series up to 6.11. There are two bugs, one is time consuming (avatar), and one is annoying and gets in the way sometimes. I'll start with the first: When you have a avatar and have some attached accessories, in previous versions when you made the avatar invisible by turning off the visible state in the timeline, everything attached to the avatar would disappear, and appear in sync. With iClone 6, The hat, hair or accessories will stay in their last state. I have to go to the timeline, and apply the visible state separately to each accessory, even though it is attached to the avatar. It's not hard to do, and sometimes the timing is slightly off. The other bug is that when you have multiple cameras, and you have then set to invisible. They keep appearing on the screen, and you have to cycle the invisible icon. Sometimes you're like; "What the heck is that in the way"? And it's the other (invisible?) cameras. Thanks.
Home built; ASRock X570 Pro 4, AMD Ryzen 9-5950X CPU, AMD RADEON RX6900XT, 16GB video card, 131GB of RAM.
Colonel_Klink
Colonel_Klink
Posted 11 Years Ago
Posts: 1.1K,
Visits: 7.7K
Agonos (6/1/2015)
Peter (RL) (6/1/2015)
Dragonskunk (5/31/2015) Each time it crashes my project is lost. Cannot open crash recovery file: ! Failed to load the file.
Hi Dragonskunk, We see you are reporting a number of issues that we are not able to reproduce. Are these all related to one project or are the issues affecting all projects? If the problem is affecting all projects I would advise uninstalling iClone 6 and perform a clean install of the full iClone 6.1. Then check again for the same issues. If the issues are with one project, can you please contact us at Support and let us have a link to download the project. http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspxThanks. 1) Load avatar "Mason". Add the 3D Scéne "Butte" for example 2) Open the "Task Manager" of Windows. End the process Ic6 3) Reload "IC6" and he wrote this on the screen: "Unsaved project data found Would you like to upgrade your project with the unsaved changes.?". Click on "ok". 4) It proposes to name the file "restore" by default. Confirm this choice. 5) After a short loading time, says IC6 as in the previous version: "Restore successull". Only after pressing "ok", IC6 now says: "Failed to load the file"  Same thing happened to me. Hours of work lost in a single keystroke. Not impressed at all.
* * * * * * * * * * * * * * * * * * See all my content in one place
 Facebook Page: CWK3D Game and Film Content Cancer Survivor - Retired Teacher - Geriatric Icloner still learning Hardware: ZX80; Operating System- ZX80 Basic; CPU - ZX80 @ 3.25 MHz; Memory - 1KB; Hard Drive - N/A; Storage - Cassette; Monitor: Any old CRT TV
Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
Colonel_Klink (6/18/2015) [ Same thing happened to me. Hours of work lost in a single keystroke. Not impressed at all.Did you update to the latest patch? That should solve it. The auto-restore works again for me.
Colonel_Klink
Colonel_Klink
Posted 11 Years Ago
Posts: 1.1K,
Visits: 7.7K
Yeah I installed the latest patch, but I don't trust it now :)
