OFFICIAL 6.02 Issues Thread
Posted By Peter (RL) 11 Years Ago
4
5
6
7
8
21
Agonos
Agonos
Posted 11 Years Ago
Last Active: 7 Years Ago
Posts: 1.1K, Visits: 3.1K
Hello all
Am I blind or there is no more "Export path" in IC6 ?
Posted 11 Years Ago
Posts: 15.8K, Visits: 31.4K
Peter (RL) (2/10/2015)
Fixed: The Hide camera shows while pressing undo and project playing.
The description of this fix is not quite clear to me, but sometimes Cameras are still showing when they are selected as hidden.
Postfrosch
Postfrosch
Posted 11 Years Ago
Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)
Posts: 6.9K, Visits: 18.4K
Hello all
No you're not blind.
I also find no export option for the path.
Greetings from Germany
Postfrosch
nat woi
nat woi
Posted 11 Years Ago
Posts: 96, Visits: 810
over all visuals quality isn't the same in my opinion with every thing set you high and smoothing
RobertoColombo
RobertoColombo
Posted 11 Years Ago
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.6K, Visits: 3.0K
animagic (2/15/2015)
I can confirm Job's statement: cameras are still shown even though they are marked as hidden.
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO + 1x2TB Samsung
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the MOTU M4 I/F) / DirectX: 12
mark
mark
Posted 11 Years Ago
Posts: 4.9K, Visits: 16.7K
Yep! I have to click them again and then click to hide...it usually works.
PROMO-BACK2
Posted 11 Years Ago
Here is a problem that a member discovered with 5-pinned cloth, which has 4 corner pins and 1 center pin.
According to the iClone 6 Help, you can delete the corner pins and then simulate a cloth that is held in the center, while the corners fall down. However, this is not what happens. After removing the corner pins, the cloth still behaves as pinned at the corners.
I was able to repeat this, following the instructions in the Help.
EDIT: As was pointed out by rampa, this does work with Bullet physics, but since the physics type cannot be set per object that is not really a viable solution. The iClone 6 Help mentions the pinned cloth as one type of Soft Cloth but does not state that it only work for Bullet physics.
Soya_RL
Soya_RL
Posted 11 Years Ago
Veteran Member (840 reputation)Veteran Member (840 reputation)Veteran Member (840 reputation)Veteran Member (840 reputation)Veteran Member (840 reputation)Veteran Member (840 reputation)Veteran Member (840 reputation)Veteran Member (840 reputation)Veteran Member (840 reputation)
Posts: 269, Visits: 1.4K
Dear Animagic,
This is to fix: Press Undo after press play. The hidden camera will become show in viewport but still as hidden in Scene Manager. :)
=> I can't repeat it. If there are some particular steps that you take to create this issue, please let me know. Tks so much. ;)
Soya
Posted 11 Years Ago
soyasu (2/16/2015)
Soya, I'll try to see if there is a specific condition that causes this to happen. Others have observed this behavior too, so it's not just me.
45thdiv
45thdiv
Posted 11 Years Ago
Posts: 209, Visits: 696
The audio drifts in the timeline for lip sync. Please fix this. Also please add the ability to have the audio play as we slowly scrub back and forth to test lip movement during animation.
thanks
Matthew
PC stats:
Intel Core i7-5930K Processor (6-cores, 15MB Cache, Overclocked to 3.9 GHz with Turbo Boost)
Windows 10
Graphics card NVIDIA GeForce GTX 1080 graphics, 8GB
Memory - 16GB Quad Channel  DDR4 at 2133MHz
DirectX - 12
256GB SSD 6Gb/s main HD + 4TB 6kRPM SATA 6Gb/s Storage
4
5
6
7
8
21
