OFFICIAL 6.02 Issues Thread
Posted By Peter (RL) 11 Years Ago
Posted 11 Years Ago
Posts: 23.1K, Visits: 36.6K
Hi Everyone,
iClone 6.02 has now been officially released.
You can update using LiveUpdate, or from your Member Account under Patch/Bonus, or by going to Help > Check For Update in iClone 6.
Can you please post all issues, bugs, glitches, etc. that you find with the iClone 6.01 release here.
Of course feel free to post general feedback in your own threads but it will be great if we can keep outstanding issues and bugs here in this official thread. It will make it easier for the development team to track any outstanding problems and get them fixed quickly.
Please do try to provide your full system specs and a description of the problem when posting issues as this will help greatly. If you can provide step by step information so we can repeat the problem even better.
Thanks.
iClone Version History
v6.02 (6.02.1409.1) released 10th February-15
Added:
  • Added iClone DirectX 9 Version for earlier graphic cards.
  • Added Graphic Mode Selection for DirectX 9/DirectX 11 switching.
  • Added Installation & Performance Guide while first launch iClone.
Fixed:
  • Fixed: Non-standard character with spring settings, exporting & reloading Motion Plus causes possible crash.
  • Fixed: Remove Motion in Timeline sometimes changes the original motion.
  • Fixed: Value change not updated in Physics & Particle Settings unless Enter is pressed.
  • Fixed: Export Range not updated correctly when Total Frame value from Project Settings is changed.
  • Fixed: Cursor not updated correctly while picking a Target in Physics Constraints.
  • Fixed: The Finger Mirror function is disabled in Avatar Proportion while loading a non-standard character after loading a standard one.
  • Fixed: The Hide camera shows while pressing undo and project playing.
  • Fixed: Copy function failed while holding Ctrl key and dragging a motion clip in the Timeline.
  • Fixed: Replacing a standard character causes a possible crash once an object is linked to a non-standard character.
  • Fixed: Possible crash while G6 character has replaced a G5 character and user double-clicks on the Timeline.
  • Fixed: Timeline Switcher track doesn't update once cameras are renamed.
  • Fixed: Delete Frame in Timeline is sometimes disabled.
  • Fixed: Breaking clips while they are overlapped caused a crash.
  • Fixed: The Right/Left Arrow key for moving the playhead doesn't work when Timeline is open.
  • Fixed: Character motion removed unexpectedly when using Create Face, Facial Features, and Collision Shape tools.
  • Fixed: The Look at function sometimes fails to Set Free.
  • Fixed: Drag a material from the library to Speedtree causes a possible crash.
  • Fixed: Slider Constraint rotate value set to -X causes possible crash.
  • Fixed: Recurrent crash while using the Undo/Redo behavior on a Soft Cloth object.
  • Fixed: Glare Type of HDR, Vertical Flare and Horizontal Flare was converse.
  • Fixed: The Spring and Physics effect exhibit shaking when exporting to Indigo in certain conditions.
  • Fixed: Exporting IGQ from the Indigo plug-in causes a crash in some Windows 8.1 environments.
  • Fixed: Frame size not synced between Indigo and Current Project Settings, while the export format switches from video to Image Sequence.
  • Fixed: Hard to select lower eyelid in facial features under Large Font size mode.
  • Fixed: In iClone traditional transform gizmo mode, mouse scroll behavior is incorrectly.
  • Fixed: Holding the CTRL key while rotating/scaling an object didn't duplicate correctly.
  • Fixed: Anisotropic Filtering in the Preference settings not remembered.
  • Fixed: Tone Mapping for Indigo Render Settings, default value changed to unchecked.
  • Fixed: Resizing the Infinite Plane caused program to crash.
  • Fixed: Some of the content downloads showed Network error (error code 202).
  • Fixed: Frame rate disabled unexpectedly while rendering AVI .
Content Update:
  • G6 Character: Enhanced the skin quality for Indigo rendering.
  • Default Project: Default.iProject enhanced shape smoothing on some objects for Indigo rendering.
  • 3D Blocks (Substance): Enhanced the texture quality.
Threaded View
Threaded View
Forum Post OFFICIAL 6.02 Issues Thread By Peter (RL) ( 11 Years Ago )
Forum Post Not mentioned by Peter but also fixed in 6.02: ... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post Yay for 6.02!!! :w00t: Great looking set of fixes. I see you... By justaviking ( 11 Years Ago )
Forum Post For the records, not fixed/still issues in 6.02: ... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post Another wish that would be very welcome: [color="#DD9955"]|WISH|... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post Thanks for the update. :D Do we need to redownload the 1 gig resource... By hattori kun ( 11 Years Ago )
Forum Post [quote][b]hattori kun (2/10/2015)[/b][hr]Thanks for the update. :D Do... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (2/10/2015)[/b][hr][quote][b]hattori kun... By wires ( 11 Years Ago )
Forum Post Hi Peter, the error when rendering I had reported today again is... By Postfrosch ( 11 Years Ago )
Forum Post Thank you RL for the patch ! Not mentioned by Peter but also fixed... By Supergerry ( 11 Years Ago )
Forum Post Same issue as the previous 6.02. The plugin tab and indigo is gone... By hattori kun ( 11 Years Ago )
Forum Post .[quote][b]hattori kun (2/10/2015)[/b][hr]Same issue as the previous... By wires ( 11 Years Ago )
Forum Post [quote][b]wires (2/10/2015)[/b][hr].[quote][b]hattori kun... By hattori kun ( 11 Years Ago )
Forum Post [quote][b]hattori kun (2/10/2015)[/b][hr]Same issue as the previous... By GOETZIWOOD STUDIOS ( 11 Years Ago )
Forum Post [quote][b]hattori kun (2/10/2015)[/b][hr]Same issue as the previous... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]hattori kun (2/10/2015)[/b][hr]Same issue as the previous... By Soya_RL ( 11 Years Ago )
Forum Post [quote][b]soyasu (2/12/2015)[/b][hr][quote][b]hattori kun... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (2/12/2015)[/b][hr][quote][b]soyasu... By Soya_RL ( 11 Years Ago )
Forum Post [quote][b]soyasu (2/12/2015)[/b][hr]The new iC6 Patch (v6.02) will... By justaviking ( 11 Years Ago )
Forum Post [quote][b]soyasu (2/12/2015)[/b][hr][quote][b]hattori kun... By hattori kun ( 11 Years Ago )
Forum Post Thank you for this patch but my problem "glare" is still not resolved.... By Agonos ( 11 Years Ago )
Forum Post [quote][b]Agonos (2/10/2015)[/b][hr]Thank you for this patch but my... By animagic ( 11 Years Ago )
Forum Post Particle Opacity will not retain changes: [center] [/center] By Cricky ( 11 Years Ago )
Forum Post [quote][b]Cricky (2/11/2015)[/b][hr]Particle Opacity will not retain... By Peter (RL) ( 11 Years Ago )
Forum Post My only problem so far is that so many people are downloading the... By KenCoon ( 11 Years Ago )
Forum Post I was just going to post about that. Download is very, very slow. By animagic ( 11 Years Ago )
Forum Post I wish RL could use auto-updation of THE PACKAGE through embedded ftp... By prabhatM ( 11 Years Ago )
Forum Post Scrap that...:blush: BTW, downloading seems up-to-speed again. By animagic ( 11 Years Ago )
Forum Post Although it wasn't on the list of fixes, one can always... By animagic ( 11 Years Ago )
Forum Post MY REQUEST... Is to have a list of all publicly reported , but... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (2/11/2015)[/b][hr]MY REQUEST... Is to have a... By hattori kun ( 11 Years Ago )
Forum Post [b]|BUGs|[/b]... By Supergerry ( 11 Years Ago )
Forum Post Little problem (with work-around): if the timeline range cursor... By RobertoColombo ( 11 Years Ago )
Forum Post I agree with Viking that we need something a more efficient. We call... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (2/11/2015)[/b][hr]I agree with Viking that we need... By james_muia ( 11 Years Ago )
Forum Post Even though I am also in favor of having a report about what is still... By RobertoColombo ( 11 Years Ago )
Forum Post Frankly, I don't expect access to Reallusion's official bug tracking... By justaviking ( 11 Years Ago )
Forum Post Great to see these fixes, I'm really like iClone 6. Still one... By hestera ( 11 Years Ago )
Forum Post [quote][b]hestera (2/13/2015)[/b][hr]Great to see these fixes, I'm... By james_muia ( 11 Years Ago )
Forum Post [quote][b]james_muia (2/13/2015)[/b][hr][quote][b]hestera... By hestera ( 11 Years Ago )
Forum Post Convert Position to Path still not working. As reported in this... By wires ( 11 Years Ago )
Forum Post [b]Fixed: Exporting IGQ from the Indigo plug-in causes a crash in some... By sbaerman ( 11 Years Ago )
Forum Post the problem with the picker is still not fixed Please RL fix it, it... By vidi ( 11 Years Ago )
Forum Post |BUG| Saving Collisions to a file does nothing / overwrite an existing... By Supergerry ( 11 Years Ago )
Forum Post [quote][b]Supergerry (2/13/2015)[/b][hr]|BUG| Saving Collisions to a... By Peter (RL) ( 11 Years Ago )
Forum Post Not sure about this one but softcloth with baked checked and unchecked... By hattori kun ( 11 Years Ago )
Forum Post Haven't had time to really work with physics in version 6 but in... By warlord720 ( 11 Years Ago )
Forum Post A bug! In Preference -> Level of Detail Options -> UnCheck it ---->... By Jen Arrow ( 11 Years Ago )
Forum Post [quote][b]Jen Arrow (2/14/2015)[/b][hr]A bug! In Preference ->... By Peter (RL) ( 11 Years Ago )
Forum Post I also have the 40% crash problem on certain (not too big either)... By DickyJim ( 11 Years Ago )
Forum Post [quote][b]DickyJim (2/14/2015)[/b][hr]I also have the 40% crash... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]sbaerman (2/13/2015)[/b][hr][b]Fixed: Exporting IGQ from the... By hattori kun ( 11 Years Ago )
Forum Post [b]Strange behavior with speedtree wind.[/b] Create a hold key at 10... By hattori kun ( 11 Years Ago )
Forum Post Hello all Am I blind or there is no more "Export path" in IC6 ? By Agonos ( 11 Years Ago )
Forum Post [quote]Hello all Am I blind or there is no more "Export path" in IC6... By Postfrosch ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (2/10/2015)[/b][hr] Fixed: The Hide camera... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (2/15/2015)[/b][hr][quote][b]Peter (RL)... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]animagic (2/15/2015)[/b][hr][quote][b]Peter (RL)... By mark ( 11 Years Ago )
Forum Post [quote][b]animagic (2/15/2015)[/b][hr][quote][b]Peter (RL)... By Soya_RL ( 11 Years Ago )
Forum Post [quote][b]soyasu (2/16/2015)[/b][hr] sometimes Cameras are still... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (2/16/2015)[/b][hr][quote][b]soyasu... By animagic ( 11 Years Ago )
Forum Post over all visuals quality isn't the same in my opinion with every... By nat woi ( 11 Years Ago )
Forum Post Here is a problem that a member discovered with 5-pinned cloth, which... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (2/15/2015)[/b][hr]Here is a problem that a member... By Peter (RL) ( 11 Years Ago )
Forum Post The audio drifts in the timeline for lip sync. Please fix this. Also... By 45thdiv ( 11 Years Ago )
Forum Post [quote][b]45thdiv (2/17/2015)[/b][hr]The audio drifts in the timeline... By justaviking ( 11 Years Ago )
Forum Post [quote][b]45thdiv (2/17/2015)[/b][hr]The audio drifts in the timeline... By mark ( 11 Years Ago )
Forum Post Maybe if more people ask???? I am glad I am not the only one who... By 45thdiv ( 11 Years Ago )
Forum Post :) :D :w00t::satisfied::satisfied::satisfied:Hallelujah!!!! :cool:... By lpatter ( 11 Years Ago )
Forum Post Hi Mark, It renders just a bit off. The sync never was correct to... By 45thdiv ( 11 Years Ago )
Forum Post Thank you all for the reports since the release of iClone 6.02. This... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (2/17/2015)[/b][hr]Thank you all for the reports... By hattori kun ( 11 Years Ago )
Forum Post [b]I'm being facetious here in some of my comments[/b] because the... By Cricky ( 11 Years Ago )
Forum Post [quote][b]Cricky (2/18/2015)[/b][hr][b]I'm being facetious here in... By Peter (RL) ( 11 Years Ago )
Forum Post In this post: https://forum.reallusion.com/FindPost225689.aspx , a... By animagic ( 11 Years Ago )
Forum Post |ISSUES| - Spring no longer works after resizing Avatar (AVATAR... By Supergerry ( 11 Years Ago )
Forum Post [quote][b]Supergerry (2/18/2015)[/b][hr]| WISH | - Press Play / Stop... By Peter (RL) ( 11 Years Ago )
Forum Post There is a problem in stereo 3d output When I use stereo 3d render... By Varsha Discmedia ( 11 Years Ago )
Forum Post I have played around again with the sync drift. I went back to this... By 45thdiv ( 11 Years Ago )
Forum Post This is actually something I would consider a "functional" bug that... By Rampa ( 11 Years Ago )
Forum Post Here's the bug in Iclone indigo for speedtree. The only workaround... By hattori kun ( 11 Years Ago )
Forum Post [quote][b]hattori kun (2/20/2015)[/b][hr]Here's the bug in Iclone... By Peter (RL) ( 11 Years Ago )
Forum Post This may just be my system but....when I turned off the GIZMO, which... By mark ( 11 Years Ago )
Forum Post [quote][b]mark (2/20/2015)[/b][hr]This may just be my system... By animagic ( 11 Years Ago )
Forum Post Collision Profiles will not write. [center] [/center] By Cricky ( 11 Years Ago )
Forum Post [quote][b]Cricky (2/22/2015)[/b][hr]Collision Profiles will not write.... By Peter (RL) ( 11 Years Ago )
Forum Post May have been mentioned but you can on longer use the "ALT" key to... By mark ( 11 Years Ago )
Forum Post It is Official. I am beating a dead horse. I just watched the... By lpatter ( 11 Years Ago )
Forum Post Check under program preferences. I don't have iClone in front of me,... By animagic ( 11 Years Ago )
Forum Post Thank you so much Animagic I can't believe that this was not part of... By lpatter ( 11 Years Ago )
Forum Post | FEATURE REQUEST | - A MERGE function for projects. (Deleting... By Supergerry ( 11 Years Ago )
Forum Post Yep! Been wanting a "Merge Projects" function since day one!!!!!:D:D By mark ( 11 Years Ago )
Forum Post I'm just waiting for the 6.1 upgrade. By mr_vidius ( 11 Years Ago )
Forum Post [quote][b]mr_vidius (2/25/2015)[/b][hr]I'm just waiting for the 6.1... By mark ( 11 Years Ago )
Forum Post This appears to be more related to Indigo, but there doesn't seem to... By Cricky ( 11 Years Ago )
Forum Post This one is directly related to the "J" shortcut key in iClone 6. The... By Cricky ( 11 Years Ago )
Forum Post I'd like to see this particular action on the time line in iClone6 to... By Cricky ( 11 Years Ago )
Forum Post The "Water Type" Props are looking for their Perform animations as... By lpatter ( 11 Years Ago )
Forum Post when i create a project with 1800 frames it will only render the first... By Mark McKinney ( 11 Years Ago )
Forum Post [quote][b]Mark McKinney (3/2/2015)[/b][hr]when i create a project with... By justaviking ( 11 Years Ago )
Forum Post Thanks - I'll just change over to "seconds" on my default setup and... By Mark McKinney ( 11 Years Ago )
Forum Post [quote][b]justaviking (3/2/2015)[/b][hr][quote][b]Mark McKinney... By prabhatM ( 11 Years Ago )
Forum Post from a total noob perspective ( well not really, but play along ) ... By planetstardragon ( 11 Years Ago )
Forum Post Re: Frames per Second... I'm not supporting iClone's behavior. I was... By justaviking ( 11 Years Ago )
Forum Post [quote][b]justaviking (3/6/2015)[/b][hr] I remember a huge fuss when... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (3/6/2015)[/b][hr]Not to be picky, but that's only... By justaviking ( 11 Years Ago )
Forum Post the grass image auto update doesn't seem to work ... ie - launch... By planetstardragon ( 11 Years Ago )
Forum Post I noticed the old "Flex Cloth" props are still included with iC6. Just... By mark ( 11 Years Ago )
Forum Post There is a bug when exporting a clip in WMV in iCl6 - Ausage. It... By Postfrosch ( 11 Years Ago )
Forum Post This is an Iclone issue that carried over to indigo. Disappearing... By hattori kun ( 11 Years Ago )
Forum Post Here is a new comment, though I am sure it really is not new. I can't... By 45thdiv ( 11 Years Ago )
Forum Post Oh yes!!! iClone has a VERY short memory where menu setups are... By mark ( 11 Years Ago )
Forum Post With regards to the fps issue in Iclone. There's a [b]disconnect[/b]... By hattori kun ( 11 Years Ago )
Forum Post Very serious issue: Collision Profile is not saved anymore. That makes... By madicloner ( 11 Years Ago )
Forum Post Bring back the floor shadow! That's an issue for all of us! It was... By Step Animations ( 11 Years Ago )
Forum Post SKYTOOL MOON The Moon phase in the free Skytool projects work.... By lpatter ( 11 Years Ago )
Forum Post MISSING ASSETS PURCHASED FROM THE MARKETPLACE This is a problem since... By lpatter ( 11 Years Ago )
Forum Post lpatter, you can set the time range for the Inventory to more than a... By animagic ( 11 Years Ago )
Forum Post I have been trying to do that for months now , even before Iclone 6,... By lpatter ( 11 Years Ago )
Forum Post :w00t: Sorry. By peppie ( 11 Years Ago )
Forum Post [quote][b]peppie (3/12/2015)[/b][hr]Look in 'Content store and... By animagic ( 11 Years Ago )
Forum Post Thank you all for continuing to report the issues you are finding with... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (3/12/2015)[/b][hr]Thank you all for continuing... By Agonos ( 11 Years Ago )
Forum Post [quote][b]Agonos (3/13/2015)[/b][hr][quote][b]Peter (RL)... By Peter (RL) ( 11 Years Ago )
Forum Post I have a problem with a project, where the Preview camera for some... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (3/14/2015)[/b][hr]I have a problem with a project,... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (3/17/2015)[/b][hr] Sounds like iClone is going... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (3/18/2015)[/b][hr][quote][b]Peter (RL)... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (3/17/2015)[/b][hr][quote][b]animagic... By Agonos ( 11 Years Ago )
Forum Post Hi, not sure if already reported... I found a problem with the... By RobertoColombo ( 11 Years Ago )
Forum Post not sure if this has been mentioned, but once you use a substance... By planetstardragon ( 11 Years Ago )
Forum Post Today's note: Please make the "Installer" more robust Actually,... By justaviking ( 11 Years Ago )
Forum Post Error Adding Prop To Avatar. When I add a prop to a general area and... By lpatter ( 11 Years Ago )
Forum Post We need a list of open issues, because I believe this one was... By animagic ( 11 Years Ago )
Forum Post This is more of an inconvenience than a serious bug: As you can... By animagic ( 11 Years Ago )
Forum Post when I use the sky tool, and close the window to regain screen... By planetstardragon ( 11 Years Ago )
Forum Post Sound issues... -I used "drag-and-drop" to put a 1 minute .wav file... By namunger ( 11 Years Ago )
Forum Post [quote][b]namunger (3/22/2015)[/b][hr]Sound issues... -I used... By animagic ( 11 Years Ago )
Forum Post Motion Puppet: when I apply it after (in the timeline) some other... By RobertoColombo ( 11 Years Ago )
Forum Post [b]Motion Layer Edit:[/b] [b]The Bone Edit Panel needs to have the... By Cricky ( 11 Years Ago )
Forum Post [quote][b]Cricky (3/22/2015)[/b][hr][b]Motion Layer Edit:[/b] ... By prabhatM ( 11 Years Ago )
Forum Post [quote][b]prabhatM (3/28/2015)[/b][hr][quote][b]Cricky... By Cricky ( 11 Years Ago )
Forum Post There are still issues to discover. I'm reporting this before I... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (3/28/2015)[/b][hr]There are still issues to... By prabhatM ( 11 Years Ago )
Forum Post [quote][b]animagic (3/28/2015)[/b][hr]There are still issues to... By mark ( 11 Years Ago )
Forum Post I have several G5 characters for which I have created new faces in... By animagic ( 11 Years Ago )
Forum Post Load "Mason" character. Use the "Avatar Proportion" option. Put the... By Agonos ( 11 Years Ago )
Forum Post [quote][b]Agonos (3/28/2015)[/b][hr]Load "Mason" character. Use the... By mark ( 11 Years Ago )
Forum Post Here is another issue to be aware of: When you try to save a project... By animagic ( 11 Years Ago )
Forum Post Triplication of the assets in the Scene Manager. See the picture:... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (3/29/2015)[/b][hr]Triplication of the assets... By animagic ( 11 Years Ago )
Forum Post I've seen it as well...very random!;) By mark ( 11 Years Ago )
Forum Post Hi all, Is it normal to see the world axis on exported video ? By Agonos ( 11 Years Ago )
Forum Post [center][quote][b]Agonos (4/4/2015)[/b][hr]Hi all, Is it normal to... By Cricky ( 11 Years Ago )
Forum Post "Mine shows up also, but [b][u]only when rendering in Preview... By Agonos ( 11 Years Ago )
Forum Post Hi RL, here is a little thing that should be fixed: when the... By RobertoColombo ( 11 Years Ago )
Forum Post Thank you all for the continued feedback. The next update 6.03 will... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (4/7/2015)[/b][hr]Thank you all for the continued... By Agonos ( 11 Years Ago )
Forum Post Apologizes for the double-post of this issue... By Artman009 ( 11 Years Ago )
Forum Post Gee wiz Peter.. this is getting depressing.. waiting.. and waiting..... By mr_vidius ( 11 Years Ago )
Forum Post I believe I saw this reported as an error recently. This came to mind... By Cricky ( 11 Years Ago )
Forum Post Hi, one tiny defect that would be nice to be fixed. Scenario: an... By RobertoColombo ( 11 Years Ago )
Forum Post Camera Indicator names are either reversed or poorly named. When I... By Cricky ( 11 Years Ago )
Forum Post Error with edit weight map - no sliders for brightness or contrast. ... By 45thdiv ( 11 Years Ago )
Forum Post And 6.03 can be expected when??? :) By wires ( 11 Years Ago )
Forum Post Same request I had (with numerous +1's) when 6.01 and 6.02 were... By justaviking ( 11 Years Ago )
Forum Post [quote][b]wires (4/13/2015)[/b][hr]And 6.03 can be expected when???... By Peter (RL) ( 11 Years Ago )
Forum Post Hi, Your team has not yet found a clue to the problem with the... By Agonos ( 11 Years Ago )
Forum Post [quote][b]Agonos (4/13/2015)[/b][hr]Hi, Your team has not yet found a... By Peter (RL) ( 11 Years Ago )
Forum Post Hi all and thx Peter [b]"Unfortunately the "Glare" issue should now... By Agonos ( 11 Years Ago )
Forum Post [quote][b]Agonos (4/16/2015)[/b][hr]Hi all and thx Peter... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]"For the G6 characters we are currently looking at adding... By Agonos ( 11 Years Ago )
Forum Post Hi Peter , I didn't see in this trhead the terrain Heightmap... By mtakerkart ( 11 Years Ago )
Forum Post Hi Peter, is this issue also repaired in version 6.03 ??? - - Spring... By Supergerry ( 11 Years Ago )
Forum Post [quote][b]Supergerry (4/16/2015)[/b][hr]Hi Peter, is this issue also... By Peter (RL) ( 11 Years Ago )
Forum Post - - Spring no longer works after resizing Avatar with AVATAR... By Supergerry ( 11 Years Ago )
Forum Post 1. Do you plan to repair the mega problems of v6 with Dazzies and... By madicloner ( 11 Years Ago )
Forum Post [quote][b]madicloner (4/17/2015)[/b][hr] Don´t you think, it is time... By prabhatM ( 11 Years Ago )
Forum Post [quote][b]madicloner (4/17/2015)[/b][hr]1. Do you plan to repair the... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]madicloner (4/17/2015)[/b][hr]What would be, if you sell... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]Peter (RL) (4/17/2015)[/b][hr][quote][b]madicloner... By RobertoColombo ( 11 Years Ago )
Forum Post @prabhatM Oh, I meaned the "super soft cloth" of v6 - aka new physX... By madicloner ( 11 Years Ago )
Forum Post [quote][b]madicloner (4/17/2015)[/b][hr]@prabhatM Oh, I meaned the... By prabhatM ( 11 Years Ago )
Forum Post We I am still having an Error with edit weight map - no sliders... By 45thdiv ( 11 Years Ago )
Forum Post [quote][b]45thdiv (4/17/2015)[/b][hr]I am still having an Error with... By animagic ( 11 Years Ago )
Forum Post [quote][b]animagic (4/17/2015)[/b][hr][quote][b]45thdiv... By 45thdiv ( 11 Years Ago )
Forum Post @Peter RL Ok, I understand. Well let´s make a short list of mega... By madicloner ( 11 Years Ago )
Forum Post [quote][b]madicloner (4/18/2015)[/b][hr]@Peter RL Ok, I understand.... By justaviking ( 11 Years Ago )
Forum Post Microsoft did not go back to Window 7 from Window 8, it went forward... By prabhatM ( 11 Years Ago )
Forum Post Topic: duplication of the names in The Scene window. I think I... By RobertoColombo ( 11 Years Ago )
Forum Post [quote][b]RobertoColombo (4/18/2015)[/b][hr]Topic: duplication of the... By Rampa ( 11 Years Ago )
Forum Post [quote][b]rampa (4/18/2015)[/b][hr][quote][b]RobertoColombo... By RobertoColombo ( 11 Years Ago )
Forum Post @prabhatM: That is right. Microsoft never went back to any old system.... By madicloner ( 11 Years Ago )
Forum Post Heavy bug in the particle part! F.e. "Hell Fire" can´t be setted to an... By madicloner ( 11 Years Ago )
Forum Post When saving a motion, if the character's transform includes a... By Dragonskunk ( 11 Years Ago )
Forum Post [quote][b]Dragonskunk (4/21/2015)[/b][hr]When saving a motion, if the... By RobertoColombo ( 11 Years Ago )
Forum Post I don't think 6.03 is out yet...:unsure: By animagic ( 11 Years Ago )
Forum Post Roll on version 6.3 that we can expect with the sale impatience the... By Agonos ( 11 Years Ago )
Forum Post Hi Iclone'rs I have a problem with working on a project that I have... By erisku ( 11 Years Ago )
Forum Post [quote][b]erisku (4/26/2015)[/b][hr]Hi Iclone'rs I have a problem... By mark ( 11 Years Ago )
Forum Post Hi Sorry you're right. Laptop Hp Envy DV6 with Nvidia 630M I7 8... By erisku ( 11 Years Ago )
Forum Post There's a fundamental problem with spring bones if a female character... By Dragonskunk ( 11 Years Ago )
Forum Post [quote][b]Dragonskunk (4/27/2015)[/b][hr]There's a fundamental problem... By animagic ( 11 Years Ago )
Forum Post iClone 6.03 has now been officially released. By Agonos ( 11 Years Ago )
