Agonos
Agonos
Posted 11 Years Ago
Last Active: 7 Years Ago
Posts: 1.1K,
Visits: 3.1K
iClone 6.03 has now been officially released.
Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
Dragonskunk (4/27/2015) There's a fundamental problem with spring bones if a female character is on a fast moving train for example her hair and boobs are in the next wagon flopping in the caboose! :D
I know I can turn them off or fake it with a moving background but I wish bones had directional constraints so you can at least just turn off by X Y or Z directions.This has been a long-standing problem already present in iClone 5. I like your idea of adjusting/turning off the effect by direction.
Dragonskunk
Dragonskunk
Posted 11 Years Ago
Visits: 1.4K
There's a fundamental problem with spring bones if a female character is on a fast moving train for example her hair and boobs are in the next wagon flopping in the caboose! :D I know I can turn them off or fake it with a moving background but I wish bones had directional constraints so you can at least just turn off by X Y or Z directions.
erisku
erisku
Posted 11 Years Ago
Visits: 688
Hi
Sorry you're right. Laptop Hp Envy DV6 with Nvidia 630M I7 8 GB ram and SSD 180 GB Intel.
The project is quite large at 480 MB. It based on Domicil objects and has a lot of speedtree trees plus some sketchup objects with medium complexity.
I try to animate on path but it crashes.
If I open the same file on the laptop that I managed to make it work on PC and has some animation on path it cannot load and crashes as soon as project appears on screen.
Also on my PC Acer predator G3 SSD 60 gb + 2 tb hdd Nvidia GTX 760 1,5Gb and I7 with 16Gb ram it crashes some times but when I restore I can continue to work.
regards Eris
Posts: 4.9K,
Visits: 16.7K
erisku (4/26/2015) Hi Iclone'rs
I have a problem with working on a project that I have created in IC6 and the characters are based on Jimmy Toon. When I start to animate Jimmy Toon Iclone crashes. Any way to fix it. I tried in two different PC and the same happens.
Does Iclone 6 have a problem with Jimmy Toon. With G6 characters animation is fine in the same project.
I really like visuals of IC6 and do not want to go back to IC5.
Any help. ThanksI have a feeling folks will need to know more about the specific project you are creating..like how large it is. And maybe the different PC systems configuration/specs ?? ;)
erisku
erisku
Posted 11 Years Ago
Visits: 688
Hi Iclone'rs
Any help. Thanks
Posted 11 Years Ago
Posts: 23.1K,
Visits: 36.6K
Supergerry (2/18/2015) | WISH |
- Press Play / Stop in the main window will update the timeline window and displays the current position of the playhead. When you manually move the slider in the main window the timeline window is not updated to the current position of the playhead.
GerryFor now you can click the ʺCurrent Frameʺ button on the Timeline. That will move the timeline to the current frame. However we will try to improve this feature in a future update.
Agonos
Agonos
Posted 11 Years Ago
Posts: 1.1K,
Visits: 3.1K
Roll on version 6.3 that we can expect with the sale impatience the version 6.4 !! ;) lol
Posted 11 Years Ago
Posts: 15.8K,
Visits: 31.4K
I don't think 6.03 is out yet...:unsure:
Supergerry
Supergerry
Posted 11 Years Ago
Last Active: 6 Years Ago
Visits: 106
- - Spring no longer works after resizing Avatar with AVATAR PROPORTION
Why not repaired in V6.03 ??? It worked in V5.xx, and V6.xx is useless for me if I can`t change the proportions without losing the springs. And I'm just tired to export from 3dxc to IC5, there to change the proportions, then save, open in IC6 ... and more until it fits ... I am now very angry and will not use Iclone after 6.03 fix until next time.
------------------------------------------------ iClone 7 Pro (DX11 only), Mocap device plugin, Curve Editor, 3DXchange 7 Homebuilt PC: Windows 7 Pro SP1-64bit, 1kW BeQuiet, MSI Z97 Gaming 5, i7-4790K @ 4,00 GHz Hashwell, 32GB 1600Mhz Cruical, Gigabyte Windforce OC GTX970 4GB, 4-Monitor-Config: 28" on GTX970 only with Iclone`s main window, 2x 21" on the Intel HD4600 ports with all other tabs (timeline, scene- & content manager...), HUION GT190 TouchPen Monitor
