OFFICIAL 6.02 Issues Thread
Posted By Peter (RL) 11 Years Ago
3
4
5
6
21
madicloner
madicloner
Posted 11 Years Ago
Veteran Member (697 reputation)Veteran Member (697 reputation)Veteran Member (697 reputation)Veteran Member (697 reputation)Veteran Member (697 reputation)Veteran Member (697 reputation)Veteran Member (697 reputation)Veteran Member (697 reputation)Veteran Member (697 reputation)
Last Active: 10 Years Ago
Posts: 109, Visits: 181
@prabhatM
Oh, I meaned the "super soft cloth" of v6 - aka new physX dynamic cloth and hair. Is the only thing that is really new and worth to mention. At moment we got an unbelievable buggy v6 with v5 plugin, that has thrown iClone back into the child's shoes. So it would be logical, to take the old well working v5 and add v6 plugins. That would take away all major childhood diseases and we could work again with highpoly content. Btw.: v6 makes suddenly problems with mp4s. It can´t load it or doesn´t animate them (if you take the working material of v5). v5 takes them without any problems!
prabhatM
prabhatM
Posted 11 Years Ago
Last Active: 6 Years Ago
Posts: 1.8K, Visits: 8.1K
madicloner (4/17/2015)
Don´t you think, it is time to think about a new old v5 core with a softcloth plugin?
Interesting option !
You don't want dynamic hair ?
Will it be called ICLONE Classic ?
madicloner
madicloner
Posted 11 Years Ago
1. Do you plan to repair the mega problems of v6 with Dazzies and every other highpoly content ? At moment v6 is much worse than v5 . Do you plan to change and patch this biggest problem at all ? I know that this is not easy, because I guess, that this is a problem of the reprogrammed "core". I hope that you fix that, because it has thrown back iClone back in time - nearly to its beginnings. And it is really paradox! On the one hand you try to give iClone suddenly a best quality graphics output with Indigo and on the other hand you make it suddenly really difficult to handle highpoly content. The problem: Without highpoly content, it is impossible to get best graphics output. Lowpoly content in Indigo only looks ugly!
2. You took away a bunch of v5 features, including the 2nd (better) facials. Do you plan to bring them back ? The 2nd facials at least ? Facials are very important, if you want to produce high quality animation clips. Facials are the biggest advantage of iClone against every other realtime animation software!
3. v6 has errors in really every part. The reprogramming of the core resulted nearly only in a bug desaster with (v5 needlessly totally changed) ugly interface. Often random and difficult to replicate. Don´t you think, it is time to think about a new old v5 core with a softcloth plugin? Any other feature of v6 doesn´t really matter!
What would be, if you sell again v5 and additional as plugin the softcloth and Indigo ? I think, a lot of people would buy that. Especially new customer. Older would take the plugins and would be able to work as well as before - but with new features while you got the time to reprogram v6 to a worthy successor of the best animator ever - v5. :D
Agonos
Agonos
Posted 11 Years Ago
Last Active: 7 Years Ago
Posts: 1.1K, Visits: 3.1K
Hi all and thx Peter
"Unfortunately the "Glare" issue should now be fixed in the 6.1 update which is scheduled towards the end of the second quarter."
In fact the question was: A do we discovered the cause of the problem?
"For the G6 characters we are currently looking at adding support for them in 3DXchange 6 at the end of the 2nd quarter, with additional tools coming in the 3rd quarter."
Still Face creation was available directly IC5.here is a special reason to be operated differently for IC6 ? And if I'm not mistaken, that was free in IC5 will become paying for IC6 because it will require 3DXC6?
Supergerry
Supergerry
Posted 11 Years Ago
Posts: 25, Visits: 106
Hi Peter,
is this issue also repaired in version 6.03 ???
- - Spring no longer works after resizing Avatar with AVATAR PROPORTION
iClone 7 Pro (DX11 only), Mocap device plugin, Curve Editor, 3DXchange 7
Homebuilt PC: Windows 7 Pro SP1-64bit, 1kW BeQuiet, MSI Z97 Gaming 5, i7-4790K @ 4,00 GHz Hashwell, 32GB 1600Mhz Cruical, Gigabyte Windforce OC GTX970 4GB, 4-Monitor-Config: 28" on GTX970 only with Iclone`s main window, 2x 21" on the Intel HD4600 ports with all other tabs (timeline, scene- & content manager...), HUION GT190 TouchPen Monitor
mtakerkart
mtakerkart
Posted 11 Years Ago
Posts: 3.2K, Visits: 29.2K
Hi Peter ,
I didn't see in this trhead the terrain Heightmap Detail issue. will the next update fix it ?
Thank you for your answer
Posted 11 Years Ago
Posts: 23.1K, Visits: 36.6K
Agonos (4/13/2015)
Hi,
Your team has not yet found a clue to the problem with the "Glare" option? And when can we expect to create our own faces with IC6 avatars?
Unfortunately the "Glare" issue should now be fixed in the 6.1 update which is scheduled towards the end of the second quarter. For the G6 characters we are currently looking at adding support for them in 3DXchange 6 at the end of the 2nd quarter, with additional tools coming in the 3rd quarter.
Posted 11 Years Ago
wires (4/13/2015)
And 6.03 can be expected when??? :)
We've had a little delay on this but it is now due around the last week of April. :)
Agonos
Agonos
Posted 11 Years Ago
Hi,
Posted 11 Years Ago
Posts: 8.2K, Visits: 26.5K
Same request I had (with numerous +1's) when 6.01 and 6.02 were released...
When you start the "Official 6.03 Issues Thread," please list both the fixes (as done before) AND the KNOWN REPORTED ISSUES that will still exist in 6.03.
That will save us the trouble of re-testing, re-banging our heads into, and re-reporting things you already know about.
Looking forward to the release!  :)
3
4
5
6
21
