Computer CPU Temp
Posted By Alley 12 Years Ago
3
planetstardragon
planetstardragon
Posted 12 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
I'm still on the 314 version, but losing confidence in testing anymore because the computer isn't overheating / shutting down - it's still not running as well as it did before but at least the chances of burn out are apparently less.
sorry to hear about the mb btw, that's harsh!! I hope you get your system fully up and running again soon!!
"To define Tao is to defile it" - Lao Tzu
Alley
Alley
Posted 12 Years Ago
Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)
Last Active: 6 Months Ago
Posts: 3.7K, Visits: 12.8K
What version did you roll back to, the 310 version?  I am there but I guess I won't really know what's what til I get the new fan and motherboard installed.
Alley
planetstardragon
planetstardragon
Posted 12 Years Ago
if you have an Nvidia card , the big suspect in this is the Nvidia driver - there have been posters on Geoforce / Nvidias site claiming the new drivers are actually burning out their video cards from running so hot. I would not be surprised if it turns out that what you are experiencing is a result of this. My computer was overheating like crazy too, once I rolled back it started running normal again and hasn't shut down for a few days now - my case fan even stopped making strange noises.
Posted 12 Years Ago
Posts: 8.2K, Visits: 26.5K
Alley,
I'm so glad you didn't ignore the problem like many people do. I'm also pleased that you're getting some progress on your fan problem and that you won't have to be without your computer for several weeks.
I had been going to suggest you ensure the case fans were blowing the right direction (the front one blowing "in" and the rear one blowing "out"), but not spinning at is also a problem, obviously.
You also want to be sure your fan is properly mounted and is in solid contact with the CPU. It needs to be flat and securely pinned in on all four corners. (You won't see it, but there is also a tiny bit of "thermal grease" between the CPU and the fan. It fills any tiny air gaps and helps heat flow from your CPU to your fan.
Your temporary solution is excellent, by the way, and you should be okay until everything is sorted out.
I have a home-built system based on an Intel i7-3770k and an Asus motherboard. I'm really happy with the Asus board. I can control my case fans via the motherboard, but my daughter has a lower-budget version of the same board, and the only fan it can control is the CPU fan. I like the temperature-controlled fans because they are very quiet most of the time, and spin faster only when needed.
Both systems will perform an Intel-sanctioned "automatic overclock" from 3.5GHz to 3.9GHz when the CPU load justifies it, and as long the the temperatures allow it. It also "idles" at 1.6 GHz when I doing stuff like typing this post.
P.S.
I am not impressed with Geek Squad at Best Buy. All they do is install software like MS Office, maybe install a hard drive, and other extremely basic stuff. I had a problem with a brand-new eMachine computer several years ago (the SD card reader didn't work). Their solution was to send it to the manufacturer, estimating a 6-week turnaround. I called the eMachine support directly, explained the problem, and they shipped a new component directly to me, free of charge. They didn't even want the old one back. I ended up being very pleased with eMachine (known for low-cost computers) and very disillusioned about Geek Squad. More recently, I wanted to test a power supply. Their test was to plug it into another customer's motherboard and see if it worked. Yikes! I now own my own $15 power supply tester.
DELETED2
DELETED2
Posted 12 Years Ago
Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)Distinguished Member (16.2K reputation)
Group: Banned Members
Last Active: 10 Years Ago
Posts: 2.4K, Visits: 6.1K
Lovely news about their attitude.
Just while theyre doing that, ask them to make sure the fans lpm or fpm litres or feet per minute rate will cope with your graphics card demands and ask them to run a temperature test of serious observation rather than just test the kit works.
Get them to run a rendered test maybe with iClone churning twenty G5's. Get the GPU hot n bothered.
It's just that if the techie has his hat on the right way round he'll realise it has a graphics card of note inside it and therefore will need a serious degree of air movement.
The fan on the table might raise a smile, but its logic and works. I happy for you. Dead puters are bad news for the creative soul. :cool:
Alley
Alley
Posted 12 Years Ago
Well....unexpected turn of events.....
Fan is reconnected but still not working.  Apparently sad face produced sympathy. :P  They ordered a new fan & motherboard and I was able to bring the pc home.  When the parts come in, they will replace them which means computer will only be out of circulation for a day.
I will ghost the two drives prior to taking it in, just in case the motherboard does something to the drives.
So...I am a happy camper for now.  I'll keep a desk fan running outside the case and keep an eye on the temp.  Parts will take about 1 week to come in. :)
Alley
colour
colour
Posted 12 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
You have our sympathies, Alley.:crying:
It might be prudent to remove the additional HDD & BluRay Burner & demand a new PC or your money-back, since the current PC isn't Fit For Purpose & your Contract is with Best Buy & not Asus.
Alley
Alley
Posted 12 Years Ago
Okay, my friend Joe came by and the back fan on the computer was not running. He also said the case was a dumb design with poor ventilation.
Now I have to take it back to Best Buy to see if they can fix the fan....however, my friend attempted to attach the fan and it caused major sparks. To the point where he said there appears to be a much deeper issue. If it has to be sent back to ASUS for repair.....6 weeks. If it were less than two weeks since I bought it, I could demand a new computer...however, I already added another hard drive....moved a dvd blue ray burner to the computer, not to mention hours of work getting all the software loaded, etc.
I have a very sad face right now.:crying:
Alley
colour
colour
Posted 12 Years Ago
it has an overclocking button which I have never pushed cause I don't really know what it does.
It increases the CPU's Clock Speed, producing more heat.:ermm:
If your CPU is an i7 2600K, it's already Factory Over-Clocked. If it's an i7 2600, it isn't.;)
Good news re; the PC Techie:)
DELETED2
DELETED2
Posted 12 Years Ago
Alley (6/4/2013)
...//... and Armstrong, it is a gaming computer and it has an overclocking button which I have never pushed cause I don't really know what it does.
Oooooh, thats  very sexy. :P
OK, you HAVE to ask the techie when he comes round how to utilise it and what buffer it has. Overclocking normally has the fall off of glitching maths but used sparingly has big differences in performance.
I would say the tranny is perfectly sweet and doesnt need replacing in that case. Good.  :P
3
