G8 is supposed to work using the G3face key.duf - but it puts G8 into the new 'zero' pose Tpose with arms at 45 degrees and feet at 25 degrees in the timeline conversion. Any ideas on how to fix this please?
From Member Charleshoover885:
Here is a quick-and-dirty (note that it is only necessary on the Genesis 8 Female because of the modified T-Pose)
1. Export the G8F from DS in FBX format.
2. Open in 3DXchange and click on "Convert to Non-Standard"
3. Uncheck the "Active" box.
4. Select "lShldrBend" in Scene Tree.
5. Use rotate tool (keyboard E).
6. Rotate to standard T-Pose position.
7. Repeat for "rShldrBend, lThighBend, and rThighBend".
8. Check "Active" box.
9. Click "Convert".
10. Click "iC" Export (Top Left).
Open character in iClone. It should assume the standard standing pose.
Charles
See also this G8 to iClone Post:
https://forum.reallusion.com/329261/yes-genesis-8-works-just-need-a-new-Tpose?PageIndex=1
Toystorylab on Vimeo :
Crassitudes (my "Alter Ego") on Youtube:
