Rotate Animation Helper For iClone3
Posted By Peter (RL) 17 Years Ago
rontarrant
rontarrant
Posted 16 Years Ago
Last Active: 11 Years Ago
Posts: 231, Visits: 571
Peter (RL) (10/9/2010)
Hi Ron,
The Animation Helper will work fine in iClone 4.3 but it really is easy to just create your own helpers by following the Help Guide HERE and HERE. Give it a try and see how you get on. :)
Hi Peter,
Sorry I took so long to reply.
Thanks for the links! That does look far easier indeed.
- Ron T.
Posted 16 Years Ago
Posts: 23.1K, Visits: 36.6K
RiViT (10/5/2010)
Peter (RL) (1/11/2009)
Hi Peter,
I'm new to iClone; I just got 4.3 a few days ago. That said, here's my question:
Will this work with the latest version of iClone? Or maybe it's built in by now or available in one of those add-on packs?
BTW, great forum! Lots of useful stuff in here. It must keep you on your toes. :w00t: :)
Hi Ron,
rontarrant
rontarrant
Posted 16 Years Ago
Hi Peter,
- Ron T.
Posted 16 Years Ago
ash003 (9/30/2010)
hi there again,i have upgraded to iclone3.2pro and rotate helper ic3 dose not work.it says not a valid iclone project file.can you help please
Hi Ash,
The helper is a Prop not a Project. You will first need to unzip the contents of the file and then go to Set - Props. From there choose Import from the Modify Panel and choose the file rotate_helper_IC3.iprop. It should then load ok.
Cricky
Cricky
Posted 16 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
Here's a little visual guidance: Starts at Zero ends at ZERO for a smooth loop
http://www.youtube.com/watch?v=mOWAm_KFjKA
SKYPE ID: rc.650
ash003
ash003
Posted 16 Years Ago
Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)
Last Active: 16 Years Ago
Posts: 30, Visits: 62
ash
Sen
Sen
Posted 17 Years Ago
Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)
Posts: 2.8K, Visits: 28.5K
Hello ,
Peter thank you for the answer. I suspected a little.
I expect this update forward. Many recent elements do not work
CGTRADER
Posted 17 Years Ago
Glad you have it working ok now. Have fun. :)
Zipman
Zipman
Posted 17 Years Ago
Last Active: 17 Years Ago
Posts: 16, Visits: 32
thank you for your qiuck reply i have updated to 3.2 now the file goes on the scene with out the error but how its not showing up.
i can click on it and its in the scene manager but cant see it in the main window,
ok after more messing about i found out why i couldnt see it the opacity map was on so i saved the opacity map as a file then delete it from the pannel and it shows up lovely and works fine,
thanks again for the help.
Posted 17 Years Ago
I just tested the file in case it was faulty but the Helper works fine in iClone 3.2.
If you have not upgraded to iClone 3.2 because you are using non-english versions of iClone then sadly it may not work until you get upgraded to 3.2.
Apologies for the inconvenience.
