Rotate Animation Helper For iClone3
Posted By Peter (RL) 15 Years Ago
Posted 15 Years Ago
Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)Distinguished Member (124.2K reputation)
Last Active: 16 hours ago
Posts: 23.1K, Visits: 36.6K
Those who have been around since iClone 2.5 will remember the Animation Helpers that enabled you to animate any static model you liked, and worked especially well with models from Google Warehouse.
With the release of iClone3 the Rotate/Rolling Helper that was previously available here, no longer worked. Well now, thanks to Zack we have the new Rotate Helper for iClone3.
All you need to do is unzip the attachment below and then import the prop file rotate_helper_IC3.iProp into iClone. Then follow the simple enclosed instructions to use the helper with your models.
Have fun. Smile
mrjrm
mrjrm
Posted 15 Years Ago
Veteran Member (563 reputation)Veteran Member (563 reputation)Veteran Member (563 reputation)Veteran Member (563 reputation)Veteran Member (563 reputation)Veteran Member (563 reputation)Veteran Member (563 reputation)Veteran Member (563 reputation)Veteran Member (563 reputation)
Last Active: 6 Years Ago
Posts: 55, Visits: 722
I was just trying to use the old helper and couldn't figure out why it wasn't working! Angry
Thankfully I did a search on the forum and found that this had just been posted... Problem solved!!! w00t
Thanks Wink
Zipman
Zipman
Posted 15 Years Ago
Last Active: 15 Years Ago
Posts: 16, Visits: 32
help please when i try to use the rotate_helper_IC3 all i keep getting is failed to load props, this is not a vaild  props file. im using IC3.1
15 Years Ago by fxp_elite
Sen
Sen
Posted 15 Years Ago
Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)Distinguished Member (8.6K reputation)
Posts: 2.8K, Visits: 28.5K
Hello    ,
same for me in IC3.03 Crying .
CGTRADER
Posted 15 Years Ago
I just tested the file in case it was faulty but the Helper works fine in iClone 3.2.
If you have not upgraded to iClone 3.2 because you are using non-english versions of iClone then sadly it may not work until you get upgraded to 3.2.
Apologies for the inconvenience.
Zipman
Zipman
Posted 15 Years Ago
thank you for your qiuck reply i have updated to 3.2 now the file goes on the scene with out the error but how its not showing up.
i can click on it and its in the scene manager but cant see it in the main window,
ok after more messing about i found out why i couldnt see it the opacity map was on so i saved the opacity map as a file then delete it from the pannel and it shows up lovely and works fine,
thanks again for the help.
Posted 15 Years Ago
Glad you have it working ok now. Have fun. Smile
Sen
Sen
Posted 15 Years Ago
Hello ,
Peter thank you for the answer. I suspected a little.
I expect this update forward. Many recent elements do not work
CGTRADER
ash003
ash003
Posted 14 Years Ago
Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)Senior Member (314 reputation)
Last Active: 14 Years Ago
Posts: 30, Visits: 62
hi there again,i have upgraded to iclone3.2pro and rotate helper ic3 dose not work.it says not a valid iclone project file.can you help please
ash
Cricky
Cricky
Posted 14 Years Ago
Skype ID= learn.iclone
Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)Skype ID= learn.iclone (14.0K reputation)
Posts: 2.8K, Visits: 13.8K
Here's a little visual guidance: Starts at Zero ends at ZERO for a smooth loop
http://www.youtube.com/watch?v=mOWAm_KFjKA
SKYPE ID: rc.650
