Rotate Animation Helper For iClone3
https://forum.reallusion.com/Topic14086.aspx
Print Topic | Close Window
By Peter (RL) - 17 Years Ago
Those who have been around since iClone 2.5 will remember the Animation Helpers that enabled you to animate any static model you liked, and worked especially well with models from Google Warehouse.
With the release of iClone3 the Rotate/Rolling Helper that was previously available here, no longer worked. Well now, thanks to Zack we have the new Rotate Helper for iClone3.
All you need to do is unzip the attachment below and then import the prop file rotate_helper_IC3.iProp into iClone. Then follow the simple enclosed instructions to use the helper with your models.
Have fun. :)
By mrjrm - 17 Years Ago
I was just trying to use the old helper and couldn't figure out why it wasn't working! :angry:
Thankfully I did a search on the forum and found that this had just been posted... Problem solved!!! :w00t:
Thanks ;)
By Zipman - 17 Years Ago
help please when i try to use the rotate_helper_IC3 all i keep getting is failed to load props, this is not a vaild  props file. im using IC3.1
By Sen - 17 Years Ago
Hello    ,
same for me in IC3.03 :crying: .
I just tested the file in case it was faulty but the Helper works fine in iClone 3.2.
If you have not upgraded to iClone 3.2 because you are using non-english versions of iClone then sadly it may not work until you get upgraded to 3.2.
Apologies for the inconvenience.
thank you for your qiuck reply i have updated to 3.2 now the file goes on the scene with out the error but how its not showing up.
i can click on it and its in the scene manager but cant see it in the main window,
ok after more messing about i found out why i couldnt see it the opacity map was on so i saved the opacity map as a file then delete it from the pannel and it shows up lovely and works fine,
thanks again for the help.
Glad you have it working ok now. Have fun. :)
Hello ,
Peter thank you for the answer. I suspected a little.
I expect this update forward. Many recent elements do not work
By ash003 - 16 Years Ago
hi there again,i have upgraded to iclone3.2pro and rotate helper ic3 dose not work.it says not a valid iclone project file.can you help please
By Cricky - 16 Years Ago
Here's a little visual guidance: Starts at Zero ends at ZERO for a smooth loop
http://www.youtube.com/watch?v=mOWAm_KFjKA
By Peter (RL) - 16 Years Ago
ash003 (9/30/2010)
Hi Ash,
The helper is a Prop not a Project. You will first need to unzip the contents of the file and then go to Set - Props. From there choose Import from the Modify Panel and choose the file rotate_helper_IC3.iprop. It should then load ok.
By rontarrant - 16 Years Ago
Peter (RL) (1/11/2009)
Hi Peter,
I'm new to iClone; I just got 4.3 a few days ago. That said, here's my question:
Will this work with the latest version of iClone? Or maybe it's built in by now or available in one of those add-on packs?
BTW, great forum! Lots of useful stuff in here. It must keep you on your toes. :w00t: :)
RiViT (10/5/2010)
Hi Peter,
Hi Ron,
The Animation Helper will work fine in iClone 4.3 but it really is easy to just create your own helpers by following the Help Guide HERE and HERE. Give it a try and see how you get on. :)
Peter (RL) (10/9/2010)
Hi Ron,
Hi Peter,
Sorry I took so long to reply.
Thanks for the links! That does look far easier indeed.
