My mocap device is not being recognized
Posted By kcanache 14 Years Ago
kcanache
kcanache
Posted 14 Years Ago
Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)Senior Member (405 reputation)
Posts: 8, Visits: 216
I installed the mocap device plugin and connected my kinect mocap device into the usb port. I opened the Mocap Driver Plugin Program and click on Connect but I get this message:
Connecting to Mocap Device
Initiation fail. (65565:Device not found)
I checked in my PC under Device Manager/PrimeSense/Kinect Motor and apparently there is a problem with the driver:
Description:
Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39.
Files that help describe the problem:
C:\Users\kcanache\AppData\Local\Temp\DMI23A8.tmp.log.xml
C:\Windows\inf\oem98.inf
What did I do wrong? :hehe:
Thanks.
Keith_MPS
Keith_MPS
Posted 14 Years Ago
Posts: 385, Visits: 1.3K
Is your Kinect plugged into a power outlet?
The Kinect which comes with the XBox doesn't include a power adapter. If you bought the Kinect in a box by itself, it should come with one, though.
The Kinect has to be plugged into a power outlet via the power adapter in order to work on a computer.
It looks like this: http://www.joystiq.com/2010/11/09/kinect-standalone-power-supply-now-available-from-microsoft/
- Keith
kcanache
kcanache
Posted 14 Years Ago
Yes I did; I bought the stand alone kinect sensor that comes with the AC adapter. I'll check anyways the power outlet once I get home from work! to make sure it's not my power outlet. :)
thanks.
brand468
brand468
Posted 14 Years Ago
Posts: 231, Visits: 7.8K
Hi, I have the same problem after installed the included driver.
I then installed this package, Brekel OpenNI Kinect Auto Installer – Developer Editionv1.3.2.3.exe
And now Kinect works fine :)
My computer: Intel i7-7700K 4.2Hhz 64Gb, Windows 10, GeForce GTX 1080 + GeForce GTX 1070, Phillips monitor 40" 4K  3840x2160 + 2x28"
aussienat2000
aussienat2000
Posted 14 Years Ago
Veteran Member (717 reputation)Veteran Member (717 reputation)Veteran Member (717 reputation)Veteran Member (717 reputation)Veteran Member (717 reputation)Veteran Member (717 reputation)Veteran Member (717 reputation)Veteran Member (717 reputation)Veteran Member (717 reputation)
Last Active: 14 Years Ago
Posts: 38, Visits: 513
I have the same problem and messgaes
aussienat2000
aussienat2000
Posted 14 Years Ago
I downloaded the software mentioned above and now it operates
kcanache
kcanache
Posted 14 Years Ago
Thanks brand468 but still not working for me :unsure:
I installed the above package but still getting the same message.
I'm running on Windows Vista 64bit.
Am I doing something wrong?
1. I installed Mocap Device Plugin from Reallusion
2. I plugged in the Kinect Sensor into the USB port.
3. I was asked to insert the disk... but I don't have a disk, so I choose to find it on c: - A Kinet Motor driver was installed.
4. I opened the Mocap Device Plug-in v1.0 software and clicked on Connect but it cannot connect to the Kinect Sensor.
5. I tried installing the package Brekel OpenNI Kinect Auto Installer - Developer Edition v1.3.2.3 to try out something else but no luck.
Note: the light on the ac power adapter is on, but not light on the kinect sensor (It's supposed to blink or anything??? or that happens after connecting through the Mocap Device Plugin???)
Also on the setup instructions on Reallusion's website says:
"Once you have finished the installation and activated the required drivers, then go to the iClone5 program folder and launch the Mocap Device server (mocapserver.exe)"
Is that Mocap Device Server different from Mocap Device Plug-in or it's the same thing?
brand468
brand468
Posted 14 Years Ago
Hi,
First you start "Mocap Device Plug-in v1.0" and press connect and do the calibrate process and leave it open.
Then start iClone an insert a actor.
Got animation- motion and press Device Mocap to the right.
shygirl
shygirl
Posted 14 Years Ago
Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)
Last Active: 6 Years Ago
Posts: 1.3K, Visits: 8.3K
 Hi kcanache,
If you have the Mocap Device Plugin from Reallusion, you don't need to install Brekel OpenNI Kinect Auto Installer.  The device plugin installs everything you need.  Also, The Kinect sensor should light up as soon as you connect the USB.
I would suggest uninstalling and reinstalling but if no light is appearing on your Kinect sensor, it may be a faulty unit.  Prime Sense should also show in your device manager and the drivers should be up to date after install of Mocap Device plugin.
 Hope this helps.
Shy
"O wad some Power the gift tae gie us, to see oursels as ithers see us!"
brand468
brand468
Posted 14 Years Ago
shygirl (9/28/2011)
 Hi kcanache,
 Hope this helps.
Shy
Hi Shy,
I tried the plugin from Reallusion, but it did not work on my computer.
Worked perfect when i install the other software package. Same thing on my laptop.:unsure:
