colour
colour
Posted 14 Years Ago
Posts: 5.2K,
Visits: 8.1K
MaesiTopi (11/7/2012) Hey Guys,
I have got a question.
I am really new in Iclone.
I have build a stage with actors and added few cameras. how i can record the "movie" with switching cameras? when i press f12 i cannot enter the directors mode. Nothing happens.
Thank you for any fast help.
Cheers
MazlumWelcome to the Forum:) You "Record the movie", by using the Camera Switch Mode. The Director Mode is for "Directing" a Character using the WASD Keys. Not much used. You will get a better & more Replies by Posting in the iClone General Forum;)
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS. New Pinhead Website & Project to be announced in September 2015 -----------------------------------------------------------------------------------------
bg38
Last Active: 7 Years Ago
Visits: 911
Not sure if this has been posted before, but I've found that, when using the material tabs for the avatars, upper and lower bodies, when I change the reflection, and textures on them, then adjust the colors for the diffuse, ambient and specular colors, iclone 5 pro tends to crash on me , but if I don't add the reflection to the avatars clothing, it does not crash.
Creature Freak
Creature Freak
Posted 14 Years Ago
Visits: 342
Using movie files 30 fps as image layers/textures etc : need to be able to change the FPS in the timeline Hi all I'm new to the forums, I'm experiencing some slight choppiness and lag with Avi's and WMV, POPVIDEO movie files that are supposed to be synched with objects in the project files. The 60 fps is playing havoc with movie files that have been rendered at 30 fps as the objects and camera are moving at 60 fps but the movie files fps are stretched/paused every 2 frames to compensate for the 60 FPS. It eventually syncs, but every two frames. So scrub through 1 2 3 4 frames 2-3 are paused. Render a simple project file with a 3d object and camera move. Import the final movie as an image layer with the same project export setting etc. Render that. You will notice between the two renders a subtle choppiness. This isn't a major problem however if your doing an animation that requires subtle layer effects it can be a problem. You can also scrub through the time line with the same image layers opacity to 50% and see the original 3d object in the project. And you will see the 2 frame lag. The problem occurs with Popvideos as well because it's not about the hardware or anything it's the 60FPS on the time line that cannot be adjusted manually to 30 fps. Please give us an option to change the time line to any FPS we want like other 3d software. That way we can accurately render the exact # of frames listed in the timeline. This is going to be a big deal if Reallusion adds some function for Camera motion tracking system that will require both imported movie files and project movie file FPS to be synched. thanks CF
High Quality ICLONE Characters and Creatures and Props.
Market-place Store
YOUTUBE
sumthinwong
sumthinwong
Posted 14 Years Ago
Last Active: 8 Years Ago
Visits: 8.2K
Has anyone found a solution to the error message "Free disc space on disk C is insufficient, Iclone may not run smoothly"? Defrag has been tried, problem still persist. Peter, is there a solution forthcoming from tech support?
All arts is political, otherwise it would just be decoration. And all artists have something to say, otherwise they'd make shoes.
Earl of Oxford
Posted 14 Years Ago
Posts: 15.8K,
Visits: 31.4K
sumthinwong (12/23/2012) Has anyone found a solution to the error message "Free disc space on disk C is insufficient, Iclone may not run smoothly"? Defrag has been tried, problem still persist. Peter, is there a solution forthcoming from tech support?I just ignore it; I have not found it causing problems, but it is annoying. It seems related to large project files. The reason for the error message is a mystery; it's very hard not to have enough disk space these days.
warlord720
warlord720
Posted 14 Years Ago
Last Active: 9 Years Ago
Posts: 1.3K,
Visits: 3.9K
I get that message a lot and ignore it just as animagic states.
Another message I get sometimes is that there is not enough disk space to load the project and regretfully it will not load. Another reason to keep many iterations of the project file so you can go back to when it will load. This seems to have more to so with how many objects are in the project but I'm just guessing.
-------------------------------------------------- I LIVE to anymate, irritate and machinamate. Not necessarily in that order.
Posted 14 Years Ago
Posts: 5.7K,
I also get the not enough disk space message when trying to open some of the scenes from the World Wilderness IV set in iClone 5. iClone 4 opens them without any problem.:ermm:
lucypaynter
lucypaynter
Posted 13 Years Ago
Last Active: 13 Years Ago
Visits: 17
Hi, I purchased a pack from the marketplace and followed the prompts to download and install the accessories and costumes. But whenever I go to use any of the items in my composition, iclone puts the watermark all over the place, and claims they are trial and advises me I have to go purchase them.
But I already DID purchase them, and I definitely didn't install them til AFTER I purchased them so what would give it this idea? And how do I fix it? I need the stuff to work without the watermark.
Could it be something to do with that pack, because everything else I bought does seem to work ok?
Ha ha... just found the answer - its because I needed a clone cloth pack to make it work. Doh!
napomokoetle
napomokoetle
Posted 13 Years Ago
Last Active: 12 Years Ago
Visits: 232
Hi. I've been setting up a scene with a number of props and avatars in it with the 64bits version iClone5.32 and all having progressing well till today. Whenever I map voice-overs for characters, iClone crashes. Thinking it will perform better I deleted about 60% of the surrounding props and hid the rest. your help is greatly appreciated.:)
Posted 13 Years Ago
Posts: 15.8K,
Visits: 31.4K
@napomokoetle: Maybe something with the audio file? Does it work in a project with just the one speaking character? Memory should not be an issue with 64-bit, although it is still a beta version. Could you try it in 32-bit? You can improve available memory for 32-bit iClone by applying the 4GB patch found here: http://ntcore.com/4gb_patch.php. I have been using it for quite some time and it does make a difference.
