Any path from obj to iFace?
Posted By wjs_pdi 15 Years Ago
wjs_pdi
wjs_pdi
Posted 15 Years Ago
Last Active: 15 Years Ago
Posts: 44, Visits: 160
I'm using a face/head generator called FaceShop 6 which outputs an .obj file. Is there any pathway or work flow which allows 3DXchange 4 to take in an .obj file and output an iFace file usable in iClone 4 ?
planetstardragon
planetstardragon
Posted 15 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Posts: 11.5K, Visits: 46.0K
yeah , but i think the procedure requires some radioactive materials, asbestos, and 3DS Max along with the iclone plug in for 3DS Max...you wont be able to do it through 3DX 4 - at least not that i know of, especially because of 3DX4's strict importing scheme.
check out the developer section of the site, and look for how head morphs were created pre 3DX 4 with 3DS Max.
and maybe someone else with more knowledge on it can chime in. - Good Luck :)
"To define Tao is to defile it" - Lao Tzu
Posted 15 Years Ago
Posts: 15.8K, Visits: 31.4K
Actually, this you can do without 3DS Max.
  1. Load your character into 3DXchange.
  2. In the tree on the left, select Face.
  3. Click Export Mesh, which will save your head as an .obj file.
  4. In FaceShop, you can load this .obj file as a custom mesh.
  5. Do your FaceShop thing as usual. I found this to be tricky, especially the lining up.
  6. Save the modelled head as an .obj file.
  7. In 3DXchange, click Replace Mesh, and load the modelled head.
  8. The head texture map will not change automatically, so double-click the Diffuse icon and load the texture that FaceShop has created.
  9. You can now reimport the character with the new head in iClone.
There were a couple of things that didn't work for me. One was creating a texture map larger that 1024x1024, even if I selected 2048x2048 or 4096x4096. I have an earlier version of FaceShop that does create a larger texture.
The other problem I had was lining up the imported head. FaceShop always insists on tilting and turning it, which results in a deformed mesh. I had to use Agile to fix that.
It's a pity really, because it would be a nice way to create larger resolution face maps.
planetstardragon
planetstardragon
Posted 15 Years Ago
AM's way can be done if you start by using the 3DX4 exported mesh, but if you have another mesh from other software, you need the radioactive materials and 3DS Max. Part of the problem is that 3DX is quite strict about what it imports , and the easiest way to avoid the extra work is to use whatever mesh 3DX / Iclone gives you and model those without increasing the vertex count.
wjs_pdi
wjs_pdi
Posted 15 Years Ago
Thanks to you both. I'm off to experiment.
Posted 15 Years Ago
The procedure I outlined using FaceShop keeps the neck untouched, so no worries there. Of course, sw00000p's approach is far more dramatic... :w00t:
planetstardragon
planetstardragon
Posted 15 Years Ago
Ya, sw00000p is the 3D hazardous materials Expert, he got skillz!! :D
Posted 15 Years Ago
sw00000p (3/16/2011)[hr
Another Noobie lead astray from imcomplete advice!
sw00000p
This was the question:
The workflow I propose allows changing the iClone mesh and create a head using FaceShop, which it saves out as an .obj file. FaceShop always starts out with an existing mesh, either a built-in or an imported one. As far as I can tell that was what the OP asked for.
FaceShop shapes the mesh, based on a photo, it does not change the vertex count. I know what I'm talking about because I have actually used the procedure I outlined myself. I always give advice I try out myself and not without thought, so I find your comment unwarranted. You may not like my approach, but it works and would work for anyone who cares to follow my instructions.
rayj00
rayj00
Posted 15 Years Ago
Last Active: 12 Years Ago
Posts: 137, Visits: 372
After creating a face in Faceshop, when I import to 3DX or Meshlab, there is no face mapping?
Paumanok West
Paumanok West
Posted 15 Years Ago
Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)Distinguished Member (11.6K reputation)
Posts: 2.5K, Visits: 7.0K
rayj00 (6/18/2011)
Your face is extremely dead: it has no bones to animate with.
General Picture - animating now to life itself(tm)
Member of Content Wizards
