Posts: 5.3K,
Visits: 16.8K
luke (RL) (9/14/2024)
Hi, h20thunder69 The issue has been resolved and will be released as soon as possible next week. h20thunder69 (9/13/2024)
I've sent off a help ticket regarding this but thought I may as well leave it here too. The "Update morph to Iclone" Button no longer works after the update. Someone made a post on feedback tracker regarding the bug https://www.reallusion.com/FeedBackTracker/Issue/Update-morph-to-iclone-function-no-longer-worksAlso the hair and props disappearing issue has been happening for me too, I also some weird character twitching that jumpscared me that I have not been able to replicate but still strange. Hope this helps I sill have some accessories which would disappear with camera closeup in CC4/IC8 (same works fine in CC3/IC7). The only solution I have found is to export as OBJ, import back and reinstate materials.
LABRATS
LABRATS
Visits: 1.4K
Iclone 8.51 crashes when trying to delete objects or characters from scene
I'm facing a new bug where Iclone 8.51 crashes when trying to delete objects or characters from a scene. - Some objects or characters can be deleted, while others don't. - This issue wasn't appearing before 8.5. - This happens to almost all our projects made before IC8.5 and after 8.5 - I wasn't able to determine a trigger, what causes this Video Upload: Currently we are almost unable to work on any projects due to the frequently crashes Specs on the machine used: Win11 RTX 3080 i712700K 64RAM Hopefully this can be fixed soon Link: FeedbackTracker (A project File to recreate the issue is attached as well)
Regards LR
Posts: 23.1K,
Visits: 36.6K
christian_delavie (10/24/2024) Dear Peter,
I don't know what is going on with version 8.5 but whenever I copy and paste an animation keyframe in the timeline, iClone simply crashes. This isn't even project specific. I tried un-installing and re-installing, nothing. Plus, I don't even have a shortcut on my desktop anymore either.
Respectfully, Christian DelavieHi Christian If the issue is happening every time, please report it in the Feedback Tracker and it will be investigated by the iClone team. If you can provide the steps leading up to the issue occurring it will make it easier to track the issue. Thanks. https://www.reallusion.com/FeedBackTracker/product/iclone-8
Posts: 5.3K,
Visits: 16.8K
I copy and paste an animation keyframe in the timeline, iClone simply crashes. This isn't even project specific. This is "come and go" issue. They would fix it in one version, then the issue comes back a few updates later. I stopped reporting it... Very frustrating. Drove me nuts the other day.. and I was only working on a small project with handful of keys. It's random and for me occurs mostly with Ctrl+key dragging with mouse for copy. A little better when using Copy/Paste to scrabber location, but still was crashing as well..
christian_delavie
christian_delavie
Visits: 143
Dear Peter,
linus10111
linus10111
Visits: 2.0K
Path issues are mounting up. Best workaround i could get was to just hide and ignore paths i do not want to use.
______________________________________________________________________________________________________________ System: Win 11_Home, CPU i9-10850k (3.60GHz), 32GB RAM, RTX3080 GPU (10GB VRAM), 2TB SSD, 2TB HDD. It's definitely time for an upgrade!
Posts: 5.3K,
Visits: 16.8K
There is no issue if you create a single path with transform points in a fresh project and then try to delete. But once you create a second path (while first one is still at the scene), then you are stuck. You may delete the first path but not the newly created. So every time you add a new transform path after that, you may delete existed but not the new one. Very weird bug :Whistling:
linus10111
linus10111
Visits: 2.0K
4u2ges (10/20/2024) @linus10111 I cannot replicate that. Please make your project fully shared (without the need to request an access).
sorry i missed that step. Link is fixed now.
Posts: 5.3K,
Visits: 16.8K
linus10111
linus10111
Visits: 2.0K
PATH REFUSES TO BE DELETED (Posted on Feedback Tracker) I created a path, and wish to delete it. Right-clicking and selecting delete from context menu does not work. Using the keyboard delete button does not work.
TO REPRODUCE THE ISSUE: 1.Create a camera. 2.Move it around to create a few keyframes. 3.Select the keyframes and convert position to path. 4.Delete the path.
RESULT: iClone will not allow the path to be deleted. I also created a path using keyframes from primitive objects i moved around. Trying to delete this path also doesnt work. I'm guessing this means all scene objects will face a similar error.
I then i created a path the normal way (create> path), and was able to delete it without any issues.
Here's a link to the project file:Project file
Anybody found a workaround to this?
