HansRL
Last Active: 3 hours ago
Visits: 160
v4.5 (4.5.3305.1) released on Sep. 5th, 2024 Several bug fixes
Fixed:
Manually removing ZBrush does not clear the related registry datas, causing CC GoZ to fail because it cannot retrieve the ZBrush path from the registry. Feedback TrackerAfter applying hair to a character, enabling the GI light source, picking the hair, and then selecting Translucent GI in the Material > GI Settings, the hair becomes semi-transparent. Feedback TrackerIf an accessory's physics collision shape is set to ConvexHull, it can cause the export of the FBX file to fail. Feedback TrackerWhen a prop contains substance data, if the substance has a Visible If parameter set, it may fail to load.When using shared materials, if some meshes lack skin weight data, there is a chance that the application may crash during motion playback. Feedback TrackerWhen facial hair with a custom morph is exported as an FBX, the morph result is incorrect. Feedback Tracker
bennydee
bennydee
Posted Last Month
Last Active: 1 minute ago
Visits: 3.4K
its unfair to release an update without updating other plugins I'm stranded i cant render out projects i created in prev. iclone to omniverse my projects have deadlines...so i will just sit and wait till God knows when???? not professional and it puts users at risk of failing deadlines with clients. why dont yall make sure all is ready and released same time?? whats the rush
csmallfield
csmallfield
Posted Last Month
Visits: 17
Hello, I just purchased CC4 (now 4.5) and I would also like to know when Omniverse compatibility will be functioning again. Or as a temporary solution, which version should I go back to in order to have compatibility?
luke (RL)
luke (RL)
Posted Last Month
Group: Power Developer
Visits: 5.5K
Hi, csmallfield jsut replace the MinimumVerRequired.ini ( download here) in the Reallusion\Character Creator 4\Resource\OmniversePlugin directory. csmallfield (9/12/2024) Hello, I just purchased CC4 (now 4.5) and I would also like to know when Omniverse compatibility will be functioning again. Or as a temporary solution, which version should I go back to in order to have compatibility?
Last Month by
luke (RL)
gtjr
Visits: 100
Luke I got this working for CC4.5, I tried the same thing for IClone 8.5 and that did not fix it any ideas ? My Iclone actually crashes at 16% every time, which is what CC4 was doing before I applied your ini file thanks luke (RL) (9/14/2024)
Hi, csmallfield jsut replace the MinimumVerRequired.ini ( download here) in the Reallusion\Character Creator 4\Resource\OmniversePlugin directory. [/quote]
Last Month by
gtjr
csmallfield
csmallfield
Posted Last Month
Visits: 17
Thanks for the fix, cheers!
luke (RL)
luke (RL)
Posted Last Month
Visits: 5.5K
Hi, gtjr
iClone 8.5 has new connector, please download it in NV launcher gtjr (9/14/2024)
