Character Creator 4.5 - New update
Posted By HansRL 2 Years Ago
Rated 1 star based on 1 vote.
HansRL
HansRL
Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)
Posts: 29, Visits: 214
v4.5 (4.5.3305.1) released on Sep. 5th, 2024
Several bug fixes
Fixed:
  • Manually removing ZBrush does not clear the related registry datas, causing CC GoZ to fail because it cannot retrieve the ZBrush path from the registry. Feedback Tracker
  • After applying hair to a character, enabling the GI light source, picking the hair, and then selecting Translucent GI in the Material > GI Settings, the hair becomes semi-transparent. Feedback Tracker
  • If an accessory's physics collision shape is set to ConvexHull, it can cause the export of the FBX file to fail. Feedback Tracker
  • When a prop contains substance data, if the substance has a Visible If parameter set, it may fail to load.
  • When using shared materials, if some meshes lack skin weight data, there is a chance that the application may crash during motion playback. Feedback Tracker
  • When facial hair with a custom morph is exported as an FBX, the morph result is incorrect. Feedback Tracker
  • bennydee
    bennydee
    Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)
    Posts: 79, Visits: 3.4K
    its unfair to release an update without updating other plugins I'm stranded i cant render out projects i created in prev. iclone to omniverse my projects have deadlines...so  i will just sit and wait till God knows when???? not professional and it puts users at risk of failing deadlines  with clients. why dont yall make sure all is ready and released same time?? whats the rush
    csmallfield
    csmallfield
    New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)
    Posts: 6, Visits: 21
    Hello, I just purchased CC4 (now 4.5) and I would also like to know when Omniverse compatibility will be functioning again. Or as a temporary solution, which version should I go back to in order to have compatibility?
    luke (RL)
    luke (RL)
    Group: Power Developer
    Posts: 289, Visits: 5.6K
    Hi, csmallfield
    jsut replace the MinimumVerRequired.ini (download here) in the Reallusion\Character Creator 4\Resource\OmniversePlugin directory.
    csmallfield (9/12/2024)
    gtjr
    gtjr
    Junior Member (213 reputation)Junior Member (213 reputation)Junior Member (213 reputation)Junior Member (213 reputation)Junior Member (213 reputation)Junior Member (213 reputation)Junior Member (213 reputation)Junior Member (213 reputation)Junior Member (213 reputation)
    Posts: 15, Visits: 110
    Luke I got this working for CC4.5, I tried the same thing for IClone 8.5 and that did not fix it any ideas ? My Iclone actually crashes at 16% every time, which is what CC4 was doing before I applied your ini file
    thanks
    luke (RL) (9/14/2024)
    Hi, csmallfield
    [/quote]
    csmallfield
    csmallfield
    Thanks for the fix, cheers!
    luke (RL)
    luke (RL)
    Hi, gtjr
    iClone 8.5 has new connector, please download it in NV launcher
    https://forum.reallusion.com/uploads/images/3253a0ad-5648-415f-836a-0c4d.png
    gtjr (9/14/2024)
    thanks
    Hi, csmallfield
    [/quote]
