Character Creator 4.5 - New update
Posted By HansRL Last Month
Rated 1 star based on 1 vote.
HansRL
HansRL
Posted Last Month
Veteran Member (708 reputation)Veteran Member (708 reputation)Veteran Member (708 reputation)Veteran Member (708 reputation)Veteran Member (708 reputation)Veteran Member (708 reputation)Veteran Member (708 reputation)Veteran Member (708 reputation)Veteran Member (708 reputation)
Last Active: 3 hours ago
Posts: 26, Visits: 160
v4.5 (4.5.3305.1) released on Sep. 5th, 2024
Several bug fixes
Fixed:
  • Manually removing ZBrush does not clear the related registry datas, causing CC GoZ to fail because it cannot retrieve the ZBrush path from the registry. Feedback Tracker
  • After applying hair to a character, enabling the GI light source, picking the hair, and then selecting Translucent GI in the Material > GI Settings, the hair becomes semi-transparent. Feedback Tracker
  • If an accessory's physics collision shape is set to ConvexHull, it can cause the export of the FBX file to fail. Feedback Tracker
  • When a prop contains substance data, if the substance has a Visible If parameter set, it may fail to load.
  • When using shared materials, if some meshes lack skin weight data, there is a chance that the application may crash during motion playback. Feedback Tracker
  • When facial hair with a custom morph is exported as an FBX, the morph result is incorrect. Feedback Tracker
  • bennydee
    bennydee
    Posted Last Month
    Veteran Member (714 reputation)Veteran Member (714 reputation)Veteran Member (714 reputation)Veteran Member (714 reputation)Veteran Member (714 reputation)Veteran Member (714 reputation)Veteran Member (714 reputation)Veteran Member (714 reputation)Veteran Member (714 reputation)
    Last Active: 1 minute ago
    Posts: 79, Visits: 3.4K
    its unfair to release an update without updating other plugins I'm stranded i cant render out projects i created in prev. iclone to omniverse my projects have deadlines...so  i will just sit and wait till God knows when???? not professional and it puts users at risk of failing deadlines  with clients. why dont yall make sure all is ready and released same time?? whats the rush
    csmallfield
    csmallfield
    Posted Last Month
    New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)New Member (25 reputation)
    Posts: 6, Visits: 17
    Hello, I just purchased CC4 (now 4.5) and I would also like to know when Omniverse compatibility will be functioning again. Or as a temporary solution, which version should I go back to in order to have compatibility?
    luke (RL)
    luke (RL)
    Posted Last Month
    Group: Power Developer
    Posts: 287, Visits: 5.5K
    Hi, csmallfield
    jsut replace the MinimumVerRequired.ini (download here) in the Reallusion\Character Creator 4\Resource\OmniversePlugin directory.
    csmallfield (9/12/2024)
    Last Month by luke (RL)
    gtjr
    gtjr
    Posted Last Month
    Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)Junior Member (203 reputation)
    Posts: 14, Visits: 100
    Luke I got this working for CC4.5, I tried the same thing for IClone 8.5 and that did not fix it any ideas ? My Iclone actually crashes at 16% every time, which is what CC4 was doing before I applied your ini file
    thanks
    luke (RL) (9/14/2024)
    Hi, csmallfield
    [/quote]
    Last Month by gtjr
    csmallfield
    csmallfield
    Posted Last Month
    Thanks for the fix, cheers!
    luke (RL)
    luke (RL)
    Posted Last Month
    Hi, gtjr
    iClone 8.5 has new connector, please download it in NV launcher
    https://forum.reallusion.com/uploads/images/3253a0ad-5648-415f-836a-0c4d.png
    gtjr (9/14/2024)
    thanks
    Hi, csmallfield
    [/quote]
