Extract Mesh Via Element Selection - greys out extract mesh button when fully selected
Posted By Ascensi Last Year
Extract Mesh Via Element Selection - greys out extract mesh button...
Ascensi
Ascensi
Posted Last Year
Posts: 262, Visits: 1.9K
So I finally found out the issue, apparently in the scene search, somehow it remembered a search from before and hid everything within the character itself!! I thought it would only hide contents in the list as a whole. it was confusing because I can see root node, the belts, metal parts etc  (they are unique words that weren't the same as the search) Is it normal for a project to remember a word and keep it in the search? either that maybe my hand slipped at some point and I hit a key. Regardless, I had only expected isolation mode to maybe pin point and isolate actual models.
The only reason why I needed to extract the cloak was because I was unable to select it to fix some weights.
 *********Maybe a word in the scene search different than the model name you want to edit prevents it from being able to be extracted all at once if not shown in the scene view. I'll have to test that some time.**********
Store Page Link
AMD 4.5 GHz 16 Cores  | 128 GB | RTX 4090 | Window11 | Houdini FX 18.5 | Zbrush 2023 | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iC8, CC4 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
Ascensi
Ascensi
Posted Last Year
Hi Rampa, thanks for the tip! unfortunately it still wont let me extract through editing but when i went to send the imported obj prop over to Zbrush, it showed me all the parts!! but I will extract the cloak at least and send it back.  https://forum.reallusion.com/uploads/images/f260cb88-67fa-44d3-a797-c6f1.png I really hope Reallusion updates it to at least make parts a selectable    sub-mesh via mesh extraction or internally or make it a HIK Clothing piece only compatible with itself via vert count.
Store Page Link
Ascensi
Ascensi
Posted Last Year
The cloak becomes hidden, so does the body and eyes.  Originally I wanted the cloak to be a sub meshes that I could enable/disable at any time, eyes and shell too but it didn't take.
It may have been the organization that the meshes were in with bones before import. Some like to parent meshes to bones, others say meshes have to be at the root of the bone hierarchy otherwise you can get double the animation instruction to a single mesh. I didn't do that either but even so, there is nothing wrong with the mesh itself unless it max out on how many verts it can extract at one time.
Store Page Link
Posted Last Year
Posts: 8.2K, Visits: 62.6K
I have seen this before as well. Try exporting your character as an OBJ, reimport as a prop, and then extract the cape mesh from the prop.
Posted Last Year
Posts: 5.3K, Visits: 16.8K
Out of curiosity...
What happens if you hide all meshes one by one, but leave the RootNode visible.
Do you see anything in the view-port?
If you do, then that part of the mesh for whatever reason is not bound as a mesh (CC could not read that mesh as a node on import).
Then the only way is to do it outside of CC (Blender?)
Ascensi
Ascensi
Posted Last Year
You can't convert it to an accessory if it's not in the scene list in your character to select and convert. If I choose element in the mesh editor, it selects the entire cloak mesh, nothing else.
About no going back, I could at least enable physics to keep it cloth-like even if it won't allow me to making it skinned as clothing. There isn't much reason to assign it as a cloth if someone enables physics on it, the pinning can be done with black as you know and the clothing piece just be attached to the hip.
https://forum.reallusion.com/uploads/images/ecc438a6-f64e-437d-b692-1dea.png
Store Page Link
Posted Last Year
The only other reason, is that the mesh has some errors.
But what mesh that cloak is part of?
Hide those meshes one by one to find out what part it belongs to.
Then select that mesh only and try edit and Extract.
If one of them only hides the cloak, then there is nothing to extract.
Keep that selected and use Convert to Accessory to separate.
But there is no going back converting to cloth though for Humanoids/Creatures
Ascensi
Ascensi
Posted Last Year
Thanks, I may have to give that a try. As I was sharing with 4u2ges, Kai had demonstrated full part extraction of vehicle parts so I don't know why I can't extract a full part not attached to the main character via verts.
Store Page Link
Ascensi
Ascensi
Posted Last Year
Can't select any object/mesh to convert to accessory, it seems to have merged the part/cloak with the body. I wish parts to be extracted could  simple be converted to clothing or accessory.  I've seen Kai Extract whole parts from a vehicle, this I think should be a non issue.  Selecting the whole part is a normal operation for mesh extraction as seen in the tutorial https://youtu.be/iuKaploaMPE?t=2459 The cloak is merged with the body but thankfully not the verts.
https://forum.reallusion.com/uploads/images/2a7124fd-8d13-4e3e-b5c5-ab27.png
Store Page Link
Posted Last Year
But what is the ultimate goal?
Extract is intended for splitting the mesh into parts (2 or more separate meshes).
If you need to separate a certain mesh from the character, use "Convert to Accessory" function.
