Character Creator rendering white, no textures
Posted By gekido Last Year
gekido
gekido
Posted Last Year
Posts: 60, Visits: 232
This just started happening, it's strange.
I'm trying to render out some preview pics for my characters but the rendered images end up all white (like shown) and then the character in character creator does the same thing, it loses all of their textures and are basically broken until I reload them?
Not sure what's going on here.
Any ideas? This is with the latest CC4. I'm rendering an Image, PNG, Final Render, Reduce Color Banding, Render with Max Texture Resolution, all settings that I have used for quite a while to render out my characters?
75% of original size (was 673x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/72e410ac-c451-4636-a2ce-6414.png
www.twitter.com/gekido
gekido
gekido
Posted Last Year
and now it's happening if I send the character to IClone and render there...sigh..
Posted Last Year
Posts: 15.8K, Visits: 31.3K
Try disabling Render with Max Texture  Resolution as this has been reported to give problems in the latest iClone and CC versions.
richard666
richard666
Posted Last Year
Posts: 74, Visits: 425
its happening to me!!!!! again at a critical work project time, i am so pissed off with the money i loose trying to sort out Reallusion faults..  cant go on like this any longer
Posted Last Year
Last Active: 7 days ago
Posts: 8.2K, Visits: 62.5K
So if you still have this issue, please do the following. You can test each one at a time to see if just one solves it.
1. Update your graphics driver.
2. Un-check the progressive texture loading box in the Performance section of the Preferences.
3. Set your realtime texture resolution to the largest texture size you are using, then un-check the "Render With Max Texture Resolution" in the render panel. If your realtime texture resolution is already your maximum texture map resolution you are not gaining any higher resolution by checking the box. You would only need to check that box if you run your realtime texture resolution lower than your maximum used texture resolution.
For instance. I sometimes run my realtime textures lower to save on VRAM on my video card. This is more important for iClone than CC, because of the amount of textures in a scene.
gekido
gekido
Posted Last Year
Thanks for the detailed reply. If I run into this again, I'll definitely dbl check those settings.
ReMark3Dcz
ReMark3Dcz
Posted Last Year
Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)
Posts: 68, Visits: 918
Thank you Rampa!!
Finally my new character in "iray test" is rendering correctly with textures :-)
I was under the impression that there was some bug in my character.
It was quite frustrating and I couldn't find a solution, the recommended points helped.
Martin (RM3D)
75% of original size (was 673x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/63c12417-4cb8-4c33-a3de-5558.png
RM3D
https://marketplace.reallusion.com/character-creator/author/remark3dcz
lubu
lubu
Posted Last Year
New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)
Posts: 1, Visits: 18
are you using headshot 2.0 ? i fixed the problem a month ago but it just happened right now im trying to remember
gekido
gekido
Posted Last Year
No I wasn't in my case, have done renders with headshot characters since and they work fine using the tips above
