Textures Seams on Character when Exporting for Unreal 5.3
Posted By DS-Waqas 2 Years Ago
DS-Waqas
DS-Waqas
Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)
Posts: 69, Visits: 442
Hi,I am using Unreal Auto Setup 1.34 for Unreal 5.3. I've attached the import and export settings I'm using Iclone 8 & CC4 It doesn't matter either way I get seams in the materials. This is really frustrating! I tried uninstalling and reinstalling the plugins and it still does this. I didn't have this problem in earlier versions.What am I doing wrong?
Export from CC4
https://forum.reallusion.com/uploads/images/61688f67-f19d-441a-8191-1cda.jpg
Export from Iclone 8
https://forum.reallusion.com/uploads/images/dde7df34-776c-42da-846b-ab71.jpg
Unreal Import Settings
https://forum.reallusion.com/uploads/images/02df01eb-c387-4d65-8c52-c760.jpg\
Also the CC4 Import just gets stuck at 30% forever here
https://forum.reallusion.com/uploads/images/5393981c-00d8-43bf-a915-be86.jpg
What is going on here? Everything looks fine in CC4 & Iclone 8.
https://forum.reallusion.com/uploads/images/ada49b8c-835d-4561-8d99-62f6.jpg
DS-Waqas
DS-Waqas
Ok so I just discovered  this issueseems to only happen in Unreal Projects where I already had a previous versionof Auto Set Up installed.
When I create a new Unreal Project from scratch it works without any issues.
This is how I'mupdating the plugin
I first go anddelete the CC_Shaders folder from  Content
Then I close Unreal andgo to the Project folder to delete the Plugins folder
And anythingremaining of the CC_Shaders folder
Then I just copypaste the newer Content and Plugins folder for Auto Setup 1.35 directly intothe Content folder of my Unreal Project
One thing:  I amrunning the exe of the Auto Set Up Plugin before doing all this to get accessto the plug in folders  I need  to copy over.
