Textures Seams on Character when Exporting for Unreal 5.3
Posted By DS-Waqas 2 Years Ago
DS-Waqas
DS-Waqas
Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)Veteran Member (883 reputation)
Last Active: 3 Weeks Ago
Posts: 69, Visits: 443
Hi,I am using Unreal Auto Setup 1.34 for Unreal 5.3. I've attached the import and export settings I'm using Iclone 8 & CC4 It doesn't matter either way I get seams in the materials. This is really frustrating! I tried uninstalling and reinstalling the plugins and it still does this. I didn't have this problem in earlier versions.What am I doing wrong?
Export from CC4
https://forum.reallusion.com/uploads/images/61688f67-f19d-441a-8191-1cda.jpg
Export from Iclone 8
https://forum.reallusion.com/uploads/images/dde7df34-776c-42da-846b-ab71.jpg
Unreal Import Settings
https://forum.reallusion.com/uploads/images/02df01eb-c387-4d65-8c52-c760.jpg\
Also the CC4 Import just gets stuck at 30% forever here
https://forum.reallusion.com/uploads/images/5393981c-00d8-43bf-a915-be86.jpg
What is going on here? Everything looks fine in CC4 & Iclone 8.
https://forum.reallusion.com/uploads/images/ada49b8c-835d-4561-8d99-62f6.jpg
DS-Waqas
DS-Waqas
Ok so I just discovered  this issueseems to only happen in Unreal Projects where I already had a previous versionof Auto Set Up installed.
When I create a new Unreal Project from scratch it works without any issues.
This is how I'mupdating the plugin
I first go anddelete the CC_Shaders folder from  Content
Then I close Unreal andgo to the Project folder to delete the Plugins folder
And anythingremaining of the CC_Shaders folder
Then I just copypaste the newer Content and Plugins folder for Auto Setup 1.35 directly intothe Content folder of my Unreal Project
One thing:  I amrunning the exe of the Auto Set Up Plugin before doing all this to get accessto the plug in folders  I need  to copy over.
