"The iTalk file contains custom expressions..." for all Expression Loop clips, no matter the...
Posted By dan.goyette 2 Years Ago
"The iTalk file contains custom expressions..." for all Expression...
dan.goyette
dan.goyette
Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)
Posts: 83, Visits: 379
It's been about 6 months that I've been dealing with this, and I still see no fix/workaround/solution.
Add any of the animations under Animation => Expression => Expression_Loop (such as "Anger_Hi"), and it will always pop up this message:
I've tried this with every character that CC4 provides, with all of the Facial Profile options available, and every combination still results in this warning, every time I add the Expression, even if I've added that expression before.
  • How do I get this message to stop showing up?
  • What is in the iTalk files that's causing this issue, and how can the offending parts of the iTalk files be removed?
  • What do the two choices here even mean? Which am I suppose to pick?
I reported this as an issue over 6 months ago (https://www.reallusion.com/FeedBackTracker/Issue/Default-Expression-Loop-iTalk-files-produce-unavoidable-warnings-when-applied-to-any-character), with no resolution. Frustratingly, I also see that if I use one of these expression in iClone, it does the exact same thing, with no better handling.
Is there a workaround to this? Can I somehow edit the iTalk files to prevent them from generating these messages?
