Hi,
I have an Unreal 5 project with Character Creator characters.
I have copied "content" and "plugin" folders from the version
1.32 of the plugin to the 5.3.2 version of unreal engine, copy and paste in the unreal project folder, as it says in the plugin documentation:
https://www.reallusion.com/auto-setup/unreal-engine/download.html
The project looks good despite for the fact that is impossible to package and export for windows.
The error message from unreal is the following one:
UATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] Can't connect pins Subject Metadata generated from expanding RLLive Link and Meta Data generated from expanding RLLive Link : Subject Metadata Structure (by ref) is not compatible with Array of Anim Meta Data Object References. from Source: /Game/RLContent/Light/Side.SideUATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] In use pin Subject Frame Handle generated from expanding Get Curves no longer exists on node Get Curves generated from expanding Get Curves . Please refresh node or break links to remove pin. from Source: /Game/RLContent/Light/Side.SideUATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] In use pin Curves generated from expanding Get Curves no longer exists on node Get Curves generated from expanding Get Curves . Please refresh node or break links to remove pin. from Source: /Game/RLContent/Light/Side.SideUATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] Could not find a function named "GetCurves" in 'Side'.UATHelper: Packaging (Windows): Make sure 'Side' has been compiled for Get Curves generated from expanding RLLive Link from Source: /Game/RLContent/Light/Side.SideUATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] Can't connect pins Meta Data generated from expanding RLLive Link and Subject Metadata generated from expanding RLLive Link : Array of Anim Meta Data Object References is not compatible with Subject Metadata Structure (by ref). from Source: /Game/RLContent/Light/Side.SideDo you know what could be happening?TThank you very much
