UATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] Can't connect pins Subject Metadata generated from expanding RLLive Link and Meta Data generated from expanding RLLive Link : Subject Metadata Structure (by ref) is not compatible with Array of Anim Meta Data Object References. from Source: /Game/RLContent/Light/Side.SideUATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] In use pin Subject Frame Handle generated from expanding Get Curves no longer exists on node Get Curves generated from expanding Get Curves . Please refresh node or break links to remove pin. from Source: /Game/RLContent/Light/Side.SideUATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] In use pin Curves generated from expanding Get Curves no longer exists on node Get Curves generated from expanding Get Curves . Please refresh node or break links to remove pin. from Source: /Game/RLContent/Light/Side.SideUATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] Could not find a function named "GetCurves" in 'Side'.UATHelper: Packaging (Windows): Make sure 'Side' has been compiled for Get Curves generated from expanding RLLive Link from Source: /Game/RLContent/Light/Side.SideUATHelper: Packaging (Windows): LogInit: Display: LogBlueprint: Error: [Compiler] Can't connect pins Meta Data generated from expanding RLLive Link and Subject Metadata generated from expanding RLLive Link : Array of Anim Meta Data Object References is not compatible with Subject Metadata Structure (by ref). from Source: /Game/RLContent/Light/Side.SideDo you know what could be happening?TThank you very much
